Posted: Wed Aug 12, 2020 1:04 pm Post subject: RV10 primary elec sys wiring |
Alex,
You need to move this conversation to the AeroElectric-List.
I see that you are presently subscribed.
What kind of engine and ignition system? (your excel spread sheet didn't
come through).
Your task is not difficult but there are a lot of questions
about hardware and manner in which the airplane will be
used.
I don't have the time to do consulting on individual projects
except when the subject matter sorts out details of physics
and practice of interest to the List as a whole.
But there's a bunch of folk on the List with more experience
than I in the fabrication and operation of owner built and
maintained airplanes who would be glad to join and help
move your project along.
This doesn't mean that I won't participate but with
all the irons I have in the fire, I need to tailor
my activities to those where I can help the most.
Tell us more about your project.
At 01:49 PM 8/12/2020, you wrote:
| Quote: | Dear Bob,Â
I am frustrated, feeling like I know nothing. The more I read - the more this feeling is inside me.Â
Commercial aviation experience now can't help (
I have made load analyses, as you advised (attached excel doc) - could you, please, give the direction on the primary electrical system?Â
still thinking on how to integrate a small backup battery (what equipment should it power, as EFIS displays and standby display have their own backup batteries), how many buses to use and determine what equipment must be powered from exact bus...
attached list has ELA, sources list and equipment list. ELA will be triple-checked, for sure -Â
it was not an easy task to determine load in different phases without experience, but exciting and, I believe, everything will be fine!Â
My main goal is to create a simple, but redundant and reliable system based on hardware which friend has already purchasedÂ
(frustrated regarding alternator with built-in voltage regulator- as read before in the Book it is not the best option, but will see ...) Â
Â
Could you, please, be so kind to help...?
Kindest regards,
Alex
Posted: Wed Aug 12, 2020 1:35 pm Post subject: RV10 primary elec sys wiring |
At 04:03 PM 8/12/2020, you wrote:
| Quote: | Bob,Â
thanks a lot for advice - i will create topic.Â
Great thanks for support! |
Alex,
Like I said . . . too many irons in the fire . . . it
slipped my mind that we'd already opened a List topic
and I published a suggested starting point for your
architecture:
See https://tinyurl.com/y6ku7lbh
List your ideas as to which accessories would
power from each bus in this drawing?
rngurley(at)att.net Guest
Posted: Fri Aug 14, 2020 10:18 am Post subject: RV10 primary elec sys wiring |
Bob –
For an RV 10 with a rear battery, I would like a rear ground bus in addition to a firewall ground bus. Is it OK to run a negative wire from the battery to the rear ground bus and then forward to the firewall ground buss?
Thank you
Dick
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Saturday, July 25, 2020 9:54 PM
To: Alex Ivancheskul <airkbp(at)gmail.com>; aeroelectric-list(at)matronics.com
Subject: Re: RV10 primary elec sys wiring
At 09:57 AM 7/23/2020, you wrote:
Good day Dear Mr.Nuckolls,
First, i really happy that i've met your book and web site with plenty of extra useful information.I am aircraft maintenance engineer (mostly Boeing type rated), have practical and theoretical skills. but realized that need some more theoretical researches for better elec system knowledge.
Those fundamentals will serve you well in your
new aviation endeavors. Your sense of craftsmanship
and knowledge of 'how the other guys do it' will
be useful.
Recently friend of mine asked me to help with his RV-10 electrical and avionics hookup. Most of works are done except all wiring work. I spent many hours doing research and stuck...we have perhaps unusual config with one regular battery(RG-25XC)with Batteryminder charging kit BM-AIK2A, just one primary alternator Plane Power 99-1012 with built-in voltage regulator (unfortunately) and small cmart backup battery TCW IBBA-12v-6AH. Ignition - Champion slick magnetos (6393 and 6350) , lefthand one with SS1001 booster.
You don't mention how this airplane will be used.
Day VFR, Day/Nite VFR, 'hard' IFR, extended flight
over unfriendly terrain? What avionics are anticipated?
Which devices will exploit the back-up battery?
Despite I am professional avionic I am really stuck and frustrated in myself...
You've come to the right place. I've taken the liberty
of signing you up as a participant on the AeroElectric-List.
We are a 'members only' consortium of aviation enthusiasts with
broad range of experience and skills. We strive for elegant
solutions based on good science.
When you receive the invitation to join us, just respond in
the affirmative and you'll be 'plugged in' to one of the
most comprehensive electrical/avionics communities on the
'net'.
Could you please, advise where can i find help with backbone elec system
architecture and etc...guys want to fly in couple of months))))
We're pleased to help. Tell us more about the project.
At firsts blush, your architecture requirements may
be exceedingly simple. Stand alone magnetos. Simple
one battery/one alternator configuration not unlike
hundreds of thousands of type certificated aircraft
that have flown successfully for a century. The
greatest difference will be the lack of an 'avionics
bus' and associated master switch. That concept was
hatched with poor understanding of then-brand-new
solid state avionics. The value of the avionics master
was limited from the beginning then and has no
value today.
Based on what we know now, your shared details may
prompt further suggestions. I've posted a 'first
pass on an architecture we're evolving here
on the AeroElectric-List. It shows an endurance
bus (common to single alternator designs), battery
bus and a brown-out booster. You may not need
any of these things we'll help you figure it out.
See: https://tinyurl.com/y6ku7lbh
Thank you again for your great work and support of aviation community!
You're most welcome my friend . . . it's what we do
here.
Posted: Fri Aug 14, 2020 11:27 am Post subject: RV10 primary elec sys wiring |
At 01:13 PM 8/14/2020, you wrote:
| Quote: | Bob –
Thank you
Dick |
Not necessary. Ground batteries locally to structure
https://tinyurl.com/n9rgrg8
https://tinyurl.com/y5c8qejs
https://tinyurl.com/y3chtcmh
Add some ground studs to any fabricated
brackets utilized in grounding batteries
to accommodate aft grounds.
Install firewall ground bus normally.
Be sure to included crankcase to thru-
bolt braided strap or 2AWG welding
cable.
airknot
Posted: Mon Aug 17, 2020 3:09 am Post subject: Re: RV10 primary elec sys wiring |
Dear Matronics Society!
First - I am extremely happy to meet all of you.
Guys, hope for your kind help in this complicated task.
GENERAL CONFIG: IFR flights
Power sources config:
1 - alternator 60 A with internal voltage regulator (Plane Power AL12-EI60 (99-1012))
2 – main battery 24 Ah (Concorde RG-25XC)
3 – backup smart battery (TCW IBBS-12V-6AH) – max cont load 8 A, intermittent 12 A
Engine: Lycoming IO-540-D4A5
Ignition: standard Champion SLICK MAGNETOs 6393 (LH) and 6350(RH) plus SlickStart module S1001 for one magneto(left) for better start. Keyed ignition switch – ACS A-510-2K.
Avionics – Dynon SkyView HDX complex with 2 monitors (+2 backup batteries for displays) and respective subsystems, except comm.
Communication – Garmin GMA245 with GTR 225A
Backup navigation - Garmin G5 system (+ backup battery).
I am looking for reliable and simple enough system…
Bob was extremely kind to me and helped with initial idea of Primary Electric system for RV-10.
Wiring: https://drive.google.com/file/d/1lbioIrf2NMAUnkgLyg7kzthyvVueMHyV/view?usp=sharing
I have done ELA but found that with 60A alternator i have load that exceeds alt capacity (about 65 A total current draw in max config, that is practically unrealistic situation, but ...). So, now i will double-check ELA, and then will think what to do...
Here is ELA with power sources assessment and List of equipment:
https://drive.google.com/file/d/1KQJFOoFCRKHqWNgRtfG3JbY6XyPKGQ0d/view?usp=sharing
Regarding aux battery - we will use TCW IBBS-12V-6Ah, that can continuously supply 8 Amps when sensing main bus (or another bus, depending on Primary elec system logic) voltage drop below 11 VDC.
My idea was to create Essential bus to power from this TCW backup battery in case of emergency.
Quote from TCW Tech Support letter regarding backup battery:
The pass-thru pins are an input that you connect to the main bus. They bring power into the IBBS which is automatically passed through to the outputs. During normal operation, the power from the aircraft bus comes into pins 6,7,8 and is passed out to pins 12-15, this allows the equipment connected to pins 12-15 operate normally. Then if there is a condition on the main bus where the voltage falls below 11 volts, the IBBD internal battery is connected to pins 12-15 to run the essential equipment. No power is back fed to the main bus.
If someone has experience in such smart battery utilization - please, share, it’s very interesting…
I am kindly asking for help and any kind of assistance and guidance for Primary Electrical System architecture calculations and building. Without you at this stage I do not see the way to successfully build RV10..
toaster73(at)embarqmail.c Guest
Posted: Mon Aug 17, 2020 7:56 am Post subject: RV10 primary elec sys wiring |
There are some nice schematics for the RV-14 or RV-12 that certainly can help you visualize what you may want for the RV-10. GO to this link:
https://www.vansaircraft.com/downloads/
-Chris
ceengland7(at)gmail.com Guest
Posted: Mon Aug 17, 2020 8:42 am Post subject: RV10 primary elec sys wiring |
On Mon, Aug 17, 2020 at 6:17 AM airknot <airkbp(at)gmail.com (airkbp(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "airknot" <airkbp(at)gmail.com (airkbp(at)gmail.com)>
2 – main battery 24 Ah (Concorde RG-25XC)Â
| What's missing from your loads list above? I only see about 20A, absolutely worst case, in that list (unless that Dynon stuff is hideously inefficient). Have you done a spreadsheet, or even just a list, with every load item with columns showing continuous and peak loads for each device, and if applicable, an intermittent duty column? For example, the Slickstart, and flaps, would be intermittent duty, & need not be part of the continuous load calcs. Comm would have some very low consumption (likely under an amp) except when transmitting. etc etc
Be aware that many (most?) devices spec a circuit protection device that's a lot larger than continuous draw, and somewhat larger than even peak inrush current. In some cases, you might need to actually power up the device to determine its actual continuous & peak draw; some mfgrs don't bother to include that data.
airknot
Posted: Mon Aug 17, 2020 11:49 am Post subject: Re: RV10 primary elec sys wiring |
| toaster73(at)embarqmail.c wrote: | There are some nice schematics for the RV-14 or RV-12 that certainly can help you visualize what you may want for the RV-10. GO to this link:
-Chris
Thank you, Chris, those wiring schemes are great, but unfortunately they use plenty of some Power Circuit Boards (perheps supplied by VANS with kits).. but plan to use some elemets in avionics hookup
airknot
Posted: Mon Aug 17, 2020 11:58 am Post subject: Re: RV10 primary elec sys wiring |
[/quote]What's missing from your loads list above? I only see about 20A, absolutely worst case, in that list (unless that Dynon stuff is hideously inefficient). Have you done a spreadsheet, or even just a list, with every load item with columns showing continuous and peak loads for each device, and if applicable, an intermittent duty column? For example, the Slickstart, and flaps, would be intermittent duty, & need not be part of the continuous load calcs. Comm would have some very low consumption (likely under an amp) except when transmitting. etc etc
Charlie[/quote]
Charlie, I have made separate ELA doc, perheps it is some problems with viewing. now it has 2 main columns - "Typical" and "Max" load. PLease, have a quick look:
https://drive.google.com/file/d/19XBHeM0oGqIDpQcepn1XrqFzVvEpWZq6/view?usp=sharing
Posted: Mon Aug 17, 2020 12:29 pm Post subject: RV10 primary elec sys wiring |
Charlie[/quote]
[/quote]
Google says we need permission to see it; sent the request.
Joined: 28 Mar 2008 Posts: 1944 Location: Riley TWP Michigan
Posted: Mon Aug 17, 2020 3:27 pm Post subject: Re: RV10 primary elec sys wiring |
Nobody can access google drive documents without the owner's permission.
_________________ Joe Gores |
Posted: Mon Aug 17, 2020 5:46 pm Post subject: RV10 primary elec sys wiring |
Thoughtfully crafted electrical systems do not suffer
emergencies . . .
3 – backup smart battery (TCW IBBS-12V-6AH) – max cont loadoad 8 A, intermittent 12 A
Engine: Lycoming IO-540-D4A5 |
With that engine, why are you including a backup
battery? A 8-10A standby alternator on a vacuum
pump pad offers UNLIMITED endurance with about
a 4 pound penalty. I go out of my way to avoid
adding batteries to a design over and above
those normally expected to start engines and
back up the primary alternator.
Do you not PLAN to conduct periodic airworthiness
checks on the main battery?
airknot
airknot
Posted: Mon Aug 17, 2020 11:00 pm Post subject: Re: RV10 primary elec sys wiring |
[/quote]
emergencies . . .
Bob . . .[/quote]
I mean loss of primary alternator
Alex
airknot
Posted: Mon Aug 17, 2020 11:43 pm Post subject: Re: RV10 primary elec sys wiring |
| nuckolls.bob(at)aeroelect wrote: | | Quote: |
3 ďż˝ backup smart battery (TCW IBBS-12V-6AH) ďż˝ max cont loadoad 8 A, intermittent 12 A
Bob . . . |
I feel the same, even more - i prefer independent buses which a powered from different power sources plus 2 batteries. as commercial airplanes constructed...
but, unfortunately, I was asked to help built Airplane with equipment already purchased...of course I can ask for changes ..
Engine is electrically independent -
and my idea was 2 or 3 buses, to construct reliable, redundant but simple system using all I have:
-Main bus powered from alternator
-Battery bus (so called switched hot battery bus - to avoid battery drain in case of always hot battery bus), but it have to be powered not from battery under normal conditions - so only main bus available
-Essential bus that might be normally powered from the Main bus (thru IBBS battery) and in case of main bus power loss - power from IBBS baterry itself.
Initial idea was to power VHF transciver with its audio control panel.
Another point is to protect equipment during engine start:
For engine start we need 1 Skyview monitor with its periphery operating
Top important question - battery maintenance.
Scheduled servicing will be performed - we will install BatteryMInder charger for Main battery and will charge IBBS with its charger (separate unit recommended by TCW).
Due to lack of time - guys want fly asap - we will do not install Ground power subsystem now, but for sure will schedule this upgrade in winter time.
Alex
Posted: Tue Aug 18, 2020 3:37 am Post subject: Re: RV10 primary elec sys wiring |
| Quote: | Essential bus that might be normally powered from the Main bus
(thru IBBS battery) and in case of main bus power loss - power from IBBS baterry itself. |
I do not like the fact that the output of the IBBS battery is protected by one
10 amp fuse. If that fuse blows, everything down steam loses power.
I would not power an essential bus through that backup battery.
The cure is worse than the disease.
airknot
Posted: Tue Aug 18, 2020 3:43 am Post subject: Re: RV10 primary elec sys wiring |
Agree, thank you. i wrote silly thing. Bob told that Avionics switch is unnecessary nowadays.
just think about the most wise and safest way of using equipment available.
Posted: Tue Aug 18, 2020 8:02 am Post subject: RV10 primary elec sys wiring |
My apologies - i was sure it is accessable for averyone with the link.
I have double-checked and gave rights to edit:
ELA - https://drive.google.com/file/d/19XBHeM0oGqIDpQcepn1XrqFzVvEpWZq6/view?usp=sharing
Equipment list, source analisys
thank you
Alex
OK, got it. 1st thing I noticed is that you didn't totalize current for
[/quote]
the various phases of flight. Even without looking there, your 'typical'
consumption for everything is only 36 A. I'd look at cruise, with pitot
heat and boost pump included for worst case numbers. Re-examine what
you've included for each phase of flight. ex: Looks like you show 1 A
for the flap motor, for all phases of flight. Also, look carefully at
recommended circuit protection values for each device. ex: Even though
the flap motor may only consume 5 A, IIRC, the docs for it recommend
closer to 15 A for circuit protection due to startup surge.
I suspect that the number for the boost pump number is a bit low. The
automotive injection pumps typically used in a/c boost pumps typically
draw a *minimum* of around 4.5A; most will draw closer to 6A. That draw
doesn't really change with engine power, since they pump the same
quantity of fuel at the same pressure, regardless of flow to the engine
(excess is bypassed back to the inlet). The Walbro pumps (not the one
used by AFP) recommend a 20A circuit protection, due to startup surge
current.
I didn't do a line-by-line analysis, so you can probably find more power
savings.
