Posted: Sun Aug 16, 2020 1:44 pm Post subject: headset crackle |
I would be grateful for any ideas on the following:
I have a rotax with a Z16. It has 250 hours from new.
My dynon skyview has been completely RF silent up today when during the flight i had quite a significant crackle that rose and fell with RPM. The crackle was lower at lower rpm. Once back on the ground i discovered that the crackle went when I switch off one mag. And when I switched off mag the other the engine coughed as if with intermittent spark.
I have recently fitted a new prop and took the top plugs out to facilitate rotation of the prop but otherwise i have not fiddled with the ignition system.
I am assume that i have some kind of issue with the HT system.
I have been advised that rotax ignition modules rarely suffer intermittent faults - is this correct?
I have also been advised to examine the Plug caps and "renew" the connection between HT lead and plug cap cutting off 1/8 of the HT lead.
Does anyone have any other suggestions?
Will
Peter(at)sportingaero.com Guest
Posted: Sun Aug 16, 2020 2:02 pm Post subject: headset crackle |
Check your headset sockets are tight and have the insulation washers fitted.
Peter
Will
user9253
Joined: 28 Mar 2008 Posts: 1939 Location: Riley TWP Michigan
Posted: Sun Aug 16, 2020 4:01 pm Post subject: Re: headset crackle |
Try new spark plugs?
_________________ Joe Gores |
Posted: Sun Aug 16, 2020 5:49 pm Post subject: headset crackle |
Yes Joe thats a good ideaThanks
William Daniell
+1 786 878 0246
On Sun, Aug 16, 2020, 20:07 user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Joe Gores
http://forums.matronics.com/viewtopic.php?p=497787#497787
Electric-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
FORUMS -
eferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer" target="_blank">http://wiki.matronics.com
b Site -
-Matt Dralle, List Admin.
rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution
Posted: Mon Aug 17, 2020 8:45 am Post subject: headset crackle |
Mmm not sure....before there was no crackle with the audio and the audio system is unchanged.
The plane is composite and the jacks are isolated. But ill check that. Its an easy task.
William Daniell
+1 786 878 0246
On Sun, Aug 16, 2020, 18:06 Peter Pengilly <Peter(at)sportingaero.com (Peter(at)sportingaero.com)> wrote:
Peter
Will
