david(at)carter.net Guest
Posted: Mon Jun 08, 2020 10:41 am Post subject: Z101 main alt wiring |
Tracing the main alt field circuit from the main bus, I see the following wire sizes:
- 16 AWG fusible link
- 12 AWG wire to 5A breaker & then to power master switch
- 20 AWG wire to regulator
- 20 AWG wire to alternator field
I don't understand the need for the 12 AWG wire feeding the master, which has only 20 AWG coming out of it to the load.
David
David Carter
david(at)carter.net (david(at)carter.net)
ceengland7(at)gmail.com Guest
Posted: Mon Jun 08, 2020 11:26 am Post subject: Z101 main alt wiring |
On Mon, Jun 8, 2020 at 1:47 PM David Carter <david(at)carter.net (david(at)carter.net)> wrote:
| Quote: | Bob,
David
David Carter
Reasonable question; might have been driven by 'off-the-shelf' fusible link size availability. 22awg (minimum reasonable size to work with) link (sleeved with silicone tubing) to 18awg would get the job done. 20awg after the breaker because the breaker protects it.
I've tested the silicone tubing trick on 22awg with a direct short on a 12v tractor battery. The wire vaporizes, leaving a smoky interior lining on the clear silicone tubing, but the tubing contained the 'event'.
216.85 KB |
6097 Time(s) |
268.96 KB |
6097 Time(s) |
242.5 KB |
6097 Time(s) |
Posted: Wed Jun 10, 2020 6:30 am Post subject: Z101 main alt wiring |
Charlie,
Thanks for the response. What type of silicone tubing do you use for this?
David
David Carter
On Mon, Jun 8, 2020 at 3:30 PM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
| Quote: | Bob,
David
David Carter
Posted: Wed Jun 10, 2020 7:17 am Post subject: Z101 main alt wiring |
On 6/10/2020 9:26 AM, David Carter wrote:
| Quote: | Charlie,
David
David Carter
| Quote: | Bob,
David
David Carter
| Hi David,
I don't even remember the source; probably ebay or Amazon. I just bought clear 'food grade' silicone tubing in an assortment of diameters.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313.TR9.TRC1.A0.H0.Xsilicone+tubing+.TRS2&_nkw=silicone+tubing+&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=silicone+tubing+assortment
Posted: Wed Jun 10, 2020 10:07 am Post subject: Z101 main alt wiring |
Charlie |
Those sizes are still 'in work' . . . 20AWG is the smallest
commericial-off-the-shelf (COTS) fusible link wire I've found . . .
and is just fine when extended with 16AWG wire.
There is no benefit in 'fine tuning' fusible link
sizes. I'm thinking we're going to find that the range
of COTS wires will cover all our needs. I'd guess that
99.9% of all breakers and fuses installed in vehicles go
to the scrap yard never having been called upon to do
their job.
Fusible links are probably an order of magnitude
LESS likely to be 'faulted' into service.
Z101 and 102 suggest some FLW as jumpers between
contactors/relays . . . I've been pondering these
choices and have just about concluded that making
those jumpers short, robust and mechanically
protected is all that's practical and useful.
Posted: Wed Jun 10, 2020 10:41 am Post subject: Z101 main alt wiring |
B&C sells fusible link kits that include
a silicone over fiberglas sleeving to
coral the destruction products of what
ever wire you want to run inside.
https://tinyurl.com/ya2nzddh
You can acquire silicon/fiberglas sleeving
in various sizes/lengths here
https://tinyurl.com/ybwnk7md
Posted: Wed Jun 10, 2020 11:58 am Post subject: Z101 main alt wiring |
On Wed, Jun 10, 2020 at 1:12 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] | Quote: |
Charlie |
Posted: Wed Jun 10, 2020 12:01 pm Post subject: Z101 main alt wiring |
On Wed, Jun 10, 2020 at 2:10 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
I wish I'd been able to find that when I fab'd mine, but it's been a while. Pretty sure it wasn't available back then. Pure silicone is 'good enough', but the Fglas stuff there is no more expensive, so I'll go there for future work. Thanks for the link!
