cheapo 24 -> 12V dc-dc converters
Colyn Case
PostPosted: Thu May 28, 2020 8:07 am    Post subject: cheapo 24 -> 12V dc-dc converters Reply with quote
I have a 28V aircraft with a few critical items that run on 12V. I previously used a Vicor VI-M11-ES but it became damaged and that model is no longer available.
What Vicor has available are mini-packs which require building up your own circuit board and heat sinks. cost is $400 and several days of work for me.
So I found this thing on the net. data sheet attached. for $22. Includes heatsink, leads etc. The worst thing I could find about it is .140V ripple. but that beats the Vicor spec.
Any reason I shouldn't just use this thing?
daygreen 24V to 12V 20A 240W.pdf
 Filename:  daygreen 24V to 12V 20A 240W.pdf
 Filesize:  768.18 KB
 Downloaded:  440 Time(s)
Colyn Case
colyncase@earthlink.net
PostPosted: Thu May 28, 2020 9:32 am    Post subject: Re: cheapo 24 -> 12V dc-dc converters Reply with quote
You might also consider a converter with 13.8 volt output which is closer to an aircraft
electrical system voltage with the alternator operating.
https://www.daygreen.com/collections/24v-to-12v-13-8v/products/24v-to-13-8v-20a-276w-dc-dc-step-down-converter-voltage-regulator
The AC ripple from an alternator is probably worse than a converter.
eBay has one for $17.50, free shipping from CA eBay item number:332791865341
Joe Gores
Colyn Case
PostPosted: Thu May 28, 2020 1:35 pm    Post subject: Re: cheapo 24 -> 12V dc-dc converters Reply with quote
Joe, thanks for the link.
In this case I actually do want 12V but interesting to get another data point on day-green.
Colyn Case
