Engine Mount / Axle Placement
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List
Rcaprd(at)aol.com
PostPosted: Mon Jul 24, 2006 2:43 pm    Post subject: Engine Mount / Axle Placement Reply with quote
While everyone is off having a great time, I've been here hammering out my Tailwind, and I have a few questions:
I extended the forward bay 2" for more leg room, and more fuel.  Tailwind Times #1 says place the axles 8" behind the firewall.
I think the axle placement should be right below the leading edge of the wind, so with the firewall extension, should I place the axles 10" behind the firewall ?
Should I build the engine mount 0º  and 0º, or should I have a little down thrust, and a little right thrust, and how much ?
The plans for the tailwheel show the wrap around piece that supports the tailwheel axle, to be .090".  I think Jim C. makes it in two pieces, and welds it down the forward part, as well as on the inside, then puts the top gusset on.  In my notes, someone suggested using .100" for this.  I have enough .090" to complete the tailwheel, but I haven't got any .100".  Should I order some .100" ?
Chuck Gantzer
Wichita, KS
Pietenpol NX770CG
- The Matronics Tailwind-List Email Forum -
http://www.matronics.com/Navigator?Tailwind-List
jerryhey(at)earthlink.net
PostPosted: Mon Jul 24, 2006 3:02 pm    Post subject: Engine Mount / Axle Placement Reply with quote
Chuck, I believe you should maintain the 8 inch trail measured from
the firewall. regards, Jerry
100" ?
Chuck Gantzer
Wichita, KS
Pietenpol NX770CG
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List All times are GMT - 8 Hours
