Super-whizzy energy management systems
PostPosted: Tue Apr 28, 2020 10:45 am    Post subject: Super-whizzy energy management systems Reply with quote
I just became aware of an incident involving
complete loss of power from an electrically
dependent engine that occurred some years ago.
The accident airplane had a lot in common
with the narrative we have going with Ron.
I've posted a copy of a narrative at
https://tinyurl.com/y7xksy6v
While this narrative has a lot more data
than most 'dark-n-scarry-nite' stories
in the journals, it is still short of
critical information necessary to
ferret out root cause.
Fortunately, the pilot walked away. I'll
suggest this is a classic example of a system
that was too complex, would not yield to
a critical FMEA and may have suffered some
deficiencies in craftsmanship.
I'll let you guys read this thing first and
come up with questions one might ask if
you were on an accident investigation team.
ceengland7(at)gmail.com
PostPosted: Tue Apr 28, 2020 11:47 am    Post subject: Super-whizzy energy management systems Reply with quote
On Tue, Apr 28, 2020 at 1:50 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
[snipped]
My 1st question is whether that alternator ground wire was the only connection between the engine and the airframe, as seems likely.
PostPosted: Tue Apr 28, 2020 1:17 pm    Post subject: Super-whizzy energy management systems Reply with quote
Good one. Let's put that one on the table.
PostPosted: Tue Apr 28, 2020 4:26 pm    Post subject: Re: Super-whizzy energy management systems Reply with quote
It seems that the engine quit because the electrical system voltage was too
high which damaged critical engine components, despite what the
manufacturer of the fuel injection and ignition systems stated.
Factors that led to the high voltage include a poorly crimped cable, omission
of an alternator on-off switch, lack of alternator over-voltage protection, and
batteries that stop accepting charging current in case of high voltage, which
allowed the voltage to climb even higher.
Joe Gores
johnbright
PostPosted: Tue Apr 28, 2020 5:30 pm    Post subject: Re: Super-whizzy energy management systems Reply with quote
Did the alternator's integral regulator have overvoltage protection? Did it trip? What is it's trip voltage?
Were there any blown fuses or tripped circuit breakers supplying power to the ECUs or coilpacks?
What in the ignition system failed? ECUs? Coilpacks? Were they bench tested post accident? How do we know the ignitions systems failed?
What is the sample rate of the EMS? Could it miss a short spike in voltage that would destroy the ECU or coilpacks?
Is it possible for ECU programming to be affected by voltage transients such as from the loose alternator crimp?
Were there any other bad connections in the aircraft besides the alternator ground wire?
Is there a complete electrial power schematic for the aircraft? Does it match the implementation?
Was the alternator ground wire the only ground for the engine? Did the coilpacks require the engine to be grounded for them to receive power?
John Bright, RV-6A
Single battery, wound-field alternator on main bus, MZ-30 PM generator on engine/essential bus.
N1921R links
chaskuss(at)yahoo.com
PostPosted: Tue Apr 28, 2020 5:40 pm    Post subject: Super-whizzy energy management systems Reply with quote
The pilot had an overcharge condition. Did his system have an over voltage warning system? The pilot's failure to install a breaker/switch for the alternator, left him with no way to disconnect the alternator. No other provisions are provided in his design to deal with an over voltage event. According to the supplied schematic, that would be his only option for protecting the batteries and making a safe continuation of the flight. Due to the design of the "Bus Manager" a [open circuit] failure of the internal diodes could leave the emergency power switch all but useless. Further, the pilot's choice of two LiFe batteries, left him with less of an electrical "sponge" to absorb the over voltage event, compared to using at least 1 flooded cell or AGM battery.
To me, both the pilot and the company who supplied the "bus manager" failed at making a safe system. The changes the pilot made, surely fall under the "major change" category. That would have required the pilot to make 5 hours of test flights in the vicinity of his home airport. Had this been done, most likely, he would have made it back to the runway safely.
Charlie Kuss
On Tuesday, 28 April 2020, 17:05:14 GMT-4, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
<= the many List utilities such as List Un/Subscription,
http://forums.matronics.com
http://www.matronics.com/contribution[/url]
kenryan
PostPosted: Tue Apr 28, 2020 5:56 pm    Post subject: Super-whizzy energy management systems Reply with quote
16.3 volts just does not seem very high. It is hard to accept that 16.3 volts would fry these products, which seem to come from reputable vendors (SDS and FlyEFII).
On Tue, Apr 28, 2020 at 4:50 PM user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=496100#496100
gilles(at)elixir-aircraft
PostPosted: Tue Apr 28, 2020 6:48 pm    Post subject: Super-whizzy energy management systems Reply with quote
Was the alternator ground wire the only ground for the engine? Did the injectors or coilpacks require the engine to be grounded for them to receive power?
Hi all,
Found some schematic and installation instructions here :
https://www.flyefii.com/media/Bus_Manager_Installation_Instructions.pdf
Best regards,
Gilles
http://contrails.free.fr
http://lapierre.skunkworks.free.fr
finn.lassen(at)verizon.ne
PostPosted: Wed Apr 29, 2020 5:40 am    Post subject: Super-whizzy energy management systems Reply with quote
The ProTek schematic does not specify how the power to ignition switch
is supplied.
I don't see "Alternator charge isolation for two-battery system." That
appears manual - pilot should be able to switch off alternator -- wrong
circuit breaker.
"In this scenario, the battery does not disconnect but instead blocks
the excess current/voltage into the battery." Doesn't make sense.
Obviously the cause was the faulty alternator grounding.
Secondary cause was wrong circuit breaker (and no OV protection).
Possibly wrong wiring of power to ignition switch.
Not sure I would want batteries that automatically disconnects.
Finn
johnbright
PostPosted: Thu Apr 30, 2020 10:10 am    Post subject: Re: Super-whizzy energy management systems Reply with quote
gilles(at)elixir-aircraft wrote:
Found some schematic and installation instructions here:
... flyefii.com/media/Bus_Manager_Installation_Instructions.pdf
Best regards,
Gilles
EFII has an updated Bus Manager installation instruction. I have not studied it in detail but I see they eliminated one of the SPOFs in the fuel pump wiring, Dwg 3B.
https://www.flyefii.com/media/Bus-Manager-Installation-Instructions-1-6-20.pdf
John Bright, RV-6A
N1921R links
blues750
PostPosted: Thu Apr 30, 2020 10:13 am    Post subject: Re: Super-whizzy energy management systems Reply with quote
Great discussion so far...hits close to home as I have a similar configuration on my EAB though I have incorporated OVP and a disconnect from the PMA. Additionally, the two EarthX batteries I have (ETX Hundred Series) are of the more recent BMS design which does not cut off available battery energy to systems, but does limit the charging current and voltage to the battery if the battery start receiving too much. I think Mr Kuss brings up a valid point regarding failure of the internal diodes, though both diodes would have to fail to prevent either battery from providing power to the essential bus via the switch. I cannot say that the designer of the Bus Manager failed at making a "safe system" - how robust are the components? Is the design flawed? Obviously, highly interested in the overall discussion - but one of my first questions would be what EarthX battery Series did he have, then why no ALT disconnect.
PostPosted: Thu Apr 30, 2020 10:39 am    Post subject: Super-whizzy energy management systems Reply with quote
Hi all,
Personnally I would prefer a means of disconnecting the alternator(s)
from the ship, and wire the emergency power switch direct from the
backup battery.
BTW, maybe I'm missing the obvious, but what is the point of having two
batteries if they always connect and disconnect together, albeit through
some diode array (part-count counts) ?
Best regards,
Gilles
johnbright
PostPosted: Thu Apr 30, 2020 10:30 pm    Post subject: Re: Super-whizzy energy management systems Reply with quote
In case folks are not familiar with EFI+I systems I made the attached schematic. "Elec Schem Generic EFI+I 4 Cylinder rev A.pdf"
 Filename:  Elec Schem Generic EFI+I 4 Cylinder rev A.pdf
 Filesize:  380.74 KB
 Downloaded:  519 Time(s)
John Bright, RV-6A
N1921R links
bcone1381
PostPosted: Tue May 05, 2020 5:05 am    Post subject: Re: Super-whizzy energy management systems Reply with quote
[/quote]My 1st question is whether that alternator ground wire was the only connection between the engine and the airframe, as seems likely.
Charlie [/quote]
Throttle, mixture and prop cables will ground an engine. Its a mystery what other grounds existed.
Brooks Cone
Bearhawk Patrol Kit Build
PostPosted: Tue May 05, 2020 4:24 pm    Post subject: Super-whizzy energy management systems Reply with quote
On 5/5/2020 10:51 AM, Robert L. Nuckolls, III wrote:
At 08:06 AM 5/5/2020, you wrote:
--> AeroElectric-List message posted by: "bcone1381" <bcone1964(at)gmail.com> (bcone1964(at)gmail.com)
CharlieÂ
Throttle, mixture and prop cables will ground an engine.  Its a mystery what other grounds existed.[/quote]
  Yes . . . sort of . . . all those conductors
  are steel, long and terminate on various
  and widely separated mountings designed
  for mechanical integrity, not electrical
  conductivity.
  It is not uncommon for those 'ground paths'
  to suffer serious overheat events during
  engine cranking when a mechanic inadvertently
  fails to replace the crankcase-to-firewall
  bond strap during maintenance. This very
  event occurred on one of my rental airplanes
  back about 1990 but it was double grounded
  p-lead shields that smoked. This is why
  the z-figures show p-lead termination that
  is contrary to some legacy practice.
  A ground lead to an alternator case is
  not common practice. The crankcase-to-
  firewall ground strap is generally 2AWG
  equivalent or better and seeks good
  electrical conductivity at locations
  suited to that service.
  We don't know where the other end of
  the illustrated ground lead was terminated,
  nor do we know if it was in addition to
  another ground path. The overheating
  observed in the picture does suggest
  that the ground system on that engine
  was inadequate by design or compromised
  by error.
  I'm hoping to get back to our hip-pocket
  accident analysis but as participants
  will note, there are more questions
  than answers. Lacking a good schematic
  for how the airplane was wired, we'll
  never know how an engine became electrically
  starved (assuming that's true) while
  a data acquisition system RECORDED
  the presence of voltage in the system.
  This wasn't an electrical 'black out' . . .
  The alternator output went to zero
  but again, we're not privy to all the
  hardware between the alternator and
  the bus . . . the breaker was not open
  so something caused the alternator
  output to zero with what appears to
  be simultaneous engine failure.
  Bob . . . [/quote] To the 'control cables will ground the engine': In the early 1970s, I bought a brand new Fiat 128; the 1st commonly available front wheel drive econobox in the USA. At some point, the dealership had to do some work on it, and when I got it back, it would intermittently fail to 'turn over' well, as if the battery was going bad. I eventually quit driving it, having purchased a 124 (a lot more fun). When a potential buyer showed interest in it, I tried to get it running with a new battery mounted, and with the hood up, I noticed smoke under the hood while the starter was trying to turn. The car had a cable actuated clutch, and the clutch cable was trying to go up in smoke. Looked under the car, and the engine's ground strap was hanging loose on one end.
If the discoloration in the 'alternator ground' terminal really is due to poor termination-induced resistance heating, that's a strong indicator (to me, anyway) that it was the only ground *wire* connecting the engine to the airframe. I'd expect a properly sized ground wire attached anywhere else on the engine to carry effectively all the current, with the high resistance 'alternator ground' being ignored by the a/c.
The narrative of the engine shutting down *when the voltage climbed* but the rest of the a/c continued to see battery voltage after the alternator shut down really is....interesting.
The investigation does seem very typical of NTSB/FAA handling of experimental a/c incidents/accidents. The never have staff experienced with homebuilts (especially 'alternative' configurations), and very rarely even make an attempt to find competent, knowledgeable consultants.  There's also rarely an *objective* opinion sought. They frequently call on the mfgr of the device, a/c, etc that's in question for failure analysis. If I built the widget, am I likely to take responsibility for its failure in an accident?
johnbright
PostPosted: Tue May 05, 2020 5:01 pm    Post subject: Re: Super-whizzy energy management systems Reply with quote
Would/could the loose alternator/engine ground wire fool the regulator into raising the field current?
John Bright, RV-6A
N1921R links
