Yellow Panel
tonyrenshaw268(at)gmail.c
PostPosted: Wed Apr 29, 2020 4:21 am    Post subject: Yellow Panel Reply with quote
Gidday,
I have recently seen a yellow panelled Europa. Would someone know who’s aircraft it is please?
Tony Renshaw
Europa48
PostPosted: Wed Apr 29, 2020 4:51 am    Post subject: Re: Yellow Panel Reply with quote
Does this qualify as "Yellow"
 Filesize:  135.54 KB
 Viewed:  10283 Time(s)
SPURPURA
PostPosted: Wed Apr 29, 2020 12:18 pm    Post subject: Re: Yellow Panel Reply with quote
How about tan colored.
 Filesize:  261.76 KB
 Viewed:  10259 Time(s)
N951EU - Tri-gear & 912ULS, N77EU- Tri-gear & 914
I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY.
John Wighton
PostPosted: Wed Apr 29, 2020 11:39 pm    Post subject: Re: Yellow Panel Reply with quote
That will be the lesser known one legged, yellow panelled, short tail Europa, one of the finch family.
Smile
John Wighton
Europa XS trigear G-IPOD
John Kirkgaard
PostPosted: Thu Apr 30, 2020 4:58 am    Post subject: Re: Yellow Panel Reply with quote
I have purchased C-FIRS which have (had) a yellow panel
Awfull :-(
 Filesize:  231.04 KB
 Viewed:  10218 Time(s)
peterz(at)zutrasoft.com
PostPosted: Thu Apr 30, 2020 5:15 am    Post subject: Yellow Panel Reply with quote
Congrats!
Where is Carl’s plane now based?
Pete
C-GNPZ
classic mono #120
CYRP
On Apr 30, 2020, at 8:58 AM, John Kirkgaard <john.kirkegaard(at)gmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=496136#496136
http://forums.matronics.com//files/img_4499_136.jpg
John Kirkgaard
PostPosted: Thu Apr 30, 2020 5:45 am    Post subject: Re: Yellow Panel Reply with quote
Thanks.
Karls Europa is now in Denmark. After checking it I found that the wings had been damaged and needed to be repaired. (Wind had been 'repaired' by hiding the severe damage with filler and paint. Firewall was partly cut away - flaps tube were put together using plywood - I had to send the engine to Rotax Service Center to be taken apart and updated - wiring partly done by parts from DYI shop- and....
The Danish 'EAA' are very surprised to see what they can get along with in Canada. And will now change the rules for importing home-build from Canada.
But I will make it.. just need time and lot of $$$
PostPosted: Thu Apr 30, 2020 7:48 am    Post subject: Yellow Panel Reply with quote
Sorry to hear that it was such a disappointment.
Sadly, Carl’s bird flew under the regulator radar for a while it seems.
Definitely not representative of the normal, but I have seen many in the North american area (both certified and experimental) who operate their craft skirting the regs. Sad
On Apr 30, 2020, at 9:55 AM, John Kirkgaard <john.kirkegaard(at)gmail.com> wrote:
Thanks.
http://forums.matronics.com/viewtopic.php?p=496140#496140
