aspenbuild(at)me.com Guest
Posted: Tue Apr 14, 2020 12:43 am Post subject: Batteries |
A friend of mine in the motorcycle trade after looking at the Rotax charging system specified a 6.5kg lead acid. Two years later he suggested LiPo and after 7 years I’m now on my second one. It’s 800 grams and the first failed through age. LTX9-BS and €80 delivered through eBay. I initially had concerns over an early regulator failure but that’s still original after 10 years and 700 hours.
Fully flooded and VRLA batteries have their place but possibly not in an aircraft.
Richard S
G CEIW
brian.davies(at)clara.co. Guest
Posted: Tue Apr 14, 2020 2:40 am Post subject: Batteries |
LiPo batteries are great for cranking amps but it is worth double checking the capacity, particularly if you are flying an aircraft that relies on only electric pumps ( 914). The LTX9 has a capacity of only 3.6 AH.
Brian
Burrilla
Posted: Tue Apr 14, 2020 4:21 am Post subject: Batteries |
| Quote: | >LiPo batteries are great for cranking amps but it is worth double checking the capacity, particularly if you are flying an aircraft that relies on only electric pumps ( 914). The LTX9 has a capacity of only 3.6 AH.<<
When I fitted a a LiPro to my 912ULS Tri-gear, I worked through the static load i.e. Radio, GPS, Master Solenoid, Transponder…. and then dynamic load i.e. Radio Transmitting, trimmer and flap operation………. With a static load of 8 amps I have 2 hours of battery capability and can extend that if I close down transponder, put GPS on internal battery and other measures. In other words I can cross the channel and find an airfield to divert into.
If anyone is considering fitting a LiPro I recommend sitting down first and working out the electrical load factors first and then considering how much capacity your would need to divert should you loose an alternator. It's done for IFR capable aircraft as part of the design.
Fitting a LiPro is not all about weight saving and cranking capacity IMHO.
Alan Burrill
G-OBJT
[quote] On 14 Apr 2020, at 11:38, Brian Davies <brian.davies(at)clara.co.uk> wrote:
Brian
Olivier.hequet@neuf.fr
Posted: Tue Apr 14, 2020 4:35 am Post subject: Batteries |
Hello,
Just for information
I put a lipo battery in my Europa...for better results I change my regulator by a Silent Hektik. Like this: https://www.silent-hektik.de/UL_R_912.htm
Olivier
[quote]Le 14 avr. 2020 à 14:24, Alan Burrill <alanb(at)dpy01.co.uk> a écrit :
--> Europa-List message posted by: Alan Burrill <alanb(at)dpy01.co.uk>
| Quote: | | Quote: | LiPo batteries are great for cranking amps but it is worth double checking the capacity, particularly if you are flying an aircraft that relies on only electric pumps ( 914). The LTX9 has a capacity of only 3.6 AH.<<
Alan Burrill
G-OBJT
[quote]On 14 Apr 2020, at 11:38, Brian Davies <brian.davies(at)clara.co.uk> wrote:
--> Europa-List message posted by: "Brian Davies" <brian.davies(at)clara.co.uk>
Brian
churchy
Posted: Tue Apr 14, 2020 5:55 am Post subject: Batteries |
Unfortunately, Silent Hektik refuses to sell their items to UK residents. Perhaps a reaction to Brexit - But they didn’t give me an explanation!
Richard C-C
[quote] On 14 Apr 2020, at 13:34, "olivier.hequet(at)neuf.fr" <olivier.hequet(at)neuf.fr> wrote:
Hello,
Olivier
h&jeuropa
Posted: Tue Apr 14, 2020 7:42 am Post subject: Re: Batteries |
We have been using a EarthX lithium battery (ETX 680C) for several years. I wrote an article for the Europa Flyer (EF82) concerning it. We load test it each inspection and it will maintain rated voltage with a load of 10 amps for over an hour. One feature of lithium batteries is that the voltage does not decay as the battery discharges. It stays pretty constant but then falls off quickly.
We replaced the Ducatti regulator with one Jim built. A RV12 owner and electrical engineer who researched many Ducatti failures developed this replacement. It is essentially a clone of the Ducatti but with high quality components and much larger heat sinks. Documentation and PC boards are available and the cost is roughly $70.
B and C Aero now has a replacement for the Ducatti called AVC-1. The link to the specifications is https://bandc.com/wp-content/uploads/2020/03/AVC1_Technical_Manual_RevIR_3-11-20.pdf
While not listed on their website yet, I believe the cost is $275.
We have always had our battery located on top of the foot well, even when we had a lead acid battery. We really wanted to avoid long, heavy cable runs. There are some loading situations where the CG is too far forward but we just use a couple 1 gallon containers filled with water located in the rear for those flights.
Jim & Heather
gilles(at)elixir-aircraft Guest
Posted: Tue Apr 14, 2020 11:49 am Post subject: Batteries |
Le 14/04/2020 à 15:53, Richard Churchill-Coleman a écrit :
| Quote: | Unfortunately, Silent Hektik refuses to sell their items to UK residents. Perhaps a reaction to Brexit - But they didn’t give me an explanation!
Hi Richard,
My building buddy has a Silent Hektik for sale. He might be willing to send it to you (regardless of Brexit or else .
Sorry, only picture I have :
[img]cid:part1.18ECAFFF.A40B68BC(at)elixir-aircraft.com[/img]
If interested, do not hesitate to pm me.
FWIW
Best regards,
Gilles
http://contrails.free.fr
http://lapierre.skunkworks.free.fr
236.36 KB |
12756 Time(s) |
rowlandcarson(at)gmail.co Guest
Posted: Mon Apr 27, 2020 12:43 am Post subject: Batteries |
On 2020-04-14, at 14:53, Richard Churchill-Coleman <richard.churchill-coleman(at)sky.com> wrote:
Richard - sorry for late response - your message got stuck in spam. I had no problem purchasing the GR6 from Herr Schicke for delivery to Cheltenham UK, but that was back in 2012. He sent me a pro-forma invoice by e-mail and I paid by Swift bank transfer. Perhaps something has changed in the last few years.
in friendship
Rowland
rparigoris
Posted: Mon Apr 27, 2020 2:01 am Post subject: Re: Batteries |
Hi Group A bit confused after reading this thread. Is someone really using a LiPo battery on an aircraft you fly in? I'm assuming LiPo you mean Lithium Polymer battery. They have one of the best energy densities around and can dump amps like crazy if designed to do. They have a better Energy Density than Lithium Ion. That said they are also incredibly dangerous. Far worst than Lithium Ion. Great stuff for models and if you charge them somewhere that when they catch fire and you have a big bag of sand in a plastic bag over them so they don't burn down your house or whatever else they are near. It's not unheard of for model guys to lose their car by recharging inside them.
Anyway is someone with a Europa really flying with LiPo??
I never heard of a LiPro, what is that?
Earth-X batteries are LiFePO4 Lithium Iron Phosphate. It's a fairly safe Lithium technology, I think Earth-X has their act together as far as making it aeroplane friendly with their balancing, protection and shut down. They have a worst energy density compared to Lithium Ion Batteries but safer.
I agree that when using batteries that can dump amps and are light weight, just because they can start your motor, their capacity may be very limited. Another thing is to consider is just because a battery Mfg. lists a specification does not mean for one thing that it's true and another if they give you a capacity when discharge at 1/20thC, in other words whatever capacity the battery is you discharge it over a 20 hour period, it will not be the same as draining the battery over an hour or two. Same goes for 1/10C. If you are relying on the battery to provide power in the event of a charging failure, you really must do an actual test. Figures don't lie, but liars sure do figure! Ron Parigoris
Burrilla
Posted: Mon Apr 27, 2020 2:33 am Post subject: Batteries |
| Quote: | >Anyway is someone with a Europa really flying with LiPo??
I never heard of a LiPro, what is that?<<
In the UK the LAA Technical leaflet 3.26 which refers to Standard Modification SM14337 - Lithium Iron Phosphate Batteries LiFePO are the approved standard for use in LAA aircraft,. I use one in mine and I believe several others do.
What others are using outside of UK I couldn’t say. Maybe people are confusing terminology.
Alan
| Quote: | On 27 Apr 2020, at 11:02, rparigoris <rparigor(at)hotmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=496060#496060
Posted: Mon Apr 27, 2020 3:01 am Post subject: Batteries |
Ron, I’m going to pm you later, current at work, Richard
Posted: Mon Apr 27, 2020 6:15 am Post subject: Batteries |
No confusion Alan, just a good old typing without my glasses on. Battery is indeed a LiFePO4 sent from Germany for €80 with the last one lasting five years.
Richard
| Quote: | On 27 Apr 2020, at 11:31, Alan Burrill <alanb(at)dpy01.co.uk> wrote:
Alan
