Curiosity Re: Master Switch
bcone1381
PostPosted: Thu Apr 09, 2020 8:00 am    Post subject: Curiosity Re: Master Switch Reply with quote
In the Aeroelectric Connection Book has notes on Master Switches. (age Z11, Note 22) I'm curious, if an engine of not running, and the field switch to the alternator is on, how much draw is there?
It seems to me like the bus is at 12V, and the Regulator sees 12V and wont be satisfied until the bus is at 14V, but the regulator does not see that the engine is not running and the alternator is not turning so I would think it want to open up its throttle to wide open to try to get 14 V. And so it seems to me like there would be a rather large draw.
I don't think me logic is right. School me.
Brooks Cone
Bearhawk Patrol Kit Build
Dave Saylor
PostPosted: Thu Apr 09, 2020 8:34 am    Post subject: Curiosity Re: Master Switch Reply with quote
My PlanePower alternator tries its best to make voltage with the engine stopped.  It pumps enough current through the field to make the alternator case hot enough to blister my fingers.  Literally.  But without any mechanical input, of course the output just stays at battery voltage.
The draw isn't enough to pop the 5A field circuit breaker.  But the case does get pretty hot.  I'm sure the lack of cooling air is a factor as well.
--Dave
On Thu, Apr 9, 2020 at 9:09 AM bcone1381 <bcone1964(at)gmail.com (bcone1964(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: "bcone1381" <bcone1964(at)gmail.com (bcone1964(at)gmail.com)>
Brooks Cone
http://forums.matronics.com/viewtopic.php?p=495725#495725
--Dave
KWVI
cluros(at)gmail.com
PostPosted: Thu Apr 09, 2020 8:38 am    Post subject: Curiosity Re: Master Switch Reply with quote
Here is a graph of a typical shutdown. You can see the draw from the battery go from about 10.5 to 9 when the alternator switch is selected off after shutdown. We have seen the alternator field draw as much as 3A and the builder noted that the alternator itself gets very hot if left on for a while with the engine not running. For this reason we don't turn the alternator on until after engine start and turn it off right after shutdown.
Brooks Cone
 Filesize:  364.49 KB
 Viewed:  6955 Time(s)
PostPosted: Thu Apr 09, 2020 10:01 am    Post subject: Curiosity Re: Master Switch Reply with quote
At 11:00 AM 4/9/2020, you wrote:
--> AeroElectric-List message posted by: "bcone1381" <bcone1964(at)gmail.com>
2-3 amps
your analysis is correct. The regulator
will go to full-bore which connects the
field (~4 ohms) to the battery.
This is the reason for a progressive transfer
DC master switch . . . it lets you power
up battery-only while leaving the alternator
off. This reduces battery loads for ground
ops. It also reduces potential for damage
to field windings being fully excited without
benefit of cooling air.
In operation, field current will be on the
order of 1 amp.
PostPosted: Thu Apr 09, 2020 10:05 am    Post subject: Curiosity Re: Master Switch Reply with quote
Correct. If you don't have a split rocker or
progressive transfer toggle switch for the
master, then it's advisable to pull the
field breaker for ground ops.
Some of the z-figures used to suggest
a simpler, easier to acquire, DPST
master switch COMBINED with a pullable
field breaker.
