Two coms mic switching
cofford
PostPosted: Wed Mar 11, 2020 3:29 pm    Post subject: Two coms mic switching Reply with quote
Hello all,
I'm sure this has been answered before, but I'm planning to use two com radios without an audio panel, so I need to switch the mic input. My current plan is to use two PTT switches on the stick, and tie the COM 2 PTT to a relay to switch the mic automatically. Does only the "MIC HIGH" side need to be switched, or do I need to switch the "MIC LO" side as well? I think "MIC LO" is just a ground reference for the mic input, but I'm looking for the lowest noise solution.
Casey
 Filesize:  37.75 KB
 Viewed:  9093 Time(s)
alec(at)alecmyers.com
PostPosted: Thu Mar 12, 2020 4:01 am    Post subject: Two coms mic switching Reply with quote
I don’t think you need to switch either side. Run the mic in parallel into both radios, and allow the appropriate PTT to select which transmits.
On Mar 11, 2020, at 19:31, cofford <cofford(at)gmail.com> wrote:
Hello all,
I'm sure this has been answered before, but I'm planning to use two com radios without an audio panel, so I need to switch the mic input. My current plan is to use two PTT switches on the stick, and tie the COM 2 PTT to a relay to switch the mic automatically. Does only the "MIC HIGH" side need to be switched, or do I need to switch the "MIC LOW" side as well? I think "MIC LOW" is just a ground reference for the mic input, but I'm looking for the lowest noise solution.
Casey
http://forums.matronics.com/viewtopic.php?p=495242#495242
PostPosted: Thu Mar 12, 2020 7:34 am    Post subject: Two coms mic switching Reply with quote
At 06:59 AM 3/12/2020, you wrote:
--> AeroElectric-List message posted by: Alec Myers <alec(at)alecmyers.com>
--> AeroElectric-List message posted by: "cofford" <cofford(at)gmail.com>
Hello all,
A DPDT switch routes PTT and MI HI to each radio
independently. An example of this is shown in
Figure 18-11 of the 'Connection
http://www.aeroelectric.com/Books/Connection/18_Audio.pdf
cofford
PostPosted: Thu Mar 12, 2020 9:27 am    Post subject: Re: Two coms mic switching Reply with quote
--> AeroElectric-List message posted by: Alec Myers <alec>
> On Mar 11, 2020, at 19:31, cofford <cofford> wrote:
--> AeroElectric-List message posted by: "cofford" <cofford>
Hello all,
Thanks for the answers. Not switching at all would cause an impedance mismatch in my case as both radios have a built-in intercom so the mic input would always be live. Sounds like switching the MIC HI line is the way to go.
PostPosted: Thu Mar 12, 2020 9:44 am    Post subject: Two coms mic switching Reply with quote
I’m pretty sure microphones aren’t impedance matched; a mic input is a high impedance input and the mic is (?) 600 ohms, so running one into two inputs doesn’t load the source.
>>> On Mar 11, 2020, at 19:31, cofford wrote:
>> Hello all,
> Bob . . .
http://forums.matronics.com/viewtopic.php?p=495264#495264
ceengland7(at)gmail.com
PostPosted: Thu Mar 12, 2020 10:15 am    Post subject: Two coms mic switching Reply with quote
That's kinda like adult diapers. (It Depends.)
Most audio circuits are a low impedance feeding a high impedance, but
you can't assume it's true in every case. You may well find high gain
inputs that have their load impedance intentionally kept low, to reduce
noise susceptibility when there's no source connected.
>>> Hello all,
>> Bob . . .
PostPosted: Thu Mar 12, 2020 10:36 am    Post subject: Two coms mic switching Reply with quote
I know. The nerdy part of me really really really wants to try it, to see if it works.
On Mar 12, 2020, at 2:10 PM, Charlie England <ceengland7(at)gmail.com> wrote:
Most audio circuits are a low impedance feeding a high impedance, but you can't assume it's true in every case. You may well find high gain inputs that have their load impedance intentionally kept low, to reduce noise susceptibility when there's no source connected.
>>> Hello all,
>> Bob . . .
trigo(at)mail.telepac.pt
PostPosted: Thu Mar 12, 2020 10:37 am    Post subject: Two coms mic switching Reply with quote
It’s kinda cool to assist these technically intrincated discussions 😉
Enviado do meu iPhone
No dia 12/03/2020, às 18:22, Charlie England <ceengland7(at)gmail.com> escreveu:
> Sent from my iPhone
>>>> Hello all,
>>> Bob . . .
PostPosted: Thu Mar 12, 2020 1:04 pm    Post subject: Two coms mic switching Reply with quote
Keep in mind that the MIC HI input to an intercom
or transmitter is designed to interface with a
powered, amplified microphone. This is a legacy
hold-over from the days when aircraft microphones
were not unlike those in your telephone . . .
carbon granules behind a foil diaphragm.
https://tinyurl.com/htnn6nq
This microphone is essentially a resistor whose
resistance varies with audio stimulation. Hence
it must first be biased up with some current
so that the electronics can tap the resulting
voltage variances that represent speech.
Here's an exemplar MIC input circuit for a
King transceiver . . .
[img]cid:.0[/img]
Looking into the DC power path, the DC source
impedance is on the order of 600 ohms, the AC
load impedance is on the order of 390 ohms
while the load impedance of the first audio
stage is about 48,000 ohms.
So while the voltage INPUT network may indeed
be 'high' impedance, the microphone BIAS network
is not. Further, paralleling two such inputs
doubles the bias to any one microphone.
The using DPDT "TX SELECT" switch for PTT and
MIC HI lines is pretty much mandatory.
 Filesize:  52.7 KB
 Viewed:  9065 Time(s)
 Filesize:  55.58 KB
