Fuel tank vents
Ken worth
PostPosted: Sat Mar 07, 2020 4:52 pm    Post subject: Fuel tank vents Reply with quote
Hoping the group.can help me with suggestions on how to properly vent the tanks. I plan to T them together & connect to the filler cap.
 Filesize:  66.86 KB
 Viewed:  13440 Time(s)
 Filesize:  66.86 KB
Ken worth
MK3 Classic
Ken worth
PostPosted: Sat Mar 07, 2020 4:57 pm    Post subject: Re: Fuel tank vents Reply with quote
The filler cap.
 Filesize:  79.9 KB
 Viewed:  13435 Time(s)
Ken worth
MK3 Classic
Richard Pike
PostPosted: Sun Mar 08, 2020 3:56 am    Post subject: Re: Fuel tank vents Reply with quote
Can you post a picture of how the system fits together? I am not picturing it in my head.
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Ken worth
PostPosted: Sun Mar 08, 2020 6:10 pm    Post subject: Re: Fuel tank vents Reply with quote
Richard,
Both fittings will be reduced down & joined to a “T” fitting.
I was uncertain of the vent cap / termination methods.
suggestions welcome.
Thank you
 Filesize:  1.14 MB
 Viewed:  13394 Time(s)
Ken worth
MK3 Classic
Richard Pike
PostPosted: Tue Mar 10, 2020 4:42 pm    Post subject: Re: Fuel tank vents Reply with quote
I hate to seem persistently dumb, but can you post a schematic, a detailed explanation, or a picture that shows both tanks and the filling system all in one shot? I went to the West Marine page and found your Perko Gas Fill & Tank Vent assembly that you pictured, I assume that the filler side will go to a T and then fill both tanks at once? Or - ?
I guess the Perko assembly includes a vent function and you are considering tying the two 5-gallon tanks into it? Or - ?
Without having a better concept of what you are thinking of doing & how you plan to do it, it is not possible to be helpful.
Richard Pike
Kingsport, TN 3TN0
kenw
PostPosted: Sat Mar 21, 2020 10:07 am    Post subject: Fuel tank vents Reply with quote
Rick,
Please see attached, suggestions are appreciated.!!
The tubing is mock up only...
my concern is attachment to the tank bung - for proper ventilation/evaporation concerns.
On Mar 10, 2020, at 7:45 PM, Richard Pike <thegreybaron(at)charter.net> wrote:
Richard Pike
Kolb Firefly Part 103 legal
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=495224#495224
 Filesize:  94 KB
 Viewed:  13204 Time(s)
 Filesize:  85.78 KB
 Filesize:  101.56 KB
 Filesize:  82.31 KB
kenw
zeprep251(at)aol.com
PostPosted: Sun Mar 22, 2020 4:37 am    Post subject: Fuel tank vents Reply with quote
JBM has fuel resistant tank grommets
On Mar 21, 2020, at 5:32 PM, worthken67(at)gmail.com wrote:
Rick,
<image0.jpeg>
<image1.jpeg>
<image2.jpeg>
<image3.jpeg>
> Richard Pike
> Kingsport, TN 3TN0
> Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing.
Ducati SS
PostPosted: Sun Mar 22, 2020 12:27 pm    Post subject: Re: Fuel tank vents Reply with quote
I am only guessing here but I suspect your vent location is in a low pressure area. You may want to do some additional research or contact Kolb. Surely would not want to vent tanks to a low pressure area.
Richard Pike
PostPosted: Mon Mar 23, 2020 6:02 am    Post subject: Re: Fuel tank vents Reply with quote
Ducati SS brings up a good point, and it's not just the low pressure - every time the prop passes the aft end of the fuselage you are going to get a pressure pulse. Have no guess as to what that may or may not do.
Richard Pike
Kingsport, TN 3TN0
George Alexander
PostPosted: Mon Mar 23, 2020 6:19 am    Post subject: Re: Fuel tank vents Reply with quote
I was told and have followed the practice on several aircraft, to run the open end of the vent line to a point that is lower than the bottom of the tank(s). I run mine down along side the tanks to a point below the pan that the tanks sit on. The theory being that if you are unfortunate enough to wind up inverted on the ground, the fuel will not run out through the vent line.
As Beauford would say... worth what you paid for it....
George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net
