leaking fuel valve?
JL2A
PostPosted: Fri Mar 06, 2020 11:42 am    Post subject: leaking fuel valve? Reply with quote
Hi all,
Does anyone know where the 'fuel valve' is that goes into the carburettor on the HS6A?
We are getting drips of fuel on shut down and have had advice that it is either the membranes (we have installed a freshly overhauled carb this week, so it's not that) or a 'leaking fuel valve that leads into the carburettor'.
Both the existing and overhauled carbs do the same thing - it was what prompted me to overhaul the spare carb in the first place.
dsavarese0812(at)bellsout
PostPosted: Fri Mar 06, 2020 1:35 pm    Post subject: leaking fuel valve? Reply with quote
To completely shut the fuel off, pull the “Fire Control” handle. It’s in front of the throttle and prop controls. It shuts the fuel off going into the fuel screen on the firewall. From the fuel screen, the fuel goes into the fuel pump. From the fuel pump into the carburetor.
Who overhauled the carburetor?
Dennis?
On Mar 6, 2020, at 2:45 PM, JL2A <info(at)flyingwarbirds.com.au.matronics.com> wrote:
Hi all,
http://forums.matronics.com/viewtopic.php?p=495183#495183
n13472(at)aol.com
PostPosted: Fri Mar 06, 2020 4:45 pm    Post subject: leaking fuel valve? Reply with quote
Where is the fuel leaking from exactly ?
yakman285(at)gmail.com
PostPosted: Sat Mar 07, 2020 3:15 am    Post subject: leaking fuel valve? Reply with quote
Check the drain screws, there is one lower and an upper over the fuel chamber. They should have safety wire but ....
Craig Payne
draftsjust417(at)gmail.co
PostPosted: Sat Mar 07, 2020 3:42 am    Post subject: leaking fuel valve? Reply with quote
I'd love to see pix of the solution, if you get the opportunity.I'm sure I'll bump into the same issue sooner or later...
Thanks all-
Justin
N280NC
On Sat, Mar 7, 2020 at 3:49 PM Craig Payne <yakman285(at)gmail.com (yakman285(at)gmail.com)> wrote:
Craig Payne
JL2A
PostPosted: Sun Mar 08, 2020 11:50 pm    Post subject: Re: leaking fuel valve? Reply with quote
found it! the fuel valve anyway. Thanks Marcell. It is in the carb itself. We are hoping it just got a bit of grit in it during shipping etc.
 Filesize:  89.17 KB
 Viewed:  7448 Time(s)
