bmchambers
Posted: Sun Feb 09, 2020 4:47 pm Post subject: Landing gear actuators |
Annual time and going to pull the actuators and uplocks off for overhaul, Appears calendar time is 7 years per logs. Looking for hints and gotchas for getting them out and back in. Plan to send them to M-14P for overhaul/service.
Bryan
bmchambers
Posted: Sun Feb 09, 2020 4:47 pm Post subject: Re: Landing gear actuators |
For the Yak 52.....
flying(at)jeffhove.com Guest
Posted: Mon Feb 10, 2020 1:02 pm Post subject: Landing gear actuators |
Hello Bryan,
The nose actuator is removed through the right-side fuselage access
panel. Seems obvious, but I did a lot of crawling around in the
cockpit before noticing that panel.
Don't lose the flow restrictors! They are small, thin, cone-shaped
metal that fit over the ends of the T-fittings to precisely regulate the
airflow rate. They tend to stick to the fittings then fall out at a
later random time, perhaps when carrying the actuator across the
hangar. Very hard to find later if drop.
I think they are only on the normal "Main" pneumatic system side of the
T-fittings. The emergency system does not have them, which is why you
use a special procedure for ground-testing the emergency gear system so
they don't slam down and cause damage:
http://www.yak-52.com/maintena.htm#Gear%20Retraction%20/%20Extension%20Test%20Procedure
M-14P, Inc. is great. Incredibly dedicated group. I took their engine
class and really appreciate them.
Blue Skies,
Jeff Hove
Yak-52 NX52BS
Saint Paul, MN
On 2/9/2020 6:47 PM, bmchambers wrote:
Bryan
http://forums.matronics.com/viewtopic.php?p=494732#494732
