Z14 with SDS EM5 ENG BUS
Goto page 1, 2  Next
foghorn757(at)gmail.com
PostPosted: Sun Feb 09, 2020 4:46 am    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
Here is my idea for Z-14 with ENG BUS. The AUX side is primarily for powering the ENG BUS. The Main side is for all other consumers with an emergency aux feed to the ENG BUS from the Main Batt.
Thoughts?
Please go easy on me. 😬
Jeff Parker
Z14_ENG_BUS_SDS_x_2.pdf
 Filename:  Z14_ENG_BUS_SDS_x_2.pdf
 Filesize:  460 KB
 Downloaded:  737 Time(s)
PostPosted: Sun Feb 09, 2020 6:28 am    Post subject: Re: Z14 with SDS EM5 ENG BUS Reply with quote
The alternator "B" lead fuses should be physically located at the battery end of the B lead, not at the alternator end.
ANL fuses will carry their rated current indefinitely. Replace the 80 amp fuse with 40 amp.
Replace the Aux 40 ANL with a Littelfuse Maxi 30 amp.
For the cost of sales tax on the VP-X, a fuse block and fuses could be purchased.
And fuses can be replaced anywhere by the pilot.
Joe Gores
yellowduckduo(at)gmail.co
PostPosted: Sun Feb 09, 2020 7:10 am    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
Jeff
Fundamentally I ask myself what your goal might be?Ā  What are you trying
to protect against?
With an immediate low voltage warning you are not going to continue
flying blissfully unaware after an alternator has failed until the
battery dies like so many have done in the past.
There would be no hurry whatsoever to close the crossfeed, or manually
switch power sources after one z14 alternator quit, or do nothing and
just land on the battery.
Why put relays in the feed path to the engine instead of a switch. Or
two switches ganged together to feed from either of two sources. If you
do use relays what is the power source to activate them.
In my case with independent ignitions I use a switch to each coil and
either coil will run the engine.Ā  No diodes because the coils are
separate from each other.Ā  My ecu's and coil drivers on the ground side
of the coils operate regardless of whether their respective coils have
+12 volts on them.
Ken
Thoughts?
Jeff Parker
PostPosted: Sun Feb 09, 2020 7:33 am    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
Hey Joe,
Thanks for the comments. The main Alt is 60a and the Aux Alt is 30+. I was under the impression that the ANL current limiter should be slightly larger than the ALT load. Hence the 80a and 40a ANL. I purchase most stuff from B&C and they don’t sell a 70a ANL fuse to the best of my knowledge but I’ll see what I can find.
The VP-X is purchased and here to stay.
Jeff Parker
And fuses can be replaced by anywhere by the pilot.
Joe Gores
http://forums.matronics.com/viewtopic.php?p=494717#494717
PostPosted: Sun Feb 09, 2020 7:58 am    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
On 9Feb, 2020, at 10:08, C&K <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: C&K <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)>JeffFundamentally I ask myself what your goal might be? Continued IFR flight, inhospitable terrain over flight or I might fly it to Europe šŸ˜. What are you trying to protect against? Self induced engine failure.With an immediate low voltage warning you are not going to continue flying blissfully unaware after an alternator has failed until the battery dies like so many have done in the past.There would be no hurry whatsoever to close the crossfeed, or manually switch power sources after one z14 alternator quit, or do nothing and just land on the battery. I agree and believe this diagram addresses continued flight with minimal pilot input.Why put relays in the feed path to the engine instead of a switch. Or two switches ganged together to feed from either of two sources. If you do use relays what is the power source to activate them. I’m not tied to the relays. My thought process was to run a smaller gauge wire to the switch in the cockpit to activate the relays for the coils. I’m really looking for what is simple and works. In my case with independent ignitions I use a switch to each coil and either coil will run the engine. No diodes because the coils are separate from each other. My ecu's and coil drivers on the ground side of the coils operate regardless of whether their respective coils have +12 volts on them. KenOn 09/02/2020 7:44 AM, Foghorn Inc wrote:
Here is my idea for Z-14 with ENG BUS. The AUX side is primarily for powering the ENG BUS. The Main side is for all other consumers with an emergency aux feed to the ENG BUS from the Main Batt.Thoughts?Please go easy on me. 😬Jeff Parker
http://www.matronics.com/contribution http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com http://wiki.matronics.com http://www.matronics.com/contribution
PostPosted: Sun Feb 09, 2020 8:08 am    Post subject: Re: Z14 with SDS EM5 ENG BUS Reply with quote
The main alternator has two labels. 40 & 60. I only noticed the 40 amp label earlier. I think that "one size larger" rule of thumb applies to circuit breakers, not ANL fuses. Maybe Bob will chime in.
Joe Gores
johnbright
PostPosted: Sun Feb 09, 2020 8:33 am    Post subject: Re: Z14 with SDS EM5 ENG BUS Reply with quote
Re ANL current limiters.
Ref: http://www.aeroelectric.com/articles/anl/anlvsjjs.html
"There are some noteworthy characteristics of the ANL series devices. Note that they will carry nearly 2X their rated current indefinitely. This makes them behave more like the fusible links we've described elsewhere on this website. So, if you wish to size an ANL current limiter more in line with the output rating of your alternator, you could do so without regard to the "headroom"..."
John Bright, RV-6A
Single battery, wound-field alternator on main bus, MZ-30 PM generator on engine/essential bus.
N1921R links
johnbright
PostPosted: Sun Feb 09, 2020 9:23 am    Post subject: Re: Z14 with SDS EM5 ENG BUS Reply with quote
Hi Jeff... My 2 cents.
All... bear in mind:
    Jeff and I are dual SDS EM-5-F four cylinder.
    Jeff is RV-8 with one battery forward of firewall and one battery aft of baggage bulkhead and I am RV-6A with two batteries forward of firewall.
    Six cylinder is different in some ways; the injector relays and ignition coils draw more current; I believe the fuel pumps are the same Walbro GSL393 units.
Placing the engine bus forward of the firewall agrees with FAR 23.1361.
For the engine bus feed 12 awg is conservative. I did current draw calculations, summarized at https://docs.google.com/spreadsheets/d/14Jho6rEreX6upko3hPlpTRoGAmE3MCj18zQzqbGkyMM/edit#gid=1724151884
I too made the engine bus always hot to eliminate a couple relays and switches but in your case of one battery rear of the baggage bulkhead I would use a relay at the battery. I verify the diodes are not open or shorted by using the Dynon D6 voltmeter on the engine bus. My engine operation checklist is at https://docs.google.com/spreadsheets/d/17gL5VBNBINsUWGvcAn5oU3dBuvL6c_QKnQUzpi2PggY/edit#gid=1116877898
FAR 23.1361 would have the fuel pumps on relays forward of the firewall.
The ignition coil relays need a jumper from relay coil to power from engine bus.
I don't know how to prove the injector relays are not stuck in the nominal/off/ECU 1 position if the ECUs are not switched. I used progressive ECU/Ignition Coil switches so the ECU can boot before powering the coil. Also on the engine operation checklist linked above.
Both injector relays can be on the same fuse, they draw 0.055 A each for a total of 0.110 A. The install manual incorrectly says 0.42 A each; currently at V30 rev 3 01/08/2020.
Wire from Blue Sea pass thru to starter contactor can be 4 awg.
Wire to aux alternator can be 8 awg or even 10 awg.
The ANL for main alternator would be close to the Blue Sea pass thru.
Consider using a relay for aux bus feed so there will not be a hot switch on the IP in any case and so all power to the cabin can be cut in a post crash scenario. I'm not sure what's the best name for the Aux Eng Bus Feed switch given it comes from the Main Batt.
John Bright, RV-6A
N1921R links
ceengland7(at)GMAIL.COM
PostPosted: Sun Feb 09, 2020 9:32 am    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
On Sun, Feb 9, 2020 at 10:16 AM user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
The main alternator has two labels. 40 & 60.Ā  I only noticed the 40 amp label earlier.Ā  I think that "one size larger" rule of thumb applies to circuit breakers, not ANL fuses.Ā  Maybe Bob will chime in.
Joe Gores
Specs are published by mfgrs. Bussman *non-time-delay* specs:
http://www.cooperindustries.com/content/dam/public/bussmann/Electrical/Resources/product-datasheets-a/Bus_Ele_DS_2024_ANL.pdf
According to this doc, a 50A ANL will handle 100A for virtually unlimited duration. But for a catastrophicĀ fault, there's a very small difference (as a percentage of current orĀ  time to melt) between a 50A & an 80A. Ex:Ā (at)120A, the 50A melts in 0.5 seconds while the 80A melts at 0.7 seconds.
PostPosted: Sun Feb 09, 2020 11:44 am    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
It doesn't really matter much since all busses
are very robust. Put all engine loads on one
bus . . . either main or aux . . . you'll be
fine. No more busses needed
PostPosted: Sun Feb 09, 2020 12:00 pm    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
At 09:31 AM 2/9/2020, you wrote:
--> AeroElectric-List message posted by: Foghorn Inc <foghorn757(at)gmail.com>
Hey Joe,
Unlike CIRCUIT BREAKERS . . .
ANL (vintage) or MIDI/MANL (recommended) devices
are CURRENT LIMITERS. Check out the specs
https://tinyurl.com/by5qnop
a CURRENT LIMITER is intended to clear
hard faults (read: more amps than you'd
like to have flowing anywhere on the
airplane!).
A current limiter will typically
carry it's rated current for a very
long time.
[img]cid:.0[/img]
150% of rating is still longer than you
want a branch circuit protection to trip.
But hit say a MIDI50 with 500A (1000%) fault
and it's going to open in about 100 milliseconds.
Short story, when purchasing current limiters,
the size equal to your expected continuous
current is fine . . .
CIRCUIT BREAKERS are another story . . . and
not recommended for alternator b-lead protection
anyhow. Beech quit putting them into the b-leads
about 3 or 4 decades ago . . .
 Filesize:  150.38 KB
 Viewed:  17247 Time(s)
PostPosted: Sun Feb 09, 2020 12:48 pm    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
Thanks Bob! I’ll go with it and get some MIDI/MANL current limiters at the ALTs rated power.
Jeff Parker
On 9Feb, 2020, at 14:39, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
It doesn't really matter much since all busses are very robust. Put all engine loads on one bus . . . either main or aux . . . you'll be fine. No more busses needed
Marvin McGraw
PostPosted: Thu Oct 29, 2020 10:50 am    Post subject: Re: Z14 with SDS EM5 ENG BUS Reply with quote
If I understand this correctly, you are saying:
(1) do not add the engine bus
(2) put the engine EI/EFI components on either battery bus
(3) the emergency procedure would be to close the cross-tie
Am I missing anything?
Marvin McGraw
PostPosted: Thu Oct 29, 2020 6:12 pm    Post subject: Re: Z14 with SDS EM5 ENG BUS Reply with quote
Correction:
(2) put the engine EI/EFI components on either the main bus or the aux bus
johnbright
PostPosted: Thu Oct 29, 2020 9:17 pm    Post subject: Re: Z14 with SDS EM5 ENG BUS Reply with quote
Hi Marvin,
Have you seen Z101? Bob N started developing it just after the OP's (Jeff Parker) post and Jeff has moved to a schematic using Z101 as a template. It's installed in his RV-8 project and has been powered up but not flying yet.
In case you don't have a link to the Z-dwgs they are at http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/
I don't know if this info helps you. I know you have Z14 flying with dual SDS EFI/I.
John Bright, RV-6A
N1921R links
Marvin McGraw
PostPosted: Thu Nov 05, 2020 10:27 am    Post subject: Re: Z14 with SDS EM5 ENG BUS Reply with quote
If I follow this advice, is there a way to turn off both battery contactors in flight for a smoke in the cockpit scenario? It seems the engine would need additional electical protection.
PostPosted: Fri Nov 06, 2020 6:27 am    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
Yeah . . . that's why Z101 came into being. Fewer components,
robust, dual fed busses. For smoke in cockpit, close
battery feed to engine bus . . . shut down all other
switches.
david(at)carter.net
PostPosted: Fri Nov 06, 2020 8:30 am    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
Bob - I'm implementing Z101 now as a retrofit in my RV-7A. Your response reminded me of a question I had. Is there a reason not to operate with the engine bus alt feed always on? And the same question for the aux alternator field? I'm using the B&C standbyĀ regulator rather than the Ford regulator since I had one laying around if that makes any difference.Ā
Thanks!
David
David Carter
david(at)carter.net (david(at)carter.net)
On Fri, Nov 6, 2020 at 9:29 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
If I follow this advice, is there a way to turn off both battery contactors in flight for a smoke in the cockpit scenario?Ā  It seems the engine would need additional electical protection.
Ā
Ā  Yeah . . . that's why Z101 came into being. Fewer components,
Ā  robust, dual fed busses. For smoke in cockpit, close
Ā  battery feed to engine bus . . . shut down all other
Ā  switches.
Ā  Bob . . .
PostPosted: Tue Nov 10, 2020 3:11 pm    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
At 02:51 PM 11/10/2020, you wrote:
Bumping the question. Looking for the same info.
Jeff Parker
757-817-4929
On Nov 7, 2020, at 12:31, David Carter <david(at)carter.net> wrote:
Bob - I'm implementing Z101 now as a retrofit in my RV-7A. Your response reminded me of a question I had. Is there a reason not to operate with the engine bus alt feed always on? And the same question for the aux alternator field? I'm using the B&C standby regulator rather than the Ford regulator since I had one laying around if that makes any difference.
Any time the main bus is up, all busses are up
and position of other switches has no effect
on operation of the airplane. Alternate
feed path integrity should be checked in pre-flight.
What advantage do you perceive for running full-up
on power distribution options? You still need a
plan-b protocol for responding to abnormal
conditions. Does it make your task easier
to figure out what to shut off as opposed to
what to turn on?
The elegant plan-b offers specific responses
to an abnormal condition . . . how you choose
to configure is your call.
out of that stuff?"
Ceengland
PostPosted: Tue Nov 10, 2020 5:59 pm    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
Jeff Parker
757-817-4929
On Nov 7, 2020, at 12:31, David Carter <david(at)carter.net> (david(at)carter.net) wrote:
  what to turn on?
I'm not Jeff, but I plan on having the engine bus switch on whenever the engine is running, with the alternate power path coming through a diode from the main bus. My *logic* is that the dual active power paths minimize any potential 'operational issues' (failures in power delivery to the engine bus, for reasons ranging from device failure to inadvertent switch movement) that could come up at times when options/reaction time are limited, like shortly after takeoff or being forced to remain at low altitude  due to 'airliner pattern' approaches flown by leading traffic. The core driver is to not based on calculated odds, but on being prepared as well as possible for what *can* happen.
Another motivator is that 'switchology' (actually, procedures), while unavoidably different from traditional a/c engine installations, will be as close as possible to decades of training, where in certain emergencies we're trained to shut down everything except the engine. Again, not probability driven, but for what *can* happen.
Obviously, proper functionality will be checked before takeoff.
Goto page 1, 2  Next
Page 1 of 2
