occom(at)ns.sympatico.ca Guest
Posted: Tue Jul 18, 2006 2:29 am Post subject: Engine choices. |
I am not planning to change engines, I will overhaul my 582 and fly it but recent threads have me wondering what engines a M. IV will accept. Mine is a Denney aircraft and the assembly manual allows only for the 582 and 912. There is no advice as to weight and HP recomendations and I got to wondering.
If I did change engines I expect that the HKS would be the lightest/simplest suitable engine.
Aerobatics(at)aol.com Guest
Posted: Tue Jul 18, 2006 10:29 am Post subject: Engine choices. |
In a message dated 7/18/2006 5:30:57 A.M. Central Daylight Time, occom(at)ns.sympatico.ca writes:
| Quote: | I am not planning to change engines, I will overhaul my 582 and fly it but recent threads have me wondering what engines a M. IV will accept. Mine is a Denney aircraft and the assembly manual allows only for the 582 and 912. There is no advice as to weight and HP recomendations and I got to wondering.
The HKS is a wonderful engine, but has significantly less power than the 582.
All choices have their benifits. Personally, I like my 582 in my KF 2. Will not change. almost 250 hrs to date.
good luck
Dave
bmwebb(at)cox.net Guest
Posted: Tue Jul 18, 2006 4:56 pm Post subject: Engine choices. |
My understanding is that you have the most choices on your Model IV. The tubing used in my Model 2 is smaller than the 4, therefore I had to be reasonably careful what I hung on it. I have not specifically looked for that in a 4, but I was told this when asking about different engines, particularly the VW options.
Bradley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Dave G.
Sent: Tuesday, July 18, 2006 6:24 AM
Subject: Engine choices.
henrysfork1(at)msn.com Guest
Posted: Tue Jul 18, 2006 5:31 pm Post subject: Engine choices. |
The Jabiru 2200 is a good choice too.
Dee Young
Lynn Matteson
Posted: Wed Jul 19, 2006 11:11 am Post subject: Engine choices. |
Amen to that , Dee....97 hours on mine so far and hardly a complaint.
On Tuesday, July 18, 2006, at 09:30 PM, Dee Young wrote:
Lynn
Kitfox IV...Jabiru 2200
| Quote: | The Jabiru 2200 is a good choice too.
Dee Young
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Michel
Posted: Sun Jul 23, 2006 1:45 pm Post subject: Engine choices. |
I have a Denney's model 3 with a 582 and I changed it for a Jabiru
2200, Dave. Like Dee and Lynn, I am very pleased with it. But both
Rotax engines are also fine engines. As Bradley says, the HKS is also a
fine engine, but it will give you less power than the 582. The Jabiru
will give you about the same power under take-off and more power under
cruise. The 912 will give you more power overall. But the engine is
heavier and you will probably need to work your CG differently.
Cheers,
Michel
