franicaza(at)yahoo.com.mx Guest
Posted: Thu Jul 20, 2006 7:38 pm Post subject: Polytone over old polytone with carnauba |
I want to paint some orange lines with polytone over
my wings already painted with the same material. For a
pair of years I have used carnauba to keep surfaces
protected. Does anyone know how I could clean the
surface to remove carnauba before painting it?
I appreciate,
Francisco Icaza.
___________________________________________________________
La mejor conexión a Internet y <b >2GB</b> extra a tu correo por $100 al mes. http://net.yahoo.com.mx
barry(at)pgtc.com Guest
Posted: Fri Jul 21, 2006 2:18 am Post subject: Polytone over old polytone with carnauba |
Francisco, you really need to sandpaper the area where the new paint will
go. I suggest fine sandpaper, about 300 grit, first then mask and paint.
After the new paint is fully cured, come back and color finish the whole
area. I think there are directions for this in Polyfiber's instruction
book. Start with 600 grit, then 1000, then 1500, then maybe 2000. After
that use medium and then fine polishing compound.
Some others on the list may tell you a better or easier way but generally,
this would work. Call the Jon Goldenbaum at Polyfiber.
Barry West
ddsyverson(at)comcast.net Guest
Posted: Fri Jul 21, 2006 3:31 am Post subject: Polytone over old polytone with carnauba |
Francisco,
You will now thank your lucky stars for having polytone on an aircraft you
want to refinish with polytone. Doing this is a lot easier to do successfully
that putting anything over something other than polytone.
Getting the wax off has to be done. Any residue left will result in peeling,
pinholes, spots of all kinds and discoloration.
To remove the wax (and any other oil or grunt) you should use a solvent that
will dissolve the wax, but not ther polytone. In the auto painting business,
these products are cleverly called "Wax and grease removers". Poly fiber has
two products of this type for this purpose "Metl-sol" - part number C-2200
which is a strong solvent for this purpose and "Paint cleaning Solvent" part
number C-2210 which is a mild solvent.
There are other products from the auto repair sector which are equivalent and,
if you go this route, just be sure you use one which is compatible with
lacquer (Poly tone behaves a lot like lacquer)
If you do any experimenting with solvents other than those from Polyfiber -
just be sure to try it our on a small spot before going wild with it. The
trick is to use a solvent which dissolves the wax and crud, but not the
polytone. Be sure to solvent wash multiple times. Use clean rags and throw
them away frequently enough so you don't recontaminate the surface.
For sure, I would recommend, since you are using polyfiber systems in your
refinishing, give one of their representatives a call - people who work with
a particular product line usually know what works best with their product
line.
If you have some experience with re-finishing, you should be pretty well
prepared to do this task - if not - really be sure that you talk to a
poly-fiber representative.
On cars, we usually degrease, then go after it with wet or dry sandpaper -
there is not a lot you can hurt on cars (other than glass & chrome) - but
there is lot you can damage on fabric airplanes. You have to be careful with
sandpaper on fabric - remember that there is a UV protection coat under the
polytone you don't want to disrupt. There is always a possibility that a
person may have to do spot repairs going into the lower coats - in this case
be sure to reapply the lower coats.
Good luck with your project - you should have a really nice looking airplane
with new paint.
Sincerely,
Dave S
St Paul, MN
KF-7 Trigrear
On Thursday 20 July 2006 10:35 pm, icaza francisco wrote:
I appreciate,
Francisco Icaza.
FLIER(at)sbcglobal.net Guest
Posted: Fri Jul 21, 2006 6:04 am Post subject: Polytone over old polytone with carnauba |
Hey Francisco,
I've seen a couple of good replys and I'll chime in
as I have some experience with this situation.
As already stated, after you've masked get some
polyfiber paint cleaning solvent and wipe down the
surface to be painted. Do it a couple of times and
use good clean paper towels. Don't let the cleaning
solvent lay wet on the paint. Wipe it on then off.
Then, use Polyfiber paint rejuvenator to 'loosen' the
surface of the existing Polytone. Be sure to get the
surface loosened. If not, the new Polytone will not
adhere to the old Polytone. The best bet is to be
sure to do the refinish in a cool place to allow the
solvent vapors to loosen up the surface well before
they flash off. Use plenty of retarder in the paint
you're spraying to allow it to bond with the dried
paint.
If you don't get the surface loosened, once that new
Polytone dries you'll find that it'll simply peel
right off the surface.
Ted
--- Original Message ---
carnauba
<franicaza(at)yahoo.com.m=
| Quote: | x>
a
| Quote: | pair of years I have used carnauba to keep surfaces
I appreciate,
Francisco Icaza.
=20
=09
=09
=09
______=20
| Quote: | La mejor conexi=F3n a Internet y <b >2GB</b> extra a
tu correo por $100 a=
=3D=3D=3D=3D=3D=3D=
| Quote: | =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3
browse
Subscriptions page,
FAQ,
List
| Quote: | _-
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
=3D=3D=3D=3D=3D=3D=
Wiki!
| Quote: | _-
=3D=3D=3D=3D=3D=3D=
List Admin.
| Quote: | _-
=3D=3D=3D=3D=3D=3D=
=20
=20
=20
Hey Francisco,
paint.
Ted
carnauba
| Quote: | x>
a
I appreciate,
Francisco Icaza.
=20
=09
=09
=09
______=20
=3D=3D=3D=3D=3D=3D=
browse
Subscriptions page,
FAQ,
List
| Quote: | _-
=3D=3D=3D=3D=3D=3D=
Wiki!
| Quote: | _-
=3D=3D=3D=3D=3D=3D=
List Admin.
| Quote: | _-
=3D=3D=3D=3D=3D=3D=
=20
=20
=20
foxfloatflyer(at)hotmail. Guest
Posted: Fri Jul 21, 2006 7:31 am Post subject: Polytone over old polytone with carnauba |
Hi Francisco,
I've used NAPA Wax & Grease remover, part #15250. Be sure to wear a good
mask when using it.
Joel
Model 5 912
Is your PC infected? Get a FREE online computer virus scan from McAfee®
Float Flyr
Posted: Fri Jul 21, 2006 4:46 pm Post subject: Polytone over old polytone with carnauba |
Only if you want to paint to stay on. If you are putting the lines on for a
temporary reason paint over the wax.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
mike Guest
Posted: Sat Jul 22, 2006 11:39 am Post subject: Re: Polytone over old polytone with carnauba |
To add a little final to the paint, use 8800 reducer and try to spray at 60degrees f. What this will do is cause the paint to dry real slow, the result is a much shinier look. Worked real nice for me.
clemwehner(at)sbcglobal.n Guest
Posted: Sat Jul 22, 2006 12:01 pm Post subject: Polytone over old polytone with carnauba |
I agree. I sprayed reduced polytone at 60 degrees. I could see my
reflection in the finish after it dried. It's been 13 years since I
painted my KFIV and the finish still looks as good. (I have kept it
hangered).
I also used polytone on my fiberglass parts such as the cowl and it is
perfect and very tough. I did as polyfiber said and sprayed the epoxy
primer then sprayed the polytone before the primer had cured. The
polytone goes on within just a few minutes after the primer. Polytone
is a fine finish and looks great when done right.
Clem
Oklahoma KFIV,912
