gearboxoil
manceliller(at)hotmail.co
PostPosted: Sat Jul 22, 2006 7:48 am    Post subject: gearboxoil Reply with quote
I HAVE A MODEL 2 WITH A 582 AND A MODEL C GEAR BOX, I CANT FIND THE CAPACITY OF OIL TO PUT BACK IN AFTER DRAINING.
  ALSO DOES THE PLANE HAVE TO BE LEVEL TO PROPERLY FILL IT??
        LANCE
In a message dated 7/20/2006 6:01:18 P.M. Central Daylight Time, wingsdown(at)comcast.net writes:
Your AOA is going to vary with speed and load. Not trying to be smart, just a thought.
Rick
Here is an APROX that should be close....?
from the center of the leading edge to trailing edge will be your zero, then at about 3 or 4 degrees, you should be darn close....
Dave
Play FOX Fantasy Football with MSN: Live scoring, fully customizable & completely free
dave(at)cfisher.com
PostPosted: Sat Jul 22, 2006 10:04 am    Post subject: gearboxoil Reply with quote
Hi Lance,
Set it in level flight   ( door frame level or close)
You will have 2 fill  holes on side of C box, remove the lower one and fill from the top vent plug on very top of box until it leaks out the lower fill hole on side.   Let sit for 5 mins or better till it done dripping.
Put screw back in and safety wire.  Check safety wire on drain on bottom of Box and fill vent if req'd.
You are all set.
Go and have fun Smile
Dave.
msm_9949(at)yahoo.com
PostPosted: Sat Jul 22, 2006 10:53 am    Post subject: gearboxoil Reply with quote
Hi Lance.
There are two screw/plugs on the left side of your  C gearbox. Level your plane, remove the top screw/plug and fill gearbox until oil starts to leak from this hole. Replace, tighten, safety-wire and you're good to go.
lance miller <manceliller(at)hotmail.com> wrote:
[quote]--> Kitfox-List message posted by: "lance miller"
        LANCE
Rick
Dave
Play FOX Fantasy Football with MSN: Get on board. You're invited to try the new Yahoo! Mail Beta.
PostPosted: Sat Jul 22, 2006 11:27 am    Post subject: gearboxoil Reply with quote
I guess I shouldn't trust my memory for this stuff anymore. Rotax manual says 200cc for C box with prop shaft offset upwards. Doesn't say if that's the top or bottom hole but if Dave says bottom, he's probably right. Sorry for the confusion.
Dave <dave(at)cfisher.com> wrote:
[quote] Hi Lance,
You are all set.
Dave.
dave(at)cfisher.com
PostPosted: Sat Jul 22, 2006 12:46 pm    Post subject: gearboxoil Reply with quote
I you fill to the top hole it will foam out the top vent plug all over the engine and muffler and like 85- 90w  burning as it drips on muffler.
Dave
PostPosted: Sun Jul 23, 2006 6:42 am    Post subject: gearboxoil Reply with quote
thanks dave, here is a picture of my fox.
[quote] I you fill to the top hole it will foam out the top vent plug all over the engine and muffler and like 85- 90w  burning as it drips on muffler.
Dave
 Filesize:  169.98 KB
 Viewed:  293 Time(s)
