algrajek
Joined: 10 Jan 2006 Posts: 41 Location: Lexington, Ky
Posted: Fri Jul 21, 2006 5:36 pm Post subject: Oil temp problems |
Listers:
I am seeing real high oil temps on my IO-360, Lycoming in my RV8. In the
270degree range. I have the 9 row oil cooler mounted on the rear baffle.
This is a new engine. Any suggestions on what to look for? Better oil cooler
placement?
Al Grajek
RV8
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ just rv8in |
tomscherder(at)hotmail.co Guest
Posted: Fri Jul 21, 2006 6:13 pm Post subject: Oil temp problems |
Al,
Check to be sure that nothing has clogged your oil cooler intake. We had
high temps in the beginning and found that we had sucked a piece of paper
into the intake. While we had it apart we increased the size of the intake.
Tom
flyeyes(at)mac.com Guest
Posted: Fri Jul 21, 2006 6:40 pm Post subject: Oil temp problems |
On Jul 21, 2006, at 8:32 PM, Al Grajek wrote:
Listers:
In the 270degree range. I have the 9 row oil cooler mounted on the
rear baffle. This is a new engine. Any suggestions on what to look
for? Better oil cooler placement?
Al Grajek
RV8
Al, this is common on the angle-valved engines. They just put more
heat into the oil. I'll send you some photos of my (not original)
solution off-list, but you can find the same info on doug reeves' site.
James Freeman
RV-8 N9TN, cool oil temps
klwerner(at)comcast.net Guest
Posted: Fri Jul 21, 2006 7:14 pm Post subject: Oil temp problems |
270-F.??? I'd check your Temp Sensor first as that sounds awfully high for any installation (especially with a 9 row cooler)!
chasm711(at)msn.com Guest
Posted: Fri Jul 21, 2006 8:29 pm Post subject: Oil temp problems |
Someone told me that early cowls had a 2" exhaust opening and that caused
some problems and this was later changed to a 3" opening. I also set the
cooler back from the baffle by 1/2 inch and it's tightly sealed. Just
something to check. My IO360A1B6 with the 9 row cooler and high compression
pistons rarely gets over 200 degrees (hot day full power climb at less than
100k IAS for several thousand feet) Good luck
Paul Schattauer
RV8 808PS
martin(at)gbonline.com Guest
Posted: Tue Aug 01, 2006 5:12 am Post subject: Oil temp problems |
Al,
I experienced the same problem when my RV8 was new.
Tilt back the Oil cooler approx. 25 degrees. Make the brackets from 030 or
040 4130 steel. This fixed my problem. 1350 hours on this set up.
Dick Martin
RV8 N233M
