Landing gear warning annunciator
greg.barnhard@gmail.com
PostPosted: Thu Oct 24, 2019 2:48 pm    Post subject: Landing gear warning annunciator Reply with quote
Does anyone know what triggers the LANDING GEAR (red) warning annunciator on the annunciator panel? This is in a 52W. I believe it’s supposed to act like what a warning horn would do in a bonanza, etc. I just can’t figure out what triggers it. There doesn’t seem to be a micro switch on the throttle. Is it tied into the stall tab? I’m trying to wire the annunciator into my G3X touch but I need to know how it works to test it. Any insight would be greatly appreciated!
Greg
 Filesize:  74.39 KB
 Viewed:  5246 Time(s)
bmacey916(at)gmail.com
PostPosted: Fri Oct 25, 2019 4:03 pm    Post subject: Landing gear warning annunciator Reply with quote
I too have one in my 52 TW and have wondered the same thing for the past 10 years?
On Thu, Oct 24, 2019 at 3:52 PM greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com) <greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com)> wrote:
--> Yak-List message posted by: "greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com)" <greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com)>
Greg
http://forums.matronics.com/viewtopic.php?p=491955#491955
http://forums.matronics.com//files/d243bec5_08ea_4dfd_8e7e_c641e2530e9c_186.jpeg
wamflight(at)gmail.com
PostPosted: Sat Oct 26, 2019 5:34 am    Post subject: Landing gear warning annunciator Reply with quote
When u r flying and pull throttle to idle is there a warning? If u leave the gear up and lower full flaps, is there a warning? Those r the only options. Either way a micro switch. Not sophisticated enough for altitude warnings.
Greg
cjpilot710(at)aol.com
PostPosted: Sat Oct 26, 2019 6:37 am    Post subject: Landing gear warning annunciator Reply with quote
There must a micro switch somewhere. I put a gear warming on my CJ6 (which has none) by put a micro switch on the rear cockpit throttle. I set and marked the position of the throttle at power setting I normally use for approaches. I then mounted a micro switch on the copper casing so that it closed a circuit getting its power from the "UP" lights in the rear cockpit. This lit up a red light on the front panel. You could put a flasher switch in the circuit so as to make the light flash as an attention get-er. Also a horn could be added. Jim "Pappy" Goolsby
