jlpartington(at)reagan.co Guest
Posted: Fri Oct 18, 2019 4:03 am Post subject: Cylinder head nut wrench HS6A |
I need one!
Anyone got one I can beg, borrow, steal or even buy? Actually. I prefer the latter.
Pooh
rhgalyen
Posted: Tue Oct 22, 2019 5:52 am Post subject: Re: Cylinder head nut wrench HS6A |
If you have a torch, you can make your own, using a box end wrench and long extension. I have used a 9/16" base wrench for Lyc, & Cont. with some success.
pennington.construction.i Guest
Posted: Tue Oct 22, 2019 7:17 am Post subject: Cylinder head nut wrench HS6A |
I am sure you have done this. Â
Reach out to Kristina at M14
And Richard Goode. Â Â
Both of those folks have been very helpful for me in the past. Â
Mark
On Tue, Oct 22, 2019 at 9:57 AM rhgalyen <rhgalyen(at)hotmail.com (rhgalyen(at)hotmail.com)> wrote:
| Quote: | --> Yak-List message posted by: "rhgalyen" <rhgalyen(at)hotmail.com (rhgalyen(at)hotmail.com)>
http://forums.matronics.com/viewtopic.php?p=491900#491900
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
     -Matt Dralle, List Admin.
GeorgeCoy
Posted: Tue Oct 22, 2019 7:50 am Post subject: Cylinder head nut wrench HS6A |
And Doug Sapp sells them as well!
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Mark Pennington
Sent: Tuesday, October 22, 2019 11:17 AM
To: yak-list(at)matronics.com
Subject: Re: Re: Cylinder head nut wrench HS6A
And Richard Goode.
Mark
fishmouth500
Joined: 07 Apr 2015 Posts: 43 Location: Southern California
JB Soar
Posted: Tue Oct 22, 2019 8:53 am Post subject: Cylinder head nut wrench HS6A |
This cylinder base wrench is a lovely work of art. It looks great in one's tool box. 'Essential if one ever needs to remove/install a cylinder...
On Tue, Oct 22, 2019 at 11:10 AM fishmouth500 <john.warwick1(at)gmail.com (john.warwick1(at)gmail.com)> wrote:
wlannon(at)shaw.ca Guest
Posted: Tue Oct 22, 2019 10:11 am Post subject: Cylinder head nut wrench HS6A |
Very good looking tool and sorely needed!
I have been welding nuts on the Chinese and Russian ones for years in order
to measure torque. I have also for some years been advocating a torque
value based on an evaluation of stud size and thread form as compared to the
Pratt & Whitney. In this I have assumed an equivalent material strength
which I firmly believe is a valid assumption.
As a result I been advocating a torque value of 300 to 320 lb/in (25 to 26.6
lb/ft.) LUBRICATED. It is heartening to finally see an "official" value
published, particularly when it seems to validate my own. I was not aware
of Termikas and I could find nothing in any of the M14 documents that I
could locate.
Only question I have is "does Termikas specify dry or lubed?" Just
curious, for me it will remain "lubed".
The next crusade here may be to throw away the torque robbing tab washers
and replace with P&W Palnuts for safety??
Cheers;
Walt
