Pics needed
yakman285(at)gmail.com
PostPosted: Mon Oct 14, 2019 1:22 pm    Post subject: Pics needed Reply with quote
I'm working on presentations for a visit to the Nanchang factory and need some pics of a CJ baggage compartment. Mine was butt-simple 2 shelves of plywood but I am looking for something simple and clean looking. Don't need no Leather and Burled Walnut with  LED mood lighting and matching monogrammed luggage....
Craig Payne
wlannon(at)shaw.ca
PostPosted: Mon Oct 14, 2019 8:12 pm    Post subject: Pics needed Reply with quote
Hi Craig;
Here is a very simple one using the original elec./avionics space. It is placarded to a max. of 50 lbs. the approx. weight of the removed equipment which transferred that load directly to the floor support structure.
It is fully enclosed and does not compromise the weight and balance situation as a further aft system would. The floor is 3/8” aircraft grade birch plywood.
The hose is a later addition to fill the smoke oil tank below the floor.
Walt
Sent: Monday, October 14, 2019 2:21 PM
To: yak-list (yak-list(at)matronics.com)
Subject: Pics needed
Craig Payne
 Filesize:  344.8 KB
 Viewed:  3444 Time(s)
 Filesize:  325.86 KB
 Filesize:  336.12 KB
