				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| nuckolls.bob(at)aeroelect Guest
				|  Posted: Mon Sep 09, 2019 9:08 am    Post subject: Aux Battery Idea Was: Speaking of Aux   Batteries |   |
				|  	  | Quote: |  	  | Here's a work in progress.  Obviously not complete, no alternator shown, lot's of detail omitted, etc, but the starter contactor power is shown.  That's the key, unless I'm missing something.
 There are no 'timing' issues with using
 a second battery for brownout protection.
 Consider Z-35 for second battery and
 simply leaving the aux battery relay
 open until after the engine is running.
 | |  |  | - The Matronics AeroElectric-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?AeroElectric-List
		| Back to top |  |
				|  Posted: Tue Sep 10, 2019 5:14 am    Post subject: Aux Battery Idea Was: Speaking of Aux   Batteries |   |
				| At 03:01 PM 9/9/2019, you wrote:
  	  | Quote: |  	  | Thanks Bob,
 What is the cost of accidently leaving the aux battery on during start?  Is it just a sag, or does starter-sized current try to run through the small relay and associated wiring?  If the main is weak, will the aux battery work that much harder?  I'm concerned that a relatively simple mistake like leaving the aux batt on during start will do some damage.
 (I've put switches in the wrong position before...)
 Make the aux battery switch two pole
 with second pole wired to disable
 the starter contactor any time the aux
 battery is ON.
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
