Russian Air Fitting
yakflyer(at)aol.com
PostPosted: Fri Aug 09, 2019 5:17 am    Post subject: Russian Air Fitting Reply with quote
I need a quarter turn air Supply fitting that connects the air bottle to the airplane...
Looks a little like an automobile fuel cap.
Bill Tiley (Bounce 25)
520-245-9311
iainday
PostPosted: Sun Aug 11, 2019 2:34 pm    Post subject: Re: Russian Air Fitting Reply with quote
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=yak+air+fitting&_sacat=0
Marcemmanuel
PostPosted: Fri Aug 16, 2019 8:35 am    Post subject: Re: Russian Air Fitting Reply with quote
Hi
anybody has the AN references for nipples and nuts we can use to retrofit the air system with 1/4 tube?
thank you so much.
 Filesize:  779.36 KB
 Viewed:  8468 Time(s)
 Filesize:  779.36 KB
yakflyer(at)aol.com
PostPosted: Fri Aug 16, 2019 11:56 am    Post subject: Russian Air Fitting Reply with quote
Call Hose Power.
520-623-0531
They have the correct fitting.
On Aug 16, 2019, at 9:35 AM, Marcemmanuel <mvallee(at)hotmail.fr> wrote:
Hi
thank you so much.
http://forums.matronics.com/viewtopic.php?p=490903#490903
http://forums.matronics.com//files/nipple_214.jpeg
http://forums.matronics.com//files/nipple_194.jpeg
dsavarese0812(at)bellsout
PostPosted: Fri Aug 16, 2019 12:38 pm    Post subject: Russian Air Fitting Reply with quote
You have to reuse the Russian/Chinese B-Nuts and use an AN4 sleeves for the flare on the 1/4" tubing.
https://www.speedwaymotors.com/Aluminum-Tube-Nut-Sleeve-4-AN-1-4-,34350.html
Doug usually has B-nuts for sale if you mess one up.
Dennis
On Friday, August 16, 2019, 12:38:18 PM EDT, Marcemmanuel <mvallee(at)hotmail.fr> wrote:
--> Yak-List message posted by: "Marcemmanuel" <mvallee(at)hotmail.fr (mvallee(at)hotmail.fr)>
Hi
thank you so much.
http://www.matronics.com/Navigsp; - MATRONICS WEB FORUMS -
http://wiki.matr========================
Marcemmanuel
PostPosted: Tue Aug 27, 2019 11:16 am    Post subject: Re: Russian Air Fitting Reply with quote
Thank you Wink
