Port wing bellcrank
barp99(at)gmail.com
PostPosted: Sat Aug 03, 2019 7:43 pm    Post subject: Port wing bellcrank Reply with quote
I'm in the middle of XS wing construction and have just riveted the
BC4W10 to a W13 Bellcrank. To save time I riveted a second one, exactly
the same. Now I am thinking they should have been a mirror image of each
other. Are there any builders with really good memories (or records) out
there that can confirm I have screwed up?
Brian in Aus.
 Filesize:  62.75 KB
 Viewed:  4262 Time(s)
 Filesize:  42.7 KB
MJKTuck(at)cs.com
PostPosted: Sat Aug 03, 2019 8:14 pm    Post subject: Port wing bellcrank Reply with quote
Hi Brian, the aileron assemblies are ‘handed’ (mirrored), I don’t think you can get away with just flipping the bellcrank around either but you might try.
Martin Tuck
On Aug 3, 2019, at 10:41 PM, Brian Phillips <barp99(at)gmail.com> wrote:
I'm in the middle of XS wing construction and have just riveted the BC4W10 to a W13 Bellcrank. To save time I riveted a second one, exactly the same. Now I am thinking they should have been a mirror image of each other. Are there any builders with really good memories (or records) out there that can confirm I have screwed up?
Brian in Aus.
<P8044736.jpg>
<P8044737.jpg>
europa10(at)bellsouth.net
PostPosted: Sun Aug 04, 2019 4:16 am    Post subject: Port wing bellcrank Reply with quote
Brian,
Sorry, but they are mirror images. See picture.
Happy building!!!
N51EU
Monowheel Classic
 Filesize:  610.09 KB
 Viewed:  4250 Time(s)
barp99(at)gmail.com
PostPosted: Sun Aug 04, 2019 5:03 pm    Post subject: Port wing bellcrank Reply with quote
Doh!  Thanks for the photo Bill. One step forward, two steps back.......
Brian.
On 4/08/2019 10:14 pm, Bill wrote:
[quote] Brian,
Happy building!!!
N51EU
Monowheel Classic
