rowlandcarson(at)gmail.co Guest
Posted: Sat Aug 03, 2019 11:04 am Post subject: Lines on pre-prep [was: fuel odor in the cockpit] |
Those are guide lines in the pre-preg used for the kit parts supplied ready-made. Builders can ignore them.
in friendship
Rowland
sent from Rowland's iPhone
On 3 Aug 2019, at 10:20, Gilles Thesee <gilles(at)elixir-aircraft.com (gilles(at)elixir-aircraft.com)> wrote:
| Quote: | Le 03/08/2019 à 10:37, Rowland Carson a écrit :
Hi all,
Please pardon this question from an outsider.
On several Europa pictures some lines and squares can be seen on the inside skin of the aircraft.
Are those lines related to some left-over peel ply, or is there some other purpose, reason, origin for those lines ?
Best regards,
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
[b]Gilles THESEE
Avionics & Systems
+33 6 61 93 29 74
<nkcjnchobcpkakkp.jpg>
http://elixir-aircraft.com/
Batiment D1 – 6 Rue Aristide Bergès
17 180 Périgny - France
N°TVA intracom : FR64 808 671 234
Ce courriel (de même que les fichiers joints) est strictement réservé à l'usage de la personne ou de l'entité à qui il est adressé et peut contenir de l'information privilégiée et confidentielle. Toute divulgation, distribution ou copie de ce courriel est strictement prohibée. Si vous avez reçu ce courriel par erreur, veuillez nous en aviser sur-le-champ, détruire toutes les copies et le supprimer de votre système informatique.
This communication (including any files transmitted with it) is intended solely for the person or entity to whom it is addressed, and may contain confidential or privileged information. The disclosure, distribution or copying of this message is strictly forbidden. Should you have received this communication in error, kindly contact the sender promptly, destroy any copies and delete this message from your computer system.
[/b]
gilles(at)elixir-aircraft Guest
Posted: Sun Aug 04, 2019 2:24 am Post subject: Lines on pre-prep [was: fuel odor in the cockpit] |
Le 03/08/2019 à 21:02, Rowland Carson a écrit :
| Quote: | Those are guide lines in the pre-preg used for the kit parts supplied ready-made. Builders can ignore them.
in friendship
Rowland,
Thank you for responding.
Best regards,
[b]Gilles THESEE
Avionics & Systems
+33 6 61 93 29 74
[img]cid:part2.8F7D43D2.30274569(at)elixir-aircraft.com[/img]
[/b]
8.21 KB |
3346 Time(s) |
