Alternator Dropping Off Line
cluros(at)gmail.com
PostPosted: Fri Jul 12, 2019 4:02 pm    Post subject: Alternator Dropping Off Line Reply with quote
The alternator on our O-200 intermittently died on a flight today. In total it quit 4 times, the longest for almost 4 minutes. After landing we wiggled all the wires, checked several for continuity, everything looks good. We have no cooling air going to the alternator at the back of the engine and it was a warm day and the engine compartment was very hot.
Is it possible this is a heat problem or definitely wiring / regulator / alternator?
Thank you,
Sebastien
 Filesize:  192.56 KB
 Viewed:  10978 Time(s)
PostPosted: Fri Jul 12, 2019 5:29 pm    Post subject: Re: Alternator Dropping Off Line Reply with quote
Not enough information is given.
How many hours on the alternator?
13.8 volts is low.
One possibility is worn brushes.
Joe Gores
cluros(at)gmail.com
PostPosted: Fri Jul 12, 2019 9:13 pm    Post subject: Alternator Dropping Off Line Reply with quote
That 13.8 is at the start of a failure cycle. Normal bus voltage has been 14.1 on the last several flights.
The engine was recently overhauled, I'm trying to find out if the alternator was as well. It looks new.
On Fri, Jul 12, 2019 at 6:35 PM user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
13.8 volts is low.
Joe Gores
http://forums.matronics.com/viewtopic.php?p=490233#490233
PostPosted: Sat Jul 13, 2019 7:34 am    Post subject: Alternator Dropping Off Line Reply with quote
Okay, it sounds like this alternator
has no known track record.
[img]cid:.0[/img]
I put a 'ruler' on a piece of your
data plot and it appears that alternator
OPERATING is on the order of 13.7v, alternator
OFF is 12.4v or battery only. you've got a
LOT of on/off transients.
Does this alternator have a built in
regulator or external regulator?
If INTERNAL regulator, the alternator
is defective. If EXTERNAL reguator,
you need to put a voltmeter on the
Field terminal during a flight to
see if the transient is upstream
(in the regulator or associate
wiring) or downstream (in the
alternator).
 Filesize:  35.57 KB
 Viewed:  10956 Time(s)
kenryan
PostPosted: Sat Jul 13, 2019 7:59 am    Post subject: Alternator Dropping Off Line Reply with quote
Bob, what is a "transient" ?
On Sat, Jul 13, 2019 at 7:39 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[img]cid:16bec0e377cd9a3031f1[/img]
  alternator).
 Filesize:  35.57 KB
cluros(at)gmail.com
PostPosted: Sat Jul 13, 2019 8:16 am    Post subject: Alternator Dropping Off Line Reply with quote
Operating is 14.1, not operating is about 12.7. Please see the link below which I should have sent to start with. I find it strange the way the voltage slowly drops rather than a sharp on/off drop. Maybe I'll try the switch to see what that looks like on the graph.
I will place a voltmeter on the field line next flight.
https://www.savvyanalysis.com/flight/3309601/fa4df24a-e512-4297-bf73-2a797c6ab36b
On Sat, Jul 13, 2019, 09:05 Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
  alternator).
 Filesize:  35.57 KB
 Viewed:  10957 Time(s)
cluros(at)gmail.com
Ford style external regulator wired as per AEC.
On Sat, Jul 13, 2019, 09:14 Sebastien <cluros(at)gmail.com (cluros(at)gmail.com)> wrote:
  alternator).
 Filesize:  35.57 KB
ceengland7(at)gmail.com
PostPosted: Sat Jul 13, 2019 9:18 am    Post subject: Alternator Dropping Off Line Reply with quote
adjective
  1. 1.
    lasting only for a short time; impermanent.
    "a transient cold spell"
noun
  1. 1.
    a person who is staying or working in a place for only a short time.
  2. 2.
    a momentary variation in current, voltage, or frequency.
[img]cid:part2.E777B17F.1749D556(at)gmail.com[/img]
  alternator).
 Filesize:  35.57 KB
 Viewed:  10955 Time(s)
kenryan
PostPosted: Sat Jul 13, 2019 11:17 am    Post subject: Alternator Dropping Off Line Reply with quote
Wow, that is certainly an all-inclusive definition.
On Sat, Jul 13, 2019 at 9:24 AM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
adjective
  1. 1.
noun
  1. 1.
  2. 2.
[img]cid:16becc23da6d9a3031f1[/img]
  alternator).
Virus-free. www.avast.com [url=#m_-949200549652384023_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
 Filesize:  35.57 KB
 Viewed:  10953 Time(s)
PostPosted: Sat Jul 13, 2019 11:57 am    Post subject: Alternator Dropping Off Line Reply with quote
Hi Ken,
I highlighted & underlined what I thought was Bob's meaning when I read it; the 2nd noun definition. Perhaps the highlight/underline didn't show up in your email client.
If a signal (or power level) is switching on/off rapidly, it's a 'transient' (short term event).
On Sat, Jul 13, 2019 at 2:22 PM Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
adjective
  1. 1.
    • 949200549652384023lr_dct_sf_subsen" id="gmail-m_263918708704238526gmail-m_-949200549652384023_hAcqXbWIObmF9PwP8JOsMA21" style="display:list-item;list-style-type:disc;font-size:xx-small;margin-left:25px;padding-top:5px">
noun
  1. 1.
  2. 2.
  alternator).
Virus-free. www.avast.com [url=#m_263918708704238526_m_-949200549652384023_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
 Filesize:  35.57 KB
kenryan
PostPosted: Sat Jul 13, 2019 3:23 pm    Post subject: Alternator Dropping Off Line Reply with quote
Thanks Charlie. I think I understand now what Bob is saying.
On Sat, Jul 13, 2019 at 12:02 PM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Hi Ken,
adjective
  1. 1.
noun
  1. 1.
  2. 2.
  alternator).
949200549652384023DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2">
Virus-free. www.avast.com [url=#m_1840038890319382137_m_263918708704238526_m_-949200549652384023_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
 Filesize:  35.57 KB
subknave
PostPosted: Sat Jul 13, 2019 3:37 pm    Post subject: Alternator Dropping Off Line Reply with quote
I don't know if it is significant but it seemed to be offline for longer periods each time during the flight. Going by the download you linked to.
On Sat, Jul 13, 2019 at 9:24 AM Charlie England < ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
adjective
  1. 1.
noun
  1. 1.
  2. 2.
On Sat, Jul 13, 2019 at 7:39 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  alternator).
 Filesize:  35.57 KB
 Viewed:  10949 Time(s)
cluros(at)gmail.com
PostPosted: Sat Jul 13, 2019 5:40 pm    Post subject: Alternator Dropping Off Line Reply with quote
Yes I found that strange. Each cycle was longer both in duration and in time before the next one. Probably random though.
On Sat, Jul 13, 2019, 19:44 r.r.hall(at)cox.net (r.r.hall(at)cox.net) r.r.hall(at)cox.net (r.r.hall(at)cox.net) <r.r.hall(at)cox.net (r.r.hall(at)cox.net)> wrote:
On July 13, 2019 at 3:16 PM Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
adjective
  1. 1.
noun
  1. 1.
  2. 2.
  alternator).
 Filesize:  35.57 KB
 Viewed:  10948 Time(s)
