914 100% Throttle Gate
rparigoris
PostPosted: Thu Jul 11, 2019 5:30 pm    Post subject: 914 100% Throttle Gate Reply with quote
Hi Group
The Europa 914 Install Manual tells you a gate will be needed for 115% power. It states a gate will be need to be included in the slotted facia plate. What is a slotted facia plate? Is it something you can buy or you make? Anyone have a drawing or pic of what they did? Thx. Ron P.
gilles(at)elixir-aircraft
PostPosted: Fri Jul 12, 2019 2:15 am    Post subject: 914 100% Throttle Gate Reply with quote
Le 12/07/2019 à 03:31, rparigoris a écrit :
--> Europa-List message posted by: "rparigoris" <rparigor(at)hotmail.com> (rparigor(at)hotmail.com)
Hi Group
Hello Ron,
How about this :
http://contrails.free.fr/engine_rotax_stops.php
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
[b]Gilles THESEE
Avionics & Systems
+33 6 61 93 29 74
gilles(at)elixir-aircraft.com (gilles(at)elixir-aircraft.com)
[img]cid:part2.6528A166.661DAA77(at)elixir-aircraft.com[/img]
http://elixir-aircraft.com/
Batiment D1 – 6 Rue Aristide Bergès
17 180 Périgny - France
N°TVA intracom : FR64 808 671 234
Ce courriel (de même que les fichiers joints) est strictement réservé à l'usage de la personne ou de l'entité à qui il est adressé et peut contenir de l'information privilégiée et confidentielle. Toute divulgation, distribution ou copie de ce courriel est strictement prohibée. Si vous avez reçu ce courriel par erreur, veuillez nous en aviser sur-le-champ, détruire toutes les copies et le supprimer de votre système informatique.
This communication (including any files transmitted with it) is intended solely for the person or entity to whom it is addressed, and may contain confidential or privileged information. The disclosure, distribution or copying of this message is strictly forbidden. Should you have received this communication in error, kindly contact the sender promptly, destroy any copies and delete this message from your computer system.
[/b]
 Filesize:  8.21 KB
 Viewed:  8059 Time(s)
Europa48
PostPosted: Fri Jul 12, 2019 2:31 am    Post subject: Re: 914 100% Throttle Gate Reply with quote
I think this type is the norm for most Europas...
Throttle facia plate with gate for turbo operation.
 Filesize:  1.76 MB
 Viewed:  8054 Time(s)
 Filesize:  1.76 MB
Bryan Allsop
PostPosted: Fri Jul 12, 2019 4:18 am    Post subject: 914 100% Throttle Gate Reply with quote
Please remove Bryan Allsop from your mailing list he passed away 2 years again Thankyou
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Europa48 <corinthian(at)me.com>
Sent: 12 July 2019 10:31
Subject: Re: 914 100% Throttle Gate
--> Europa-List message posted by: "Europa48" <corinthian(at)me.com>
http://forums.matronics.com/viewtopic.php?p=490209#490209
http://forums.matronics.com//files/img_5238_172.jpeg
http://forums.matronics.com//files/img_5238_183.jpeg
st Email Forum -
pa-List">http://www.matronics.com/Navigator?Europa-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
p; - NEW MATRONICS LIST WIKI -
matronics.com
p; - List Contribution Web Site -
p;   -Matt Dralle, List Admin.
spcialeffects
PostPosted: Fri Jul 12, 2019 5:08 am    Post subject: Re: 914 100% Throttle Gate Reply with quote
Hi Ron. I think this is what your looking for
 Filesize:  323.94 KB
 Viewed:  8036 Time(s)
budyerly(at)msn.com
PostPosted: Fri Jul 12, 2019 6:32 am    Post subject: 914 100% Throttle Gate Reply with quote
Ron,
To save metal workings look at a simple and effective mod that is easy to use and install. A simple angle installed in the existing throttle box works great and is a lot less filing and easy to adjust.
Best Regards,
Bud Yerly
Sent from Mail for Windows 10
Sent: Friday, July 12, 2019 6:31:43 AM
st Email Forum -
ums.matronics.com
matronics.com
Throttle_Friction_and_Stop_Modifications_Final.pdf
 Filename:  Throttle_Friction_and_Stop_Modifications_Final.pdf
 Filesize:  723.4 KB
 Downloaded:  565 Time(s)
