Another weight and balance question
Off2wildblue
PostPosted: Tue Jul 02, 2019 1:10 pm    Post subject: Another weight and balance question Reply with quote
I’m just trying to figure out if the numbers I have for my airplane are correct. It seems that I have a very high main wheel load for the left and right sides. My nose wheel load looks accurate at 610 lbs for my M-14B motor.
When I received my airplane the weight and balance sheet that was used shows 1185 pounds for the left main and 1150 pounds for the right man. This was calculated with the original paint and all of the avionics removed from the bay. This seems to be approximately 200 pounds more per side than the average weight and balance numbers I have seen for other CJ-6A’s.
Any ideas?
SAM
dabear
PostPosted: Wed Jul 03, 2019 5:07 am    Post subject: Another weight and balance question Reply with quote
Actually, thats about 300 lbs extra each side... I'd re-weigh your airplane.
Any ideas?
SAM
http://forums.matronics.com/viewtopic.php?p=489969#489969
n13472(at)aol.com
PostPosted: Wed Jul 03, 2019 8:18 am    Post subject: Another weight and balance question Reply with quote
My CJ stocker empty, dry weights
Nose 571
Left 890
Right 892
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV.
89019
Cell 541-297-5497
N13472(at)AOL.COM
Off2wildblue
PostPosted: Wed Jul 03, 2019 8:58 am    Post subject: Re: Another weight and balance question Reply with quote
See, that looks about right. Do you have the Housai?
SAM
Nose 571
Left 890
Right 892
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV.
89019
Cell 541-297-5497
N13472(at)AOL.COM
Off2wildblue
PostPosted: Wed Jul 03, 2019 9:11 am    Post subject: Re: Another weight and balance question Reply with quote
Is it possible that they weighed the plane with full tanks and a guy sitting in it and didn’t subtract that out. It would be 30 gallons in each wing with a 200 lb guy in the airplane and that would equal the extra 300 lbs per side.
SAM
Ttail
PostPosted: Wed Jul 03, 2019 11:15 pm    Post subject: Re: Another weight and balance question Reply with quote
Here are my weights after replacing Housai with M14PF all in Kgs
stephen.hayne
PostPosted: Sat Jul 13, 2019 5:19 am    Post subject: Re: Another weight and balance question Reply with quote
Here mine - just before certification last year and all old radios removed (lightest possible!). I have a google Spreadsheet here...
https://docs.google.com/spreadsheets/d/1jcIDqVtKRMBy5qm_kkyiOnqxakVXHI5eCX-4oaczPL8/edit?usp=sharing
 Filesize:  87.46 KB
 Viewed:  11042 Time(s)
Stephen Hayne, Cyber Security Consultant, Professor Emeritus (retired)
443LM Nanchang CJA
http://selfsynchronize.com/hayne/plane/cj6.asp
