Breake pads - mono?
stabelvej9(at)gmail.com
PostPosted: Sun Jun 30, 2019 12:20 am    Post subject: Breake pads - mono? Reply with quote
Hi
Need new brake pads for my mono.
Other places to buy these than Europa A?
Gert
OY-GDS, Mono, 914, Woodcomp, 1.000 hrs and still smiling
[img]cid:EE17EE42-B4CA-43E9-A3A2-CE1B6DFF69CD(at)My_net[/img]
 Filesize:  136.6 KB
 Viewed:  13724 Time(s)
Corinthian
PostPosted: Sun Jun 30, 2019 12:38 am    Post subject: Breake pads - mono? Reply with quote
Not sure about the wire locking on the axle at the 3 o clock point?
On 30 Jun 2019, at 09:20, Gert Dalgaard Sørensen <stabelvej9(at)gmail.com> wrote:
<EE17EE42-B4CA-43E9-A3A2-CE1B6DFF69CD.jpeg>
PostPosted: Sun Jun 30, 2019 7:12 am    Post subject: Breake pads - mono? Reply with quote
Not sure about what .. ?
Question was - where to purchase brakepads .. ?
The wire-locking thing is just fine.
Gert
Den 30. jun. 2019 kl. 10.36 skrev David Lewendon <davidlewendon(at)me.com>:
Rocketman
PostPosted: Sun Jun 30, 2019 8:26 am    Post subject: Breake pads - mono? Reply with quote
Wired to the loosen side, not the tighten side on 3 o'clock bolt. Good
eye, David.
Jeff
Gert
Corinthian
PostPosted: Sun Jun 30, 2019 10:34 am    Post subject: Breake pads - mono? Reply with quote
Thanks Jeff.
RAF training! A minor thing in this case and I don’t think it would cause a problem, but I can still hear my instructors words more than 50 years on.
BW
David
On 30 Jun 2019, at 17:25, Jeff B <topglock(at)cox.net> wrote:
Wired to the loosen side, not the tighten side on 3 o'clock bolt. Good eye, David.
Jeff
> Regards
> Gert
Rocketman
PostPosted: Sun Jun 30, 2019 11:06 am    Post subject: Breake pads - mono? Reply with quote
US Naval Aviation, here, '68-'72. Becomes ingrained after a while. Smile
Jeff
On 6/30/2019 1:34 PM, David Lewendon wrote:
Thanks Jeff.
BW
David
> Jeff
>> Regards
>> Gert
Remi Guerner
PostPosted: Sun Jun 30, 2019 11:19 pm    Post subject: Re: Breake pads - mono? Reply with quote
Gert,
The mono brake pads are 66-106 from Cleveland, Rapco or Grove. These are used on a lot of certificated aircraft types. Any aircraft parts vendor have them in stock.
Remi
PostPosted: Mon Jul 01, 2019 4:49 am    Post subject: Breake pads - mono? Reply with quote
Hi Remi
Thanks for your answer.
Gert
Den 1. jul. 2019 kl. 09.19 skrev Remi Guerner <air.guerner(at)orange.fr>:
Gert,
Remi
http://forums.matronics.com/viewtopic.php?p=489943#489943
Europa48
PostPosted: Mon Jul 01, 2019 4:54 am    Post subject: Re: Breake pads - mono? Reply with quote
They seem quite reasonably priced as well.
italianjon
PostPosted: Mon Jul 01, 2019 5:05 am    Post subject: Re: Breake pads - mono? Reply with quote
Good alternative part number!
Does anyone happen to know which of the "economical rivet tools" on the aircraftspruce site is applicable. They have some good rivet squeezers on there, which should make this job a piece of pi$$
h&jeuropa
PostPosted: Tue Jul 02, 2019 2:34 am    Post subject: Re: Breake pads - mono? Reply with quote
We use the Rapco tool ($37.75) to press out the old rivets and insert the new ones. It's easy to use and gives a nice result.
Jim & Heather
