test "do knot archive" in PROFILE Question
Site Admin
PostPosted: Thu Jul 20, 2006 8:43 am    Post subject: test "do knot archive" in PROFILE Question Reply with quote
Hi Gary,
Well the answer is yes-and-no. If something gets posted and ultimately added to the archive that is particularly heinous, then I can go in a edit the archives as necessary. But this is a labor intensive process, and generally not something I do too often.
List Admin.
At 11:48 PM 7/19/2006 Wednesday, you wrote:
Hello Matt
I have a question since some years ago...
Can you delete (or clean) the archives from some mails that beeing "not related" were released accidentally without the Do not archive note in it?
Just curious... Thanks one more time for this great lists
Saludos
Gary Gower
Flying from Chapala, Mexico.
Matt Dralle <dralle(at)matronics.com> wrote:
At 04:47 AM 7/19/2006 Wednesday, you wrote:
>I set my signature in my PROFILE to ".....Geoff.......do knot archive"
>Lets see if it follows this text. Just in case though DO KNOT ARCHIVE
>Read this topic online here:
Geoff and others,
Please _do not_ do this!
This permanently kills valuable threads of discussion unnecessarily. If someone responds to your message with some information that should have been in the archive, then it doesn't make it.
I can't stress enough, _do not_ put the "do knot archive" string in your signature file.
Thank you,
ggower_99(at)yahoo.com
PostPosted: Thu Jul 20, 2006 5:03 pm    Post subject: test "do knot archive" in PROFILE Question Reply with quote
Thanks Matt,
Got the answer,  sure will be a 24 hrs 365 days reading by you to check all the posts, all the list!!!!   .... But glad you do eventually.
I will try not to forget the Do not archive, and as much as possible on focus posts.
prob a little  joke once in a while, to light things up.
Saludos
Gary Gower.
--> Zenith-List message posted by: Matt Dralle
Hi Gary,
List Admin.
Hello Matt
Saludos
Gary Gower
>--> Zenith-List message posted by: "Geoff Heap"
Geoff and others,
Thank you,
How low will we go? Check out Yahoo! Messenger’s low PC-to-Phone call rates.
