ADS-B
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
ledson
PostPosted: Tue Aug 28, 2018 5:29 pm    Post subject: ADS-B Reply with quote
Has anyone here installed an ADS-B compliant system in their Allegro? And
If so, what type was it and would you please share the information with the group?
Larry Edson
N4362C
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
N456TS
PostPosted: Thu Aug 30, 2018 5:57 am    Post subject: Re: ADS-B Reply with quote
I've got the Dynon Skyview system. It's ADS-B in and out. I love it.
The Sky Beacon should be available shortly. It looks like it should be a quick install. It might be the lowest cost solution.
N456TS
lsvance54
PostPosted: Fri Apr 19, 2019 12:44 pm    Post subject: Re: ADS-B Reply with quote
Now that the Sky Beacon / Tail Beacon is out, has anyone installed one on an Allegro?
I’m thinking either would require some sort of modification.
How about the Garmin GDL-82?
Scott
N25017
jkgcpa(at)ix.netcom.com
PostPosted: Sat Apr 20, 2019 6:47 pm    Post subject: ADS-B Reply with quote
I measured for the Sky Beacon & concluded it won't fit.
Jerry Goldberg
N44456
Covey Trails (X09)
ishadatta
PostPosted: Tue Sep 24, 2019 8:49 pm    Post subject: Re: ADS-B Reply with quote
Thank Great Post. Smile
hgmckay
PostPosted: Wed Sep 25, 2019 5:00 am    Post subject: ADS-B Reply with quote
I have just read the discussion on the above subject. The skybeacon will not fit on the Allegro 2000 or the 2007 without major and costly modification, and the tailBeacon likewise. However, there is a location where the tailBeacon can be located and will work fine. I have installed the tail beacon on my Allegro 2000 E-LSA (N661WW) and it is working without a problem. It is mounted on the airframe crossbar in the cockpit just above the instrument panel. Since the top of the cockpit is clear the unit can see all Satellites, and the wiring connections from that point to the panel is short and simple. I did my own work since I built the plane from a KIT. Cost for the unit was $1,669.00 from uAvionix and my labor was free. I will post a few pictures later on the Allegro Matronics List. If any other Allegro owners want to contact me I will be glad to give you more detail. My personal email is hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
Hugh G. McKay III, P.E. Fellow. L.M. ASCE
Senior Consultant
Worldwide Engineering Inc.
4090 North NC Hwy. 16
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
Email hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
http://www.geo.com (click on Power Division)
Sent from Mail for Windows 10
Sent: Wednesday, September 25, 2019 12:49 AM
To: allegro-list(at)matronics.com (allegro-list(at)matronics.com)
Subject: Re: ADS-B
--> Allegro-List message posted by: "ishadatta" <isha.datta2052(at)gmail.com>
http://forums.matronics.com/viewtopic.php?p=491464#491464
_-= Same great content also available via the Web Forums!
Brian Carpenter
PostPosted: Fri Sep 27, 2019 7:39 am    Post subject: ADS-B Reply with quote
[img]cid:2B5F5C84-FC59-4AD2-956A-BAEAADD42858[/img]
The echoUAT Might make for a much more simple install. Also 1399 with the dash mounted GPS receiver antenna combo.!
Brian Carpenter
N3081X
On Sep 25, 2019, at 05:59, Hugh McKay <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)> wrote:
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
Subject: Allegro-List: Re: ADS-B
--> Allegro-List message posted by: "ishadatta" <isha.datta2052(at)gmail.com (isha.datta2052(at)gmail.com)>
 Filesize:  344.04 KB
 Viewed:  18668 Time(s)
BRIAN N3081X
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
