rngurley(at)att.net Guest
Posted: Tue Apr 16, 2019 9:21 am Post subject: Water resistant D-Sub |
Does anyone have a suggestion for a water resistant or waterproof D-Sub connector where the pins are crimped? I am looking for 5 – 9 pins.
Thank you for your assistance
billhuntersemail(at)gmail Guest
Posted: Tue Apr 16, 2019 10:59 am Post subject: Water resistant D-Sub |
| Quote: | Does anyone have a suggestion for a water resistant or waterproof D-Sub
connector where the pins are crimped? I am looking for 5 - 9 pins.
So am I. Can someone PLEASE suggest a product?
Posted: Tue Apr 16, 2019 11:51 am Post subject: Water resistant D-Sub |
At 01:57 PM 4/16/2019, you wrote:
| Quote: | > Does anyone have a suggestion for a water resistant or waterproof D-Sub connector where the pins are crimped? I am looking for 5 – 9 pins.
So am I. Can someone PLEASE suggest a product? |
There is a mil-qualified 'environmental'
series of d-subs. See page 364 of this
catalog
http://aeroelectric.com/Mfgr_Data/Connectors/ITT_Cannon/Military_Aerospace.pdf
What's the application here? Why 'water
proof' in a d-sub?
henador_titzoff(at)yahoo. Guest
Posted: Tue Apr 16, 2019 3:04 pm Post subject: Water resistant D-Sub |
Try this link for NorComp Seal-D D-sub connectors that meet IP66 or IP67. You always have to specify a standard, because otherwise you don't know what you'll get.
Newark, Mouser, Digi-Key and other distributors carry them.
Waterproof D-Sub | IP67/IP68 Rated | NorComp
Search a full range of waterproof d-sub connectors used in a variety of harsh environments & demanding end-use a...
Henador Titzoff
On Tuesday, April 16, 2019, 1:36:09 PM EDT, Richard Gurley <rngurley(at)att.net> wrote:
cluros(at)gmail.com Guest
Posted: Tue Apr 16, 2019 6:59 pm Post subject: Water resistant D-Sub |
https://www.youtube.com/watch?v=qzc4mtFmmHo Â
On Tue, Apr 16, 2019 at 12:56 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Â
 catalog
 proof' in a d-sub?
Posted: Wed Apr 17, 2019 8:06 am Post subject: Water resistant D-Sub |
At 06:03 PM 4/16/2019, you wrote:
| Quote: | Try this link for NorComp Seal-D D-sub connectors that meet IP66 or IP67. You always have to specify a standard, because otherwise you don't know what you'll get.
Henador Titzoff
Cool find! Thank you.
Posted: Wed Apr 17, 2019 11:58 am Post subject: Water resistant D-Sub |
THANKS Bob!!!
I bought these DB15 type connectors and I understand the concept of
installing the back shell with the male thumbscrews to connect to an
accessory such as my Lightspeed III ignition module.
What I am not clear on is how to connect the male D-Sub to a female D-Sub
inline with each having a back shell and one with a male thumb screw and the
second with a female threaded nut.
Example: I have a Dynon GPS antenna mounted to a removeable hatch and I
want to be able to unbolt the hatch and then disconnect the two D-Sub
connectors that connect the ships wiring to the antenna and then remove the
hatch.
Right now I the two connectors do not have a back shell and when I mate the
two connectors I secure them togher with a tie wrap on each side through the
holes that the thumbscrew should go through.simple, lightweight, low tech,
and secure however not very professional.
argoldman(at)aol.com Guest
Posted: Wed Apr 17, 2019 2:30 pm Post subject: Water resistant D-Sub |
Bill, there are little female connectors (basically nuts) that you can screw both the affixing screws into joining the two shells together. Suggested to use thread locker with these. I think B&C carries them.
S8013-hex
Rich
In a message dated 4/17/2019 2:59:22 PM Central Standard Time, billhuntersemail(at)gmail.com writes:
THANKS Bob!!!
I bought these DB15 type connectors and I understand the concept of installing the back shell with the male thumbscrews to connect to an accessory such as my Lightspeed III ignition module.
What I am not clear on is how to connect the male D-Sub to a female D-Sub inline with each having a back shell and one with a male thumb screw and the second with a female threaded nut.
Example: I have a Dynon GPS antenna mounted to a removeable hatch and I want to be able to unbolt the hatch and then disconnect the two D-Sub connectors that connect the ships wiring to the antenna and then remove the hatch.
Right now I the two connectors do not have a back shell and when I mate the two connectors I secure them togher with a tie wrap on each side through the holes that the thumbscrew should go through…simple, lightweight, low tech, and secure however not very professional…
Bill Hunter
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of Robert L. Nuckolls, IIISent: Wednesday, April 17, 2019 9:05 AMTo: aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)Subject: Re: Water resistant D-Sub
At 06:03 PM 4/16/2019, you wrote: | Quote: |
Try this link for NorComp Seal-D D-sub connectors that meet IP66 or IP67. You always have to specify a standard, because otherwise you don't know what you'll get.Newark, Mouser, Digi-Key and other distributors carry them.Waterproof D-Sub | IP67/IP68 Rated | NorComp Waterproof D-Sub | IP67/IP68 Rated | NorComp
Search a full range of waterproof d-sub connectors used in a variety of harsh environments & demanding end-use a...Henador Titzoff |
Posted: Wed Apr 17, 2019 3:24 pm Post subject: Water resistant D-Sub |
At 05:29 PM 4/17/2019, you wrote:
| Quote: | Bill, there are little female connectors (basically nuts) that you can screw both the affixing screws into joining the two shells together. Suggested to use thread locker with these. I think B&C carries them.
S8013-hex |
Yeah. Looks like these
[img]cid:7.1.0.9.0.20190417182319.054d98d8(at)aeroelectric.com.0[/img]
Got a boat load. Send me an address and
quantity needed. I'll drop them in the mail.
167.55 KB |
10082 Time(s) |
ceengland7(at)gmail.com Guest
Posted: Wed Apr 17, 2019 6:13 pm Post subject: Water resistant D-Sub |
On 4/17/2019 6:24 PM, Robert L. Nuckolls, III wrote:
S8013-hex |
Bob . . . | I really like Dsubs, but I really hate the standard attachment method (tiny, sloppily slotted screws). For some chassis mounts, and most in-line pairs, I really like 'bale' style latches. Here's one source:
https://www.google.com/url?sa=i&source=images&cd=&cad=rja&uact=8&ved=2ahUKEwjYlKi7xNjhAhXLTN8KHfiPCrsQjRx6BAgBEAU&url=https%3A%2F%2Fwww.newark.com%2Fcooper-interconnect%2F17-529%2Fd-sub-spring-latch%2Fdp%2F39F1390&psig=AOvVaw064bp5kfjSPGEFC3WoLuOE&ust=1555638852183307
May require modifying the backshell slightly.
Posted: Wed Apr 17, 2019 6:15 pm Post subject: Water resistant D-Sub |
Beg to differ, Bob.
The devices to which I referred were totally of the female gender persuasion. The ones that you showed are male on one side and female on the other.
Not so my suggestion. Both sides are female with opposite threads and are sized to hold two sub ds together. See b& c catalog with the stock number that I indicated (unless I was dyslexic when I copied the number. )
Rich
On Apr 17, 2019, at 6:24 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
S8013-hex |
<15f5306.jpg>
echristley(at)att.net Guest
Posted: Wed Apr 17, 2019 6:29 pm Post subject: Water resistant D-Sub |
That's what I'm using on my firewall to engine sensor bundle connector. Keep in mind that these won't fit on all shells. I actually have a bag full of shells now.
On Wednesday, April 17, 2019, 7:14:24 PM MST, Charlie England <ceengland7(at)gmail.com> wrote:
| Quote: | At 05:29 PM 4/17/2019, you wrote: | Quote: | | Bill, there are little female connectors (basically nuts) that you can screw both the affixing screws into joining the two shells together. Suggested to use thread locker with these. I think B&C carries them. S8013-hex | Yeah. Looks like these Got a boat load. Send me an address and quantity needed. I'll drop them in the mail.
Bob . . . |
I really like Dsubs, but I really hate the standard attachment method (tiny, sloppily slotted screws). For some chassis mounts, and most in-line pairs, I really like 'bale' style latches. Here's one source: https://www.google.com/url?sa=i&source=images&cd=&cad=rja&uact=8&ved=2ahUKEwjYlKi7xNjhAhXLTN8KHfiPCrsQjRx6BAgBEAU&url=https%3A%2F%2Fwww.newark.com%2Fcooper-interconnect%2F17-529%2Fd-sub-spring-latch%2Fdp%2F39F1390&psig=AOvVaw064bp5kfjSPGEFC3WoLuOE&ust=1555638852183307 May require modifying the backshell slightly. Charlie Virus-free. www.avast.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
Posted: Thu Apr 18, 2019 7:13 am Post subject: Water resistant D-Sub |
Thanks Bob for your kind offer! I already ordered some from Amazon Aircraft
Supply but I greatly appreciate the offer and all of the advice
Bill Hunter
S8013-hex
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=icon> Virus-free
