Foam wing; uk approved nav light fixing method
graeme bird
PostPosted: Sat Apr 13, 2019 11:45 pm    Post subject: Foam wing; uk approved nav light fixing method Reply with quote
I want to put strobes/nav lights on my classic wing tips and, from the forum note that wire routing via aileron recess might be best, drilling from there to the wing tip. Can anyone, having obtained UK LAA approval for such a mod, or similar, say what they needed to do to get the light mounting approved; I am thinking that bonding a shaped aluminium plate with redux and holding wih cleos while bonding might be approved.
The part built kit I obtained has wiring and a mount to a fin top strobe but that will prevent me getting it in my trailer!
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
carlp101
PostPosted: Sun May 05, 2019 10:35 am    Post subject: Re: Foam wing; uk approved nav light fixing method Reply with quote
Hi Graham,
I fixed nav/strobe lights to my Europa foam wings. Check out the latest Europa Flyer. I wrote an article about getting my bird IMC & night approved. This includes a description of how I routed the cable. The LAA mod number is 14396 - Strobes and nav lights (attached).
Carl
LAA-MOD 3 - Wing Tip Strobes Mod Application - Signed.pdf
 Filename:  LAA-MOD 3 - Wing Tip Strobes Mod Application - Signed.pdf
 Filesize:  2.01 MB
 Downloaded:  450 Time(s)
