S700-2-50 switch
pelletie1959(at)me.com
PostPosted: Thu Apr 11, 2019 3:23 pm    Post subject: S700-2-50 switch Reply with quote
Hi,
I perform the Z-16 diagram from Bob and I use the S700-2-50 switch suggest by Bob to light the ignition and the starter contactor. I have some problems with the wiring of that switch. Somebody have a wiring diagram for that switch. And is it possible to get the same result with the S700-2-51 switch which have only 4 poles.
Daniel Pelletier
PostPosted: Thu Apr 11, 2019 4:26 pm    Post subject: Re: S700-2-50 switch Reply with quote
Will this diagram help?
https://mid-8704.kxcdn.com/wp-content/uploads/2016/05/2-50-Typical-use-PMAG-POWER-TEST-drawing.pdf
Joe Gores
PostPosted: Fri Apr 12, 2019 9:46 am    Post subject: S700-2-50 switch Reply with quote
Not really,
I've yet thi diagram. Maybe I don't understand this diagram. When I flip the switch on the momentary, the starter contactor is on but the ignition is off. It doesn't make sense.
Daniel Pelletier
Envoyé de mon iPad
Joe Gores
http://forums.matronics.com/viewtopic.php?p=488676#488676
PostPosted: Fri Apr 12, 2019 10:57 am    Post subject: Re: S700-2-50 switch Reply with quote
We need more information. Do you have a Rotax 912ULS engine?
If not, what engine?
Does it have magnetos?
Can you post a picture that shows how the wires are connected?
I would use 3 separate switches like diagram Z-20.
1 momentary switch for starting.
2 separate ignition switches.
Joe Gores
steerr(at)bellsouth.net
PostPosted: Fri Apr 12, 2019 11:11 am    Post subject: S700-2-50 switch Reply with quote
That's what I did for the Hirth 3202 on my Excalibur.  The two separate
ignition switches, and the pushbutton start switch, are wired so that
both ignition switches must be on for the start switch to work.
I would use 3 separate switches:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=488691#488691
This email has been checked for viruses by AVG.
https://www.avg.com
PostPosted: Fri Apr 12, 2019 4:56 pm    Post subject: S700-2-50 switch Reply with quote
I have a 912 uls. I use this setup of switch at the suggestion of Bob, see note 2 in the Z16 diagram. But there is no pattern for that type of switch in the Z16 schema. If I can find the way to plug it, I will use a distinct start button and two separate switch for ignition.
Daniel Pelletier
Envoyé de mon iPad
Le 12 avr. 2019 à 15:11, Bill Steer <steerr(at)bellsouth.net> a écrit :
That's what I did for the Hirth 3202 on my Excalibur. The two separate ignition switches, and the pushbutton start switch, are wired so that both ignition switches must be on for the start switch to work.
> Joe Gores
https://www.avg.com
PostPosted: Fri Apr 12, 2019 7:10 pm    Post subject: Re: S700-2-50 switch Reply with quote
Below is a drawing showing how to connect ignition switches and start switch.
 Filesize:  40.35 KB
 Viewed:  6171 Time(s)
Joe Gores
