Shutters cable
cerveirapinto(at)gmail.co
PostPosted: Thu Mar 28, 2019 3:45 am    Post subject: Shutters cable Reply with quote
Hi there
Does anyone know if the cable that opens and close the shutters of the engine can be replaced by a marine teleflex cable?
Pedro Cerveira Pinto
dougsappllc(at)gmail.com
PostPosted: Thu Mar 28, 2019 5:51 am    Post subject: Shutters cable Reply with quote
Are you looking for shutter cable for CJ or Yak?  If CJ I have them in stock, if for Yak may be the same, I do not know for sure.
Doug
On Thu, Mar 28, 2019 at 4:49 AM Pedro Cerveira Pinto <cerveirapinto(at)gmail.com (cerveirapinto(at)gmail.com)> wrote:
Hi there
PostPosted: Thu Mar 28, 2019 6:19 am    Post subject: Shutters cable Reply with quote
Looking for yak 52
A quinta, 28/03/2019, 13:57, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> escreveu:
Doug
Hi there
hkgibby(at)yahoo.com
PostPosted: Thu Mar 28, 2019 6:21 am    Post subject: Shutters cable Reply with quote
Pedro-
Yes you can;  I have for both the shutter and prop Gov control. Email me directly for more pics and details if you decide to do it. The Universal ends can take the metric chinee/Rusky metric connector as it is 10/32 which is close enough for metric M4 or M5, can’t remember. Trickiest part for the shutters is the cockpit connection and whether you keep the Chinese/Russian control knob/lever mechanism.
https://www.greatlakesskipper.com/teleflex-tfxtreme-3300-33c-boat-control-cable-ccx63322-22-foot-134809?utm_source=google&utm_medium=cpc&adpos=1o4&scid=scplp8201349&sc_intid=8201349&gclid=EAIaIQobChMIq9_B0_yk4QIVwh-tBh2fCwHyEAUYBCABEgKpGvD_BwE
[img]cid:4E900DF5-DBDD-4E83-BDFE-7AEFF117427E[/img]
[img]cid:726F9A3C-51E9-46B5-AA29-54CA21DC223F[/img]
On Mar 28, 2019, at 4:44 AM, Pedro Cerveira Pinto <cerveirapinto(at)gmail.com (cerveirapinto(at)gmail.com)> wrote:
Hi there
=================================== //www.matronics.com/Navigator?Yak-List =================================== cs.com =================================== om =================================== matronics.com/contribution ===================================
 Filesize:  679.75 KB
 Viewed:  20329 Time(s)
 Filesize:  667.47 KB
PostPosted: Thu Mar 28, 2019 8:35 am    Post subject: Shutters cable Reply with quote
Measure the OD of the tube and the overall length and give me a call  509-826-4610
Doug
On Thu, Mar 28, 2019 at 7:24 AM Pedro Cerveira Pinto <cerveirapinto(at)gmail.com (cerveirapinto(at)gmail.com)> wrote:
Looking for yak 52
Doug
Hi there
dsavarese0812(at)bellsout
PostPosted: Thu Mar 28, 2019 10:03 am    Post subject: Shutters cable Reply with quote
My experience says the CJ cable, even if it may have the same ends on it, will be too long because the CJ cooling louver control is on the left side of the instrument panel. Whereas the Yak 52's control lever is on the right front console. The total length of the Yak 52 cable is going to be much shorter.
Dennis
On Thursday, March 28, 2019, 12:37:27 PM EDT, doug sapp <dougsappllc(at)gmail.com> wrote:
Doug
Looking for yak 52
Doug
Hi there
-- Pedro Cerveira Pinto
PostPosted: Thu Mar 28, 2019 10:19 am    Post subject: Shutters cable Reply with quote
Dennis,Good to know.  No Yaks nearby for me to check.
I have in the past fabricated a new outer sheath out of copper tubing.  As I'm sure you know 99% of the time there is nothing wrong with the inner cable, the issue is that the outer sheath is kinked/dented and is binding on the inner cable or the threaded rod ends which are swaged onto both ends of the cable.  Bugger is getting the old sheath off the cable without screwing it up.
Doug
On Thu, Mar 28, 2019 at 11:07 AM A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
Dennis
On Thursday, March 28, 2019, 12:37:27 PM EDT, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
Doug
Looking for yak 52
Doug
Hi there
kingcj6(at)aol.com
PostPosted: Thu Mar 28, 2019 10:28 am    Post subject: Shutters cable Reply with quote
Depending on the year of manufacture, some CJ's have the control on the right side.
Dave
In a message dated 3/28/2019 11:03:50 AM Pacific Standard Time, dsavarese0812(at)bellsouth.net writes:
Dennis
Doug
Looking for yak 52
Doug
Hi there
PostPosted: Thu Mar 28, 2019 10:40 am    Post subject: Shutters cable Reply with quote
"there is nothing wrong with the inner cable, the issue is that the outer sheath is kinked/dented and is binding on the inner cable,,,"
That is exactly the problem Doug.
doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> escreveu no dia quinta, 28/03/2019 à(s) 18:23:
Doug
Dennis
Doug
Looking for yak 52
Doug
Hi there
PostPosted: Thu Mar 28, 2019 10:42 am    Post subject: Shutters cable Reply with quote
Doug,
You absolutely hit the nail on the head regarding the sheath.
Dennis
On Thursday, March 28, 2019, 2:21:35 PM EDT, doug sapp <dougsappllc(at)gmail.com> wrote:
Doug
Dennis
Doug
Looking for yak 52
Doug
Hi there
PostPosted: Thu Mar 28, 2019 11:16 am    Post subject: Shutters cable Reply with quote
The sheath could be replaced with most any ridged tubing material of the proper ID/OD.  I used copper tubing which I purchased at the local hardware.
Doug
On Thu, Mar 28, 2019 at 11:47 AM A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
Doug,
Dennis
On Thursday, March 28, 2019, 2:21:35 PM EDT, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
Doug
Dennis
Doug
Looking for yak 52
Doug
Hi there
PostPosted: Thu Mar 28, 2019 11:27 am    Post subject: Shutters cable Reply with quote
I've done exactly the same thing Doug. The real problem is removing the cable from the sheath when the sheath has been kinked badly.
McMaster Carr sells 8mm ID copper tubing.
Dennis
On Thursday, March 28, 2019, 3:19:03 PM EDT, doug sapp <dougsappllc(at)gmail.com> wrote:
Doug
Doug,
Dennis
Doug
Dennis
Doug
Looking for yak 52
Doug
Hi there
PostPosted: Thu Mar 28, 2019 11:33 am    Post subject: Shutters cable Reply with quote
DougThanks I believe that is a proper solution.
Copper or aluminum tube depending on what we can find locally.
A quinta, 28/03/2019, 19:22, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> escreveu:
Doug
Doug,
Dennis
Doug
Dennis
Doug
Looking for yak 52
Doug
Hi there
wlannon(at)shaw.ca
PostPosted: Thu Mar 28, 2019 7:45 pm    Post subject: Shutters cable Reply with quote
Just to complicate matters further the CJ cooling (warming?) control is on both the LH front sub inst. panel and on the RH front console!
Early CJ models like mine (Batch 15, 1965/66) had it on the RH console, later models on the LH panel. When the change was made I do not know. Also should be noted that the control mechanism in the handle assy. is reversed to accommodate the different location so that item is not interchangeable.
Obviously the cable and housing lengths will be different.
Cheers;
Walt
From: A. Dennis Savarese (dsavarese0812(at)bellsouth.net) Sent: Thursday, March 28, 2019 11:02 AM
Subject: Re: Shutters cable
Dennis
Doug
Looking for yak 52
Doug
Hi there
n13472(at)aol.com
PostPosted: Thu Mar 28, 2019 8:22 pm    Post subject: Shutters cable Reply with quote
use a tubing cutter (small one) and piece out the tubbing. then the bent / kinked part will be a very
small section then slit it with a dermal tool cut off wheel!
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV.
89019
Cell 541-297-5497
N13472(at)AOL.COM
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: Thursday, March 28, 2019 12:26 PM
To: yak-list(at)matronics.com
Subject: Re: Yak-List: Shutters cable
Dennis
Doug
Doug,
Dennis
Dennis,
Doug
Dennis
Doug
Looking for yak 52
Doug
Hi there
Virus-free. www.avg.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
glipaz
PostPosted: Thu Mar 28, 2019 9:13 pm    Post subject: Re: Shutters cable Reply with quote
Great discussion. My previous CJ 1966 had the control on the left front panel. My new CJ 1965 has it on the right hand lower panel.
Question: I have seen a couple examples where the control knob and mechanism were replaced with a vernier style controller. Anyone have any experience with that?? I am wanting to replace mine since it is rough on the knuckles opening and closing!
Gil
cjpilot710(at)aol.com
PostPosted: Fri Mar 29, 2019 4:21 am    Post subject: Shutters cable Reply with quote
NOW THAT I DIDN'T KNOW. 24 years I've owned my CJ and I still learn something new from you guys! Thanks Walt! Jim "Pappy" Goolsby
PS I've sold my girl. Sad
Viperdoc
PostPosted: Fri Mar 29, 2019 6:25 am    Post subject: Shutters cable Reply with quote
Bugger is right. I had to use a grinder to thin the copper tubing to paper thin. I then used a chisel that I ground the tip down to sharp edge. The lightly skived the chisel along the thin wall splitting the cable. Usely the cable is gummed up along its shaft in the curve of the cable housing from oil and dirt. Doc
On Mar 28, 2019, at 1:18 PM, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
Doug
Dennis
Doug
Looking for yak 52
Doug
Hi there
Viperdoc
hill(at)doctor-hill.com
PostPosted: Fri Mar 29, 2019 8:35 am    Post subject: Shutters cable Reply with quote
As an alternative, you can have a speedometer repair shop custom make cables for you. This is what I did for the M-14P prop governor cable and the gill shutters cable. Works better than the original control cables on the CJ. Unfortunately, not every city has a shop that offers this type of service. Something additional to consider.
Warren Hill
N464TW
Mesa, AZ
On Mar 29, 2019, at 7:00 AM, Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> wrote:
Bugger is right. I had to use a grinder to thin the copper tubing to paper thin. I then used a chisel that I ground the tip down to sharp edge. The lightly skived the chisel along the thin wall splitting the cable. Usely the cable is gummed up along its shaft in the curve of the cable housing from oil and dirt. DocSent from my iPad
Doug
Dennis
Doug
Looking for yak 52
Doug
Hi there
Viperdoc
PostPosted: Sat Mar 30, 2019 6:05 pm    Post subject: Shutters cable Reply with quote
Correction: the chisel was skived parallel along the cable to split the copper housing.Doc
On Mar 29, 2019, at 9:00 AM, Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> wrote:
Doug
Dennis
Doug
Looking for yak 52
Doug
Hi there
Viperdoc
