TR1
tomreeder1(at)icloud.com
PostPosted: Mon Mar 25, 2019 8:20 am    Post subject: TR1 Reply with quote
I have recently purchased a TR1 with a can air power unit which overall has been quite unreliable for the previous owner. I intend to fit a continental 0200 with crossfloe cylinders, any info or advice would be gratefully recieved,,, thanks Tom
aeromomentum(at)yahoo.com
PostPosted: Mon Mar 25, 2019 9:19 am    Post subject: TR1 Reply with quote
Hi Tom,
I would suggest the Lycoming O-235 over the Continental O-200. The added power is very important. My TR-1 was powered by a 125hp high compression O-235 and I found the performance to be ok in climb but good in cruise. My guess is the O-200 would be ok in cruise but marginal in climb. But what works for you may be different.
My company (aeromomentum.com) offers new engines based on Suzuki that are dyno and flight proven that would work well in the TR-1.
Mark Kettering
On Mon, 3/25/19, Thomas Reeder <tomreeder1(at)icloud.com> wrote:
Subject: TR1
To: kis-list(at)matronics.com
Date: Monday, March 25, 2019, 12:07 PM
The KIS-List Email Forum -
Navigator to browse
List Un/Subscription,
7-Day Browse, Chat, FAQ,
    - MATRONICS WEB FORUMS -
via the Web Forums!
    - NEW MATRONICS LIST WIKI -
Email List Wiki!
  - List Contribution Web Site -
support!
gbrighton(at)skymesh.com.
PostPosted: Tue Mar 26, 2019 8:41 pm    Post subject: TR1 Reply with quote
Howdy Tom,
Further to Marks reply ... 100 HP wont allow u to
see the TR1 performance potential .. too under powered .., good luck with ur
decisions .. Lets know what u decide and how it goes plz ..,
Cheers
Graham
TR1 # 80
Sent: Tuesday, March 26, 2019 4:06 AM
To: <kis-list(at)matronics.com>; <tomreeder1(at)icloud.com>
Subject: Re: TR1
Hi Tom,
Mark Kettering
Subject: TR1
Navigator to browse
via the Web Forums!
Email List Wiki!
support!
This email has been checked for viruses by AVG.
https://www.avg.com
randy.ott(at)gmail.com
PostPosted: Wed Mar 27, 2019 10:41 am    Post subject: TR1 Reply with quote
O320 is the only way to go! Please don’t even consider 0200!
On Mar 26, 2019, at 9:38 PM, Graham Brighton <gbrighton(at)skymesh.com.au> wrote:
Howdy Tom,
Further to Marks reply ... 100 HP wont allow u to see the TR1 performance potential .. too under powered .., good luck with ur decisions .. Lets know what u decide and how it goes plz ..,
Cheers
Graham
TR1 # 80
Subject: Re: TR1
> Hi Tom,
> Mark Kettering
> Subject: TR1
> Sent from my iPhone
> Navigator to browse
> via the Web Forums!
> Email List Wiki!
> support!
> https://www.avg.com
Keith.Miller(at)esa.int
PostPosted: Tue Apr 02, 2019 6:13 am    Post subject: TR1 Reply with quote
Thomas
The switch to the 0-200 is certainly going to be more reliable that the CAM , which i know has had its issues in your KIS over the years, since it was made way back in the 90's , But like others I would recommend going a bit bigger than the O-200, if you have the chance.
The KIS will likely be still under powered on Grass at MTOW, with 100HP. Having said that we had a 0-200 powered in the UK (G-OKPW) which operated for a number of years very successfully, (before the owner/ builder switched it out to a JABIRU 6) , The good news is it will be easy getting LAA approval, for the change from the CAM to the O-200.
Note : LAA has also approved the 0-235 Lyc , TCM IO-240, TCM O-240, and the JABIRU 6. (knowing the LAA, unless you want to do lots of paperwork , i would not recommend going with any other unit)
Keith
G-OKMA
[img]cid:1__=4EBB0943DFD911618f9e8a93df938690(at)esa.int[/img]Thomas Reeder ---25/03/2019 17:30:49-----> KIS-List message posted by: Thomas Reeder <tomreeder1(at)icloud.com> I have recently purchased a TR
Date: 25/03/2019 17:30
Subject: TR1
Sent by: owner-kis-list-server(at)matronics.com
matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
MS -
ms.matronics.com">http://forums.matronics.com
.matronics.com">http://wiki.matronics.com
e -
matronics.com/contribution">http://www.matronics.com/contribution
This message is intended only for the recipient(s) named above. It may contain proprietary information and/or
protected content. Any unauthorised disclosure, use, retention or dissemination is prohibited. If you have received
this e-mail in error, please notify the sender immediately. ESA applies appropriate organisational measures to protect
personal data, in case of data privacy queries, please contact the ESA Data Protection Officer (dpo(at)esa.int).
 Filesize:  105 Bytes
 Viewed:  9235 Time(s)
PostPosted: Tue Apr 02, 2019 6:27 am    Post subject: TR1 Reply with quote
Thanks for the input, it has cross flow heads and I intend to fit hc pistons this should up the rating a little. Tom
On 2 Apr 2019, at 15:13, Keith.Miller(at)esa.int (Keith.Miller(at)esa.int) wrote:
Thomas
Keith
G-OKMA
<graycol.gif>Thomas Reeder ---25/03/2019 17:30:49-----> KIS-List message posted by: Thomas Reeder <tomreeder1(at)icloud.com (tomreeder1(at)icloud.com)> I have recently purchased a TR
From: Thomas Reeder <tomreeder1(at)icloud.com (tomreeder1(at)icloud.com)>
Subject: TR1
Sent by: owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com)
MS -
e -
personal data, in case of data privacy queries, please contact the ESA Data Protection Officer (dpo(at)esa.int (dpo(at)esa.int)).
