Viperdoc
Posted: Sun Mar 24, 2019 12:28 pm Post subject: Covering ailerons questions. |
Anybody covering ailerons. The mounting points and the push rod connection points are a problem damning up. See my attached email for pictures and please give your thoughts. I need a foam that is not destroyed by MEK. Thanks
Doc
Begin forwarded message:
Sent a different way after being rejected.Doc
| Quote: | What type foam is used for damming and adding form to the push rod attachment points on the aileron. The foam is high density. It does not dissolve when exposed to organics specifically MEK (methylethyl ketone).
[img]cid:0E244017-79F1-4E87-828A-40BD3E0DC16F[/img]
[img]cid:FAB74D12-191A-471D-AD90-DED7D9DC1ECC[/img]
[img]cid:E123C7DD-23AB-449D-917C-F60489FB1798[/img]
315.3 KB |
1993 Time(s) |
347.16 KB |
1993 Time(s) |
322.68 KB |
1993 Time(s) |
_________________ Viperdoc |
