		| Author | Message |
		| brian
				|  Posted: Tue Jan 17, 2006 9:51 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| Roger Kemp wrote:
  	  | Quote: |  	  |
 Brian,
 Best check again on the nitrogen Narcosis thing at altitude It happens.
 It is called decompression sickness.
 Go read your books again. Nitrogen narcosis is a malady that occurs when
 too much N2 is dissolved in the tissues, especially the tissues of the
 nervous system. The symptoms are similar to drunkenness but
 hallucination is not uncommon. Divers who are "narc'd" have been known
 to offer their regulator mouthpiece to passing fish. When N2 is
 dissolved in the tissues it isn't coming out in bubbles.
 When the body then decompresses again if it is done too quickly, the N2
 can come out of the tissue in bubbles. These tend to lodge in the joints
 and cause pain which often causes the victim to contort him/herself in
 an attempt to relieve the pain, hence the term "the bends". The official
 name for this malady is decompression sickness. This is a completely
 different malady from nitrogen narcosis. Both involve nitrogen, both
 involve pressure change, but the pathology is different as are the symptoms.
  	  | Quote: |  	  | The treatment for it is recompression in a dive chamber.
 The treatment for decompression sickness is to increase the pressure
 again so that the N2 goes back into solution in the blood and tissues.
 The prevention of decompression sickness is to reduce the pressure
 gradually so that the excess N2 in the tissues can stay in solution and
 move into the bloodstream where it can move to the lungs and be exhaled.
  	  | Quote: |  	  | I  have had to fly two military aviators to the chamber one at Brooks, AFB and the other was at Beale AFB. Both  had to be flown
 with the cabin pressurized to sea level because of the risk of worsening
 the decompression sickness. One of those pilots was my Squadron cc. He had
 a gradual cabin pressure leak due to a slow leaking canopy seal.
 Had he been diving? Remember, the pressure change going from sea level
 to FL250 is less than the pressure change from the surface to 30 feet
 underwater. I suppose it is possible for someone to get decompression
 sickness loss of cabin pressure but a slow leak is unlikely to cause the
 problem. I am not saying it can't happen but I am skeptical unless there
 was some other mechanism acting to raise the level of N2 in the tissue.
 Living at sea level is not likely to cause enough N2 to dissolve in the
 blood to cause the bends to happen at FL250, especially if the pressure
 drops gradually.
  	  | Quote: |  	  | There are two ways to get the "Bends."  One is from decompression and the other is from compression.
 Sorry, no. The Bends occur *only* on decompression. Compression just
 causes more N2 to dissolve in the tissues. If the person is suffering
 from The Bends recomressing him/her causes the N2 bubbles to go back
 into solution. Once that happens you can begin slow decompression thus
 allowing the N2 to slowly and safely move from the tissue to the blood
 to the lungs and then be exhaled.
  	  | Quote: |  	  | In either case, N2 comes out of solution in blood.
 No, it doesn't. It *only* does that on decompression, hence the name
  	  | Quote: |  	  | It  coleses into gas bubbles in the tissue. Most commonly in an injured joint. It also can happen in the spinal cord, brain (neurological
 nitrogen narcosis), and the pulmonary tree. (the chokes). That is putting
 it in simple terms.
 You are describing only decompression sickness. You also called it
 nitrogen narcosis which it isn't. Now nitrogen narcosis does happen when
 you compress the body in the presence of N2. The greater the pressure,
 the greater the symptoms of narcosis.
 This is why divers use special breathing gasses that reduce or eliminate
 the N2 in the breathing mix (heliox or nitrox) -- so that they are less
 likely to experience narcosis while down and less likely to experience
 The Bends upon ascending.
  	  | Quote: |  	  | In otherwords, every time you take that unpressurised twin above FL 180, you are at risk for for developing the "bends".
 Any time you reduce the pressure on the body there is some chance of
 developing decompression sickness. OTOH, the chance is very, very,
 *VERY* small for people living at sea level or above who don't dive and
 smaller still if the pressure change is gradual, i.e. standard rates of
 ascent and not explosive decompression. I think if you go back and
 research this you will find that this is an *extremely* rare event.
 As a pilot who spent three years operating in the Virgin Islands who
 dives and flies, I am *VERY* aware of the dangers from rapid pressure
 changes and of going directly from a dive to a flight in an airplane.
 For safety we use a rule of thumb of 24 hours between a decompression
 dive to a flight because we know that even after a successful and safe
 decompression dive, the tissues are still saturated to a higher level of
 N2 than someone who has not been diving. The extra 24 hours allows the
 body to come back to equilibrium before flying. My rule of thumb is
 that, if you have been diving today, we don't fly until tomorrow.
 So, yeah, I have some idea how all this works. The threat is vanishingly
 small compared to what you are implying unless you have been diving and
 then the threat is very real.
 And nitrogen narcosis is NOT decompression sickness.
 Brian Lloyd                         2243 Cattle Dr.
 brian-yak at lloyd dot com          Folsom, CA 95630
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 - Antoine de Saint-Exupery
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
 Brian Lloyd
		| Back to top |  |
		| brian
				|  Posted: Tue Jan 17, 2006 10:18 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| But don't take my word for it. Here is a really good article on what
nitrogen narcosis is.
 http://en.wikipedia.org/wiki/Nitrogen_narcosis
 Brian Lloyd
		| Back to top |  |
		| cjpilot710(at)aol.com Guest
				|  Posted: Wed Jan 18, 2006 5:27 am    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| Frankly I don't see any  difference except by degree.
 You takeoff and go up -  - you decompress.
 You come down to  land  - -  you compress.
 You jump in the water  and go down - -  you compress.
 You (hopefully) bob to  the surface - - you decompress.
 Now you can never go  deeper (there is a bottom) than you go high (a vacuum mean decompress  right?  Boy, I bet that would hurt ).
 But water is thicker  than air, sooooooo it would have more effect per foot than air.
 But how fast you go up  in the air would have the same effect as if you went up to fast in water?   So a guy is sitting in a rocket is going to have the same effect on him as  a guy coming up from the bottom of the ocean?
 Hmmmmmmmmmmmmmmm
 Gee I'm being to see  what that old fart ment: "If God want man to swim He'd given him fins and he  were suppose to fly He'd given him feathers.  Dearn  foolishness!"
 FD44- CAVU, brisk  breeze from the NW, 55 F on the patio.
 Jim " Pappy"  Goolsby
		| Back to top |  |
		| viperdoc(at)mindspring.co Guest
				|  Posted: Wed Jan 18, 2006 7:11 am    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| Well Pappy, in your infinite wisdom you have boiled the issue of altitude verses diving decompression sickness down to its essence. Brilliant! As I was prepared to condense the 1st 8 chapters of Fundamentals of Aerospace Medicine Third Edition, Roy L. DeHart  M.D. MPH, M.S.I.A., pp.1-161, Diving Medicine Second Edition, Alfred A. Bove, M.D. and Jefferson C. Davis, M.D., pp. 5-47, The Society of United States Air Force Flight Surgeons Check List,revised biannually by the USAFSAM residents- 5th edition, pp 83-85 (the down and dirty version) for a discussion of decompression sickness Type I and Type II. But, Pappy since you so eloquently boiled this topic down to its essence, I will refrain from discussions of partial pressures of nitrogen, water, oxygen, carbon dioxide, and inert gasses at 1/2 ATA, 1/4 ATA, 0.10 ATA, 1 ATA, 2 ATA, 3 ATA, and 4 ATA. These all being common altitudes and feet of sea water that man   flying and diving are exposed to. Brian will only claim to know more.
Dogmatic Viperdoc
 Roger W. Kemp M.D.
 Col. M.C., CFS
 State Air Surgeon
 HQ ALANG
 Senior Aeromedical Examiner -FAA
 Boarded in Anesthesia and Pain Management.
 With a whole lot of alphebet following my name down.
		| Back to top |  |
		| brian
				|  Posted: Wed Jan 18, 2006 9:32 am    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| Roger Kemp wrote:
  	  | Quote: |  	  | Well Pappy, in your infinite wisdom you have boiled the issue of altitude verses diving decompression sickness down to its essence.
 _Fundamentals of Aerospace Medicine Third Edition,_ Roy L. DeHart  M.D.
 MPH, M.S.I.A., pp.1-161, _Diving Medicine_ Second Edition, Alfred A.
 Bove, M.D. and Jefferson C. Davis, M.D., pp. 5-47, _The Society of
 United States Air Force Flight Surgeons Check List_,revised biannually
 I don't claim to know more. But I do know when I am right. When I am not
 sure I look it up. When it is not a topic I have studied I let someone
 else speak in the hope that I will learn something.
 That you are an MD with a whole alphabet behind your name does not make
 you automatically correct and/or immune from making mistakes. But you
 made an error. You then compounded that error when you argue about
 correcting your error.
 You know what Doc? I don't think I am either smarter or more
 knowledgeable than you are. You don't manage to become an MD by being an
 idiot. Given that you have been trained far more than I have in this
 area I would expect you would have much more knowledge than I. But I
 make it a point to know a fair bit about the things that I do. I try to
 ensure that the information I have and that I give to my students (in
 many areas) is correct. If I discover that I am wrong I go back and make
 sure that I correct that information.
 This is actually kind of scary. There are probably people who base
 life-critical decisions on what you tell them. I now see that, when
 faced with evidence that you have made a mistake, rather than saying,
 "gee, you're right and I will correct the information," you go off and
 try to blow smoke up everyone's ass. You will belittle the source of the
 correct information in an attempt to get people to ignore the source
 rather than ensure that the others around you have the correct
 information. Yup, that is just plain ol' f----- scary.
 And Pappy is right about it all being about pressure. It is just that
 the devil is in the details. Albert Einstein one put it very succinctly
 when he said, "Things should be made as simple as possible -- and no
 simpler."
  	  | Quote: |  	  | Dogmatic Viperdoc Roger W. Kemp M.D.
 Col. M.C., CFS
 State Air Surgeon
 HQ ALANG
 Brian Lloyd
 Gadfly
 Annoying son-of-a-bitch
 Asshole
 Plain ol' guy with no alphabet after his name
 Ordinary pilot
 Ordinary CFI
 -- but right
 Brian Lloyd
		| Back to top |  |
		| Ernie
				|  Posted: Wed Jan 18, 2006 10:56 am    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| We call it being "Narced" in diving circles. Diving physiology 101.
You go deep, compress, and nitrogen disolves into your tissues, and
 you get into a druken like state due to factors beyond my knowledge.
 Decompression sickeness also called the bends, is from rapid
 de-compression and nitrogen quickly coming out of its soluable state
 and back into a gas in your arteries, shake a can of Coke and open,
 same thing occurs except its CO2 doing its thing. Those bubbles will
 can cause pain or even death due to brain embolisms.
 Being narced and the bends are 2 different things and happen at 2 ends
 of the spectrum. The only way you would get narced at altitude is if
 you were at 90,000 ft and dropped to 20,000 in about 5 seconds, but
 getting narced would be the least of your worries.
 We have dive computers and tables that we follow which tells us how
 many hours we have to wait before acending to any altitude depending
 on our dive profile, in order to avoid the bends.
 Ernie
		| Back to top |  |
				|  Posted: Wed Jan 18, 2006 12:04 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| Brian,
You are right Narcosis is a malady of descent generally below 150 feet
 ocean water. I wrote wrong the term when I was speaking of decompression.
 Both are related to Nitrogen going into and out of solution in the blood
 and tissue.
 My first statement about pre-breathing 100% O2 prior to ascending to an
 unpressurized altitude was in reference (inferred at the time) to
 decreasing the risk of altitude decompression sickness. For that you
 asserted that you can only get decompression sickness from diving. And
 there you are also wrong. I am wrong for saying Nitrogen Narcosis and you
 are wrong for asserting that decompression only comes from ascending from a
 compression dive.
 The symptoms of Nitrogen Narcosis and Neurological Decompression sickness
 can be strikingly similar. One is from descent and the effect of an
 increased partial pressure of Nitrogen and other inert gases in
 neurological tissue causing mental disorientation. Neurological
 Decompression is nitrogen bubbles forming emboli after coming out of
 solution as one ascends either from a depth of sea water or from sea level
 to altitude. In each case the the common thread is that  the the pressure
 decreased after the diver or the aviator was subjected to an increased
 atmospheric pressure.
 An aviator climbing from 1 ATA at sea level to 1/2 ATA at 18000 ft or 1/4
 ATA at 33500ft unpressurized is at an increased risk for nitrogen coming
 out of solution and forming "bubbles". The same for the diver that was at 4
 ATA ~ 100 feet of sea water (fresh water also) and ascending to the surface
 without percautionary decompression stops (not that is always protective
 either). Yes, bottom time does influence the risk of developing the
 "bends". As does other factors such as dehydration, fatigue, exercise at
 depth or exercise prior to diving.
 Nitrogen Narcosis is from the increased nitrogen in solution disrupting the
 electrical potential transfer across the pre and post synaptic cleft of the
 CNS. This most likely being in the Reticular Activating system and the
 Cortical mantle. It follows the Meyer-Overton hypothesis that states "all
 gaseous or volatile substances induce narcosis if they penetrate the lipids
 of the cell wall in a definate molar concentraion that is characaristic for
 each type of animal tissue aand approximately the same for all narcotics."
 That is measured by the mean alveolar concentration (MAC) of the anesthetic
 agent. The measure of an anesthetic concentration of an inert gas is the
 concentration of the gas at which only 50% of rats will respond to pinching
 their tail with a ring forcep. The so called MAC 50.  So that is the theory
 behind why we can give you an inhaled anesthetic at a concentration
 inspired greater than sea level concentration and induce amnesia with
 sedation for surgery.
 We are comparing Apples and Oranges here.
 Sorry Brian for mis-stating Narcosis instead of altitude decompression last
 night at 11:20.
 Doc
  	  | Quote: |  	  | [Original Message] From: Brian Lloyd <brian-yak(at)lloyd.com>
 To: <yak-list(at)matronics.com>
 Date: 1/17/2006 11:51:15 PM
 Subject: decompression sickness and narcosis (was: AYS-bound)
 Roger Kemp wrote:
 > Brian,
 happens.
  	  | Quote: |  	  | > It is called decompression sickness.
 symptoms.
  	  | Quote: |  	  | > The treatment for it is recompression in a dive chamber.
 had
  	  | Quote: |  	  | > a gradual cabin pressure leak due to a slow leaking canopy seal.
 drops gradually.
 the
  	  | Quote: |  	  | > other is from compression.
 (neurological
  	  | Quote: |  	  | > nitrogen narcosis), and the pulmonary tree. (the chokes). That is putting
  	  | Quote: |  	  | > it in simple terms.
		| Back to top |  |
		| brian
				|  Posted: Wed Jan 18, 2006 12:12 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| Ernest Martinez wrote:
  	  | Quote: |  	  | Being narced and the bends are 2 different things and happen at 2 ends of the spectrum. The only way you would get narced at altitude is if
 And if you were at 90,000' pressure altitude you would already be dead.
 Even then it wouldn't happen. It requires a partial pressure of N2 at
 about 3 BAR before you start getting enough N2 in your system to
 interfere with normal nervous system operation. Nitrogen Narcosis can
 only happen when the pressure exceeds that of being 100' deep
 underwater. It is not going to happen anywhere on or off Earth when you
 are in the atmosphere. Period.
 Nitrogen Narcosis comes from the total amount of N2 present in the blood
 and tissues. Decompression sickness comes from a too-rapid change in
 pressure during ascent/decompression. The one time I would really worry
 about decompression sickness in an airplane is during explosive
 decompression or right after a dive.
  	  | Quote: |  	  | We have dive computers and tables that we follow which tells us how many hours we have to wait before acending to any altitude depending
 You know, I never paid attention to see if the dive computer continues
 to do its thing in an aircraft and give you a decompression stop. I
 suppose there is no reason why it couldn't. SMOP (small matter of
 programming).
 Brian Lloyd
		| Back to top |  |
		| Ernie
				|  Posted: Wed Jan 18, 2006 12:28 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| I have 2 diver computers that I use, they both have (I think, since I
havent used them in 2 years) a mode which you can call up that says
 "OK to fly" when you've spent enough time out of the water. Same
 algoritm which tells you when you can dive again.
 If I remember correctly from Dive school, the dive tables also had
 some basic method for determining how much time must lapse before
 flying.
  	  | Quote: |  	  | >>Nitrogen Narcosis is from the increased nitrogen in solution disrupting the electrical potential transfer across the pre and post synaptic cleft of the
 Also, the fernaderstand coupling to the finnigan motor spignads, will
 de-cobobulate when administered in the presence of sinous friggle
 dangle near the copious osmobrosis, causing increased cluster bumpkins
 over the entire swaggle noodlefrapses region..
 Ernie
 On 1/18/06, Brian Lloyd <brian-yak(at)lloyd.com> wrote:
  	  | Quote: |  	  |
		| Back to top |  |
				|  Posted: Wed Jan 18, 2006 12:38 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| Do you know the first  sign of rapid decompression?
 You  Fart   like you would not believe.  Just hope its dry.
 Pappy
		| Back to top |  |
				|  Posted: Wed Jan 18, 2006 12:42 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| And Now Ernie you are a bonified Meyer - Overton expert!
Doc
  	  | Quote: |  	  | [Original Message] From: Ernest Martinez <erniel29(at)gmail.com>
 Date: 1/18/2006 2:28:14 PM
 Subject: Re: decompression sickness and narcosis (was:
 AYS-bound)
  	  | Quote: |  	  |
 flying.
 disrupting the
  	  | Quote: |  	  | electrical potential transfer across the pre and post synaptic cleft of the
  	  | Quote: |  	  | CNS. This most likely being in the Reticular Activating system and the Cortical mantle. It follows the Meyer-Overton hypothesis that states "all
 lipids
  	  | Quote: |  	  | of the cell wall in a definate molar concentraion that is characaristic for
  	  | Quote: |  	  | each type of animal tissue aand approximately the same for all narcotics." That is measured by the mean alveolar concentration (MAC) of the
 anesthetic
  	  | Quote: |  	  | agent. The measure of an anesthetic concentration of an inert gas is the concentration of the gas at which only 50% of rats will respond to
 pinching
  	  | Quote: |  	  | their tail with a ring forcep. The so called MAC 50. >>>
 Ernie
		| Back to top |  |
		| brian
				|  Posted: Wed Jan 18, 2006 1:27 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| Roger Kemp wrote:
  	  | Quote: |  	  |
 Brian,
 and tissue.
 compression dive.
 Hmm, I just went back and reread what I wrote. I think I made it pretty
 clear that any time you have a rapid decrease in pressure, whether
 ascending from a dive or ascending into the air, you can experience
 decompression sickness. What I was trying to assert is that it is very
 unlikely in an aircraft and much more likely from a dive. In fact, here
 is what I did say:
 "Any time you reduce the pressure on the body there is some chance of
 research this you will find that this is an *extremely* rare event."
 So, no, I did not assert that decompression sickness only comes from
 diving. I did assert it is very difficult to make it happen while flying.
 In any of the unpressurized aircraft we fly it is almost impossible to
 get a change in pressure that is sufficiently rapid to invoke
 decompression sickness. Going up right after a dive so that there is
 more N2 in the tissues might cause it tho'.
 And a rapid decompression from an 8,000' cabin to a 35,000' cabin might
 do it. That is why I made the comment about explosive decompression.
  	  | Quote: |  	  | The symptoms of Nitrogen Narcosis and Neurological Decompression sickness can be strikingly similar. One is from descent and the effect of an
 Right, that is decompression sickness.
  	  | Quote: |  	  | An aviator climbing from 1 ATA at sea level to 1/2 ATA at 18000 ft or 1/4 ATA at 33500ft unpressurized is at an increased risk for nitrogen coming
 The rate of ascent is a key part of that. We change pressure all the
 time when we fly. When was the last time you heard of a person in an
 unpressurized aircraft experiencing decompression sickness when that
 person had not been diving prior to flying? I have never known of a case
 but I don't have that much exposure.
 As an AME and (I presume) flight surgeon, you probably have a lot more
 exposure to that sort of thing. Still, without explosive decomp and
 without some prior activity to increase the N2 saturation, how many
 cases of decomp sickness have occurred? I hold that it occurs so
 infrequently that it is not worth worrying about.
  	  | Quote: |  	  | The same for the diver that was at 4 ATA ~ 100 feet of sea water (fresh water also) and ascending to the surface
 Bottom time influences it a lot. It has more effect than all the other
 factors you mention. It takes time for the N2 to dissolve in the blood
 and then move to the tissues. The longer you are under the greater
 partial pressure of N2, the closer you get to equilibrium and the longer
 it will take to reach equilibrium again at a lower pressure. That
 process can only proceed so fast and any attempt to make it go faster
 results in the N2 coming out of solution in gaseous form (bubbles).
 Those bubbles hurt.
  	  | Quote: |  	  | Nitrogen Narcosis is from the increased nitrogen in solution disrupting the electrical potential transfer across the pre and post synaptic cleft of the
 agent.
 I am familiar with that. The problem is finding inert gasses that have
 the effect at partial pressures less than 1 atmosphere. Xenon actually
 works pretty well but it is too expensive to use for that purpose.
  	  | Quote: |  	  | The measure of an anesthetic concentration of an inert gas is the concentration of the gas at which only 50% of rats will respond to pinching
 That is all well and good but I wasn't particularly interested in
 anesthetizing rats with inert gasses. (Sorry, I couldn't resist.)
 BTW, my research experience with blood gasses was working with dogs, not
 rats. I worked on a research project to develop a system to
 automatically determine blood gas concentrations and then make the data
 immediately available as part of a patient monitoring system. Writing
 the software and building the dedicated microprocessor hardware for that
 project was one of the ways I worked my way through college in the '70s.
 We used dogs as research subjects. I am sure that nowadays I would be
 drawn and quartered by some PETA enthusiast for even admitting I had
 something to do with killing dogs for research purposes.
 (We took dogs slated for euthanasia at the pound and performed various
 tests on cardiopulmonary function. The dogs were treated kindly and
 properly anesthetized prior to operating on them. When we had finished
 gathering our data they were then euthenized, which is a nice word for
 "killed". I did learn a LOT about cardiopulmonary function from that job
 tho'.)
 But I digress.
  	  | Quote: |  	  | We are comparing Apples and Oranges here.
 Agreed.
  	  | Quote: |  	  | Sorry Brian for mis-stating Narcosis instead of altitude decompression last night at 11:20.
 Right on bro'. It happens. We all make mistakes. The important thing is
 to make sure we then get the proper information into people's hands lest
 they make erroneous decisions based on improper information. We already
 have to make decisions based on insufficient information (as in deciding
 what do to in an off-airport landing). Bad information just compounds
 the problem.
 You get to buy the first round. I will buy the second.
 Darn, still no alphabet soup after my name and I am not old enough yet
 to exchange "curmudgeon" for "asshole".
 Brian Lloyd
		| Back to top |  |
				|  Posted: Wed Jan 18, 2006 1:30 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| Pappy,
That is why you wear a brown fight suit so when you release that wet trapped gas, it does not show up as well!
 Doc
		| Back to top |  |
		| brian
				|  Posted: Wed Jan 18, 2006 1:33 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| cjpilot710(at)aol.com wrote:
  	  | Quote: |  	  | */Do you know the first sign of rapid decompression?/* *//*
 */You  Fart  like you would not believe.  Just hope its dry./*
 Yeah, that was the worst thing about taking off your mask in the
 hypobaric chamber to experience the effects of hypoxia. Everyone had
 farted their asses off and the chamber stunk big time.
 BTW, if you haven't taken a 'chamber ride' you should. Seeing what it is
 like to experience pressure breathing O2 at 42,000' and hypoxia at
 25,000' is good experience.
 Brian Lloyd
		| Back to top |  |
		| talew(at)bellsouth.net Guest
				|  Posted: Wed Jan 18, 2006 3:36 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| Pappy,
My older captains taught me to never count on a dry fart after 50 years  old. I believe they were right. Although, you understand, I can' t confirm  that.
   Terry Lewis
 [quote]   ---
		| Back to top |  |
				|  Posted: Wed Jan 18, 2006 4:21 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| There are no dry farts over age 55. Just old farts.
Doc
		| Back to top |  |
		| JOffice(at)aol.com Guest
				|  Posted: Wed Jan 18, 2006 5:06 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| In a message dated 1/18/2006 3:29:43 PM US Eastern Standard Time, erniel29(at)gmail.com writes:
  	  | Quote: |  	  | >>>Nitrogen Narcosis is from the increased nitrogen in solution disrupting the electrical potential transfer across the pre and post synaptic cleft of the
 Ernie
 Viperdoc-
 Well, I appreciated it anyway...  buy you didn't talk about Argon and Neon as anesthetics at high pp...
 JSL
 (another anesthesiologist-pilot)
		| Back to top |  |
		| L39parts(at)hotmail.com Guest
				|  Posted: Thu Jan 19, 2006 6:27 am    Post subject: decompression sickness and narcosis (was: AYS-bound) |   |
				| I didn't realize so many CJ pilots were divers.  Here's an interesting  story about SCUBA diving to 900 feet HTTP://outside.away.com/outside/features/200508/dave-shaw-1.html  in the deepest freshwater lake (cave) in the world.
[quote]   ---
		| Back to top |  |
