barp99(at)gmail.com Guest
Posted: Fri Jan 25, 2019 6:59 pm Post subject: XS Port wing stiffener misalignment |
I have just commenced build work on my XS wings, and have found that the
spanwise stiffener on the underside of the Port wing closure panel does
not line up with the rebates in the ribs, causing the skin to sit too
high and preventing a bond to the ribs, see spanwise photo. What have
others done who have been through this issue?
Many thanks,
Brian Phillips
Builder 489
40.94 KB |
5061 Time(s) |
Richard Wheelwright
Joined: 15 Sep 2008 Posts: 111 Location: Halifax, West Yorkshire, UK
Posted: Fri Jan 25, 2019 11:14 pm Post subject: XS Port wing stiffener misalignment |
Hi Brian
There is a fix for this. It may be on the LAA website of the Europa club website.
Richard
_________________ Richard Wheelwright
G-IRPW
First Flight 24th July 2013
Last edited by Richard Wheelwright on Sat Jan 26, 2019 11:55 am; edited 1 time in total |
alan.twigg775(at)gmail.co Guest
Posted: Fri Jan 25, 2019 11:46 pm Post subject: XS Port wing stiffener misalignment |
Brian, looks like the stiffener has been bonded to the wrong side if the marked line. EUROPA might (should ) be able to sort this out.
Dear old Nev would have cut it off and re bonded in the correct position but if EUROPA cannot help, Andy Draper at LAA HQ will know the way to proceed.
Alan Twigg
Kit 463 ( Long wings )
| Quote: | On 26 Jan 2019, at 02:59, Brian Phillips <barp99(at)gmail.com> wrote:
I have just commenced build work on my XS wings, and have found that the spanwise stiffener on the underside of the Port wing closure panel does not line up with the rebates in the ribs, causing the skin to sit too high and preventing a bond to the ribs, see spanwise photo. What have others done who have been through this issue?
Many thanks,
Brian Phillips
Builder 489
<P1253686.jpg>
Kelvin Weston
Joined: 14 Apr 2010 Posts: 90 Location: Hampshire, UK
Posted: Sat Jan 26, 2019 1:05 am Post subject: Re: XS Port wing stiffener misalignment |
Hi Brian
Have a look at the Tech Info on the Europa website:
http://www.europa-aircraft.co.uk/updates/
Service Bulletin 8 addresses this problem.
It is also worth having a browse through the Tech Talk section. There is a lot of good information that addresses a lot of the 'little anomolies' you will come across as you progress through your build.
Lots of good information on the Europa Club website if you are a member.
_________________ Regards
Kelv Weston
Kit 497
kelv@kdweston.co.uk |
