Which is better for laminated glass and insulating glass?
ahwhglass
PostPosted: Tue Jan 22, 2019 9:38 pm    Post subject: Which is better for laminated glass and insulating glass? Reply with quote
INSULATING glass was invented simply by Americans in 1865. This is the new building material together with good heat insulation, noise insulation, beautiful appearance in addition to reduced building weight. That uses two (or three) eyeglasses. The high-strength and high-air-tight composite adhesive can be used to bond the glass piece towards aluminum alloy frame containing the desiccant to offer a high-performance sound insulation and insulating glass. fire resistant glass supplier
Laminated glass is additionally called laminated glass. It is just a two-piece or several float glass sandwich to difficult PVB (ethylene polymer butyrate) film, which is pressed with a hot press and discharged regularly, and then placed in the high-pressure steam kettle utilizing high temperature and underhand. A small amount regarding residual air is dissolved inside film. Compared with additional glass, it has the particular performance of shockproof, anti-theft, bulletproof and explosion-proof.
First of all, the laminated glass and the insulating glass have the sound insulation effect to some extent. However, laminated glass has excellent shock challenge and explosion-proof performance, whilst insulating glass has much better thermal insulation.
In words of sound insulation, you will find different differences between both the. Because of the great seismic performance of laminated cup, when the wind is definitely large, the possibility of noise brought on by self-vibration is small, specifically for medium and low frequencies. Insulating glass is at risk from resonance.
But to say that it is isolated from additional noise, it is still a slight advantage. For that reason, depending on the location, the glass to be chosen is different.
If it is common household, insulating glass may be the most widely chosen. In the event you live in the higher level, the wind is big, and the noise is relatively small when compared to outside world. Laminated glass is also your best option.
The most direct manifestation on the two types of glass is the sun room. Typically, the top of the sun room consists of double-layer tempered glass. The facade glass on the sun room uses insulating glass.
Because if a person encounter high-altitude falling things, the safety of laminated tumbler is relatively high in fact it is not easy to absolutely break. The fa├žade a glass uses insulating glass to better achieve thermal insulation, so that the sunshine room is warm throughout winter and cool with summer.
Therefore, it cannot be said that double-layer laminated tumbler and double-layer insulating goblet are better, and it might only be said how the demand in which point is greater.
