Elaine5056(at)msn.com Guest
Posted: Wed Jul 19, 2006 2:55 pm Post subject: Model II Brakes |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I purchased my model II completed so I haven't had to work with the brakes so far. I need to fill up the brake fluid but there isn't a reservoir by the pedals. What's the best method for filling up the system?
- Verne
eskflyer(at)lvcisp.com Guest
Posted: Wed Jul 19, 2006 3:22 pm Post subject: Model II Brakes |
`you loosen the screw in the toip of the resavoir and push the fluid from the brake caliper back to the master cylinder . if any questions call me and ill help all i can i have a model 2 .
John Perry
eskflyer(at)lvcisp.com (eskflyer(at)lvcisp.com)
580-695-8778
bmwebb(at)cox.net Guest
If it’s original, you have the MC-1 master cylinder, and the PH-1 calipers. The reservoir is the master cylinder itself. It holds a couple ounces of fluid. There should be screw on the top. Remove that, and stick a white, small zip-tie down to check the level.
MC Drawing here…
http://matco.elixirlabs.com/catalog/index.php?file=catalog&uid=2192&prod_pcategory=69102&clist=0,68008,69102&uid=2192
Caliper drawing here…
http://matco.elixirlabs.com/catalog/index.php?file=catalog&uid=2192&prod_pcategory=69101&clist=0,68008,69101&uid=2192
DO NOT use DOT 3 automotive fluid. That’s what happened to mine. All the seals had to be replaced. Use MIL-H-5606 spec fluid, and you can’t get it at the auto parts stores.
BTW, check this link on 5606 fluid…
http://www.tpub.com/content/aviation/14018/css/14018_178.htm
Even though the piston shaft is supposed to be the vent, Matco drills the center of the screw with a small hole to “help” it. They replaced mine with plastic internals wrenching screws, but you can use whatever fits the threads.
Bradley
Model 2
N1836
Middle Georgia
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Elaine Erickson
Sent: Wednesday, July 19, 2006 6:55 PM
Subject: Model II Brakes
- Verne
Posted: Wed Jul 19, 2006 6:23 pm Post subject: Model II Brakes |
I used a turkey baster from Wal-Mart and a length of clear tubing. Target has neat metal ones.
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Noel Loveys
Sent: Wednesday, July 19, 2006 9:36 PM
Subject: RE: Model II Brakes
I opened the bleeding screw on the master cylinder,wrapped it in lots of cloth and pumped fluid in through the bleeder on the callipers with a small oil can and a length of clear tubing.
Noel | Quote: |
-----Original Message-----
Sent: Wednesday, July 19, 2006 8:25 PM
- Verne
elaine5056(at)msn.com Guest
Posted: Fri Jul 21, 2006 4:59 pm Post subject: Model II Brakes |
Thanks to everyone who replied to this message. The info was very helpful.
- Verne
| Quote: | From: "Elaine Erickson" <Elaine5056(at)msn.com>
Date: Wed, 19 Jul 2006 18:55:10 -0400
- Verne
