Paul Valovich
Posted: Thu Jan 10, 2019 6:31 am Post subject: Building Coax |
When building a coax cable can I use a male D-sub pin instead of the pin supplied in the connector bag?
Tried to crimp those pins with a D-sub crimper and it didn’t go well. I now have extra connectors with no pins.
echristley(at)att.net Guest
Posted: Thu Jan 10, 2019 7:27 am Post subject: Building Coax |
You could use a piece of clipped off a paperclip if you could get it to stick. The problem is reliability.
Those pins are designed to "click" inside the connector, or be seal with a silicone o-ring. Until moisture seeps in, just leaving the center wire sticking out will work just as well as the crimped pin. Getting the connector to go together without bending the center wire and destroying the connection . . let's say I've done it, but don't really want to do it again.
I'm pretty sure you can get just the pins fairly cheap.
On Thursday, January 10, 2019, 9:32:33 AM EST, Valovich, Paul <pvalovich(at)dcscorp.com> wrote:
Posted: Thu Jan 10, 2019 8:38 am Post subject: Building Coax |
At 08:30 AM 1/10/2019, you wrote:
| Quote: | When building a coax cable can I use a male D-sub pin instead of the pin supplied in the connector bag?
Tried to crimp those pins with a D-sub crimper and it didn’t go well. I now have extra connectors with no pins. |
the connectors are cheap.
https://tinyurl.com/yd4z7gta
throw the first one away and start over.
Posted: Thu Jan 10, 2019 9:43 am Post subject: Building Coax |
On 1/10/2019 9:30 AM, Valovich, Paul wrote:
| Quote: | <![endif]--> <![endif]-->
I had a similar situation. I substituted a D-sub pin and it seems to have worked well.
With that said, I'm ordering some extra pins for my remaining orphan plugs per Bob's post.
Question: What is one supposed to crimp those pins with? The D-sub crimper?
www.avast.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
rick(at)beebe.org Guest
Posted: Thu Jan 10, 2019 10:36 am Post subject: Building Coax |
There is, of course, a specialty crimper. The ratchet crimper I have has small holes for crimping the pin and then a larger hole to crimp the ferrule. Something like https://tinyurl.com/y7tv4jzl
--Rick
Question: What is one supposed to crimp those pins with? The D-sub crimper? |
Posted: Thu Jan 10, 2019 10:57 am Post subject: Building Coax |
The tool you crimped the hex-sleeve should
have a die for pins
[img]cid:7.1.0.9.0.20190110124906.05e98e10(at)aeroelectric.com.0[/img]
See https://tinyurl.com/y7to3wnb
66.92 KB |
6956 Time(s) |
Posted: Thu Jan 10, 2019 11:03 am Post subject: Building Coax |
I had a similar situation. I substituted a D-sub pin and it seems to have worked well. |
NOT A GOOD IDEA. The pin retaining mechanism
for these two technologies could not be more
different. Further, the d-sub pin o.d. is
0.040" while the BNC pin o.d. is 0.052"
NOT a good match.
scuperhead
Posted: Thu Jan 10, 2019 11:20 am Post subject: Building Coax |
Hi Bob,
Could you remove me from the email notification portion of the list?
Thank you,
Craig Schulze
From: <owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)> on behalf of "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Reply-To: <aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)>
Date: Thursday, January 10, 2019 at 11:02 AM
Subject: Re: Building Coax
NOT a good match.
_________________ Blue Skies,
Craig |
Posted: Fri Jan 11, 2019 9:53 am Post subject: Building Coax |
On 1/10/2019 2:02 PM, Robert L. Nuckolls, III wrote:
| Quote: | | Quote: |
NOT a good match. |
I'll get that fixed! Thanks as always.
