Delta Pop Transponder Antenna and Garmin GDL 82
PostPosted: Sun Jan 06, 2019 6:10 am    Post subject: Delta Pop Transponder Antenna and Garmin GDL 82 Reply with quote
At 11:36 PM 1/5/2019, you wrote:
--> AeroElectric-List message posted by: Michael Burbidge <mburbidg(at)gmail.com>
Does anyone know if these two play well together?
Transponder/DME/ADSB antennas are
generic devices and not specific
to the panel equipment they are paired
with.
Tim Olson
PostPosted: Sun Jan 06, 2019 9:05 am    Post subject: Delta Pop Transponder Antenna and Garmin GDL 82 Reply with quote
The Delta Pop transponder antenna should work fine if you already own one. If you still need to buy one they do have a UAT antenna tuned more precisely for 978mhz that would be perfect. They are close enough for the task that either will work.
On Jan 6, 2019, at 8:09 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: Michael Burbidge <mburbidg(at)gmail.com (mburbidg(at)gmail.com)>
with.
