DPSK Unlock on Dynon Xpndr
wdaniell.longport(at)gmai
PostPosted: Tue Dec 25, 2018 5:40 am    Post subject: DPSK Unlock on Dynon Xpndr Reply with quote
I have this "DPSK Unmlock" on my Dynon.  The last time it appeared they changed the unit so this is the second unit to suffer the same thing.
I am interested to know what it means and if anything in my system might be provoking it.
My aircraft is a Europa with the Rotax Z16 (which you all helped me with and which is working very well) and I followed manufacturer's instructions with separating ADSB and Transponder antenna.
I used ADVANCED AIRCRAFT ELECTRONICS HIGH GAIN TRANSPONDER ANTENNA (L2) from ACS for both transponder and ADSB.
Everything worked normally (they see me on radar and I can see other traffic).   When I get the message,  I cycle the transponder and the message goes away.
So is this something in my system or is it a manufacturing issue?
Thanks and Happy Holidays to all
Will
William Daniell
LONGPORT
+57 310 295 0744
ceengland7(at)gmail.com
PostPosted: Tue Dec 25, 2018 7:14 am    Post subject: DPSK Unlock on Dynon Xpndr Reply with quote
This?
http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1508284062
Charlie
On Dec 25, 2018, at 8:44 AM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Will
William Daniell
LONGPORT
+57 310 295 0744
PostPosted: Tue Dec 25, 2018 8:00 am    Post subject: DPSK Unlock on Dynon Xpndr Reply with quote
Thats the one!
But i was wondering if anyone knows why this happens....
Dynon just asked me to send the unit back last time this happened...this is the second unit with the same issue which seems a little wierd.  Maybe it was a bad batch.
Also without a transponder these days you're grounded.   Certainly in Colombia you cant fly wiithout a working transponder.
Will
On Tue, Dec 25, 2018, 10:18 Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com) wrote:
This?
Charlie
Will
William Daniell
LONGPORT
+57 310 295 0744
