Need spark plug wrench for # 6 cylinder
motoadve
PostPosted: Tue Dec 04, 2018 6:53 am    Post subject: Need spark plug wrench for # 6 cylinder Reply with quote
Doug does not have them in stock.
Any other source?
www.Backcountry182.com
Cessna 182 P
CJ -6
Top Ace
PostPosted: Wed Dec 05, 2018 12:55 pm    Post subject: Re: Need spark plug wrench for # 6 cylinder Reply with quote
Alternate is take the 22mm, or 7/8th long socket, cut or grind down one side at 45 degrees off the socket head, and then it will work, on cyl, # 6,,
or wait till Doug gets some in for you,,
David
GeorgeCoy
PostPosted: Wed Dec 05, 2018 2:21 pm    Post subject: Need spark plug wrench for # 6 cylinder Reply with quote
We have a limited quantity of these basic tool kits available at the
factory, but they aren't cheap $525 each plus shipping.
George Coy
MotorstarNA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
george.coy(at)gmail.com
http://motorstarna.com/
SKYPE george.coy
 Filesize:  662.93 KB
 Viewed:  6041 Time(s)
wlannon(at)shaw.ca
PostPosted: Wed Dec 05, 2018 9:38 pm    Post subject: Need spark plug wrench for # 6 cylinder Reply with quote
George et al:
I am more than a little confused about the problem with the #6 cyl. rear
spark having been removing and installing these regularly for about 25
years.
I normally use the Chinese spark plug wrench for removal and my 80 year old
P & W spark plug socket (7/8" deep) and torque wrench for installation
including #5 and #6 rear; they are both a pain in the ass! The only
difference with these is that you simply attach the socket to the plug
before attaching the torque wrench. These are all 3/8" drive tools, 1/2'
may be a problem but I don't know. I have never found a need to modify the
socket.
Sounds simple but now it get's interesting! Looking at the very nice photo
George supplied I fail to see a spark plug wrench (these are Russian but no
significant difference at all). So time to check out the HS6A Parts Cat.
Tools section. See pg. 259 and on. Fig 17 -1, Item 10 is described as a
"spark plug spanner". This is exactly the same tool as shown # 6 from the
left in George's photo. Well I'll be damned! The real Chinese spark plug
wrench des not apparently exist!
I have two or three of these laying around the hangar. They sure enough are
22mm and fit the spark plug but as a spark plug wrench they are virtually
useless particularly for #6 rear. In fact I have found no use for them at
all.
My guess is the Chinese Air Force grunts agreed with me and designed a tool
that actually works! In which case my good buddy Doug will know all about
this and get some in stock. They are not really necessary but are very
convenient for plug removal.
If my brain is in working order tomorrow I will get a photo of the non -
existant wrench for you.
Cheers;
Walt
dougsappllc(at)gmail.com
PostPosted: Thu Dec 06, 2018 11:01 am    Post subject: Need spark plug wrench for # 6 cylinder Reply with quote
"Spanner for spark plug of cylinder no.6" is shown in my version of the IPBs on page 122 of book #3, figure 2-7.
On the web site CJ6.org it is shown in book #3, but on page 126, which means that there are at lease two maybe 3 different iterations of the CJ6 parts books out there.
We think we have the bugs worked out of the downloads on the site now, others report success in downloading the manuals.
Doug
On Wed, Dec 5, 2018 at 9:48 PM Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
[quote]--> Yak-List message posted by: "Walter Lannon" <wlannon(at)shaw.ca (wlannon(at)shaw.ca)>
George et al:
years.
socket.
all.
Cheers;
Walt
