Stall warning through Radio
John M Tipton
PostPosted: Thu Nov 29, 2018 6:39 am    Post subject: Stall warning through Radio Reply with quote
Hi
What kind of input do I use to in-put a 'Stall Warning' sound through the radio
PostPosted: Thu Nov 29, 2018 7:22 am    Post subject: Re: Stall warning through Radio Reply with quote
If all you have now is a stall warning vane and switch, then that switch needs to turn on an audio oscillator which is then connected to an aux audio input on the radio. Search eBay for Assembled Audio Oscillator
Joe Gores
John M Tipton
PostPosted: Fri Nov 30, 2018 7:02 am    Post subject: Stall warning through Radio Reply with quote
I presume you mean one of these:
https://www.ebay.co.uk/itm/Assembled-Low-Distortion-Audio-Range-Oscillator-1KHz-Sine-Wave-Signal-Generator/153165312394
Sent from Mail for Windows 10
Sent: 29 November 2018 15:22
Subject: Re: Stall warning through Radio
Joe Gores
http://forums.matronics.com/viewtopic.php?p=485868#485868
PostPosted: Fri Nov 30, 2018 6:11 pm    Post subject: Re: Stall warning through Radio Reply with quote
Yes, something like that is what I had in mind. If someone else has a suggestion, please post.
Joe Gores
Eric Page
PostPosted: Fri Nov 30, 2018 6:57 pm    Post subject: Stall warning through Radio Reply with quote
Joe, you might try searching eBay for “voice recorder module.” There are several variants that can record whatever you wish, and play it back when triggered. Prices start at $0.99.
Eric
PostPosted: Sat Dec 01, 2018 6:36 am    Post subject: Re: Stall warning through Radio Reply with quote
Good suggestion Eric. I have one of those voice recorders along with an airspeed switch
on my RV-12 to warn of unlatched canopy during takeoff roll. -
John, search eBay for item number 332182973272, (Diy Kit 16-Tone)
I used one of those to make a toy for grand kids.
The description mentions voice, but there is no voice, just sounds.
Joe Gores
PostPosted: Sat Dec 01, 2018 6:50 am    Post subject: Re: Stall warning through Radio Reply with quote
Those do-it-yourself kits require that aircraft voltage be reduced, perhaps to 5 volts.
Joe Gores
PostPosted: Sat Dec 01, 2018 12:48 pm    Post subject: Stall warning through Radio Reply with quote
[img]cid:7.1.0.9.0.20181201144640.0208eff8(at)aeroelectric.com.0[/img]
How about this?
 Filesize:  191.81 KB
 Viewed:  10295 Time(s)
PostPosted: Mon Dec 03, 2018 2:35 pm    Post subject: Re: Stall warning through Radio Reply with quote
There are lots of ways to make an alarm tone.
The Forrest Mims Engineer's Notebook (my favorite book) has some circuits.
https://www.zpag.net/Electroniques/Kit/The%20Forrest%20Mims%20Engineers%20Notebook.pdf
On page 55 is a gated tone source. Grounding a pin on a 74LS368 turns on the tone.
Joe Gores
PostPosted: Mon Dec 03, 2018 2:52 pm    Post subject: Stall warning through Radio Reply with quote
Boy . . . there's a classic. I've recommended
that publication dozens of times over the years.
An excellent learning tool.
