Snot valve, constantly builds pressure. Normal/Not?
bmsim
PostPosted: Tue Nov 20, 2018 5:33 am    Post subject: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
Hello Everyone!
In searching for an air leak and rebuilding a couple of things already, I found something I have a question about. Whenever I open the snot valve, air blows out. This is regardless of if the engine has ran or not, if I dump it and let it sit for 10 min, I can open the valve and it has pressure. Is that normal, or might I be leaking air there?
Brandon
dougsappllc(at)gmail.com
PostPosted: Tue Nov 20, 2018 6:53 am    Post subject: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
Check valve (s) on the PRV are most likely leaking.
Doug
On Tue, Nov 20, 2018 at 5:41 AM bmsim <bmsim(at)hotmail.com (bmsim(at)hotmail.com)> wrote:
--> Yak-List message posted by: "bmsim" <bmsim(at)hotmail.com (bmsim(at)hotmail.com)>
Hello Everyone!
Brandon
http://forums.matronics.com/viewtopic.php?p=485342#485342
br> fts!)
r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
dsavarese0812(at)bellsout
PostPosted: Tue Nov 20, 2018 9:12 am    Post subject: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
No, that is not normal.  You have a check valve leaking.
Dennis
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 11/20/2018 8:33 AM, bmsim wrote:
Hello Everyone!
Brandon
bmsim
PostPosted: Wed Nov 21, 2018 9:37 am    Post subject: Re: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
Thanks guys!
I have rebuild kits and filter for the T assembly. For the individual sides, do the check valves just screw apart? I disassembled the T the other day and tried to take one of the valves apart but it was so hard to turn that it appears to need a vise. I didn't know if that's normal or if I'd be tearing something up, so I stopped until I could ask.
Should the individual sides of the T assembly require a vise to disassemble, or am I missing something on how to disassemble?
Brandon
hkgibby(at)yahoo.com
PostPosted: Wed Nov 21, 2018 10:23 am    Post subject: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
Hi Brandon-
Yes a vise will help in disassembly and rebuild of your check valves and pop off valve. You really ought to have the CJ parts manuals. Refer to Parts Book Vol 1, pages 442-448 for all things check valves. Will all make sense. I sent you Vol 1 direct to your email.
Hoot
On Nov 21, 2018, at 12:37 PM, bmsim <bmsim(at)hotmail.com> wrote:
Thanks guys!
Brandon
http://forums.matronics.com/viewtopic.php?p=485478#485478
bmsim
PostPosted: Wed Nov 21, 2018 11:07 am    Post subject: Re: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
Thank you very much!
hill(at)doctor-hill.com
PostPosted: Wed Nov 21, 2018 11:44 am    Post subject: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
Brandon,
On occasion, after rebuilding the CJ check valves, they will continue to leak for a week or two. The hard rubber disk over the metal cap on top of the spring may take a while to properly seat. Soaking the hard rubber cap in glycerine sometimes helps. A few will continue to leak no matter what and need to be replaced. A simple test of individual check values before going through the trouble of installing them is to connect an air pressure gauge via a B-nut on the outflow side and then pressurize the inflow side to 50 ATM (735 PSI). After turning off and removing the air source, the pressure on the outflow side should hold. A common point of failure and annoyance is on the right side of the oil tank where a pair of check valves separate air flow into the main and the emergency systems.
It’s also not a bad idea to replace check values that have been in place for a long time. The amount of internal corrosion can be astonishing. Attached is a picture of what typical check valve corrosion looks like.
Hope this helps,
Warren Hill
N464TW
Mesa, AZ
[img]cid:DF4C9940-B54B-4241-B05B-DAD8B38D1035[/img]
On Nov 21, 2018, at 11:22 AM, Hank Gibson <hkgibby(at)yahoo.com (hkgibby(at)yahoo.com)> wrote:
--> Yak-List message posted by: Hank Gibson <hkgibby(at)yahoo.com (hkgibby(at)yahoo.com)>Hi Brandon-Yes a vise will help in disassembly and rebuild of your check valves and pop off valve. You really ought to have the CJ parts manuals. Refer to Parts Book Vol 1, pages 442-448 for all things check valves. Will all make sense. I sent you Vol 1 direct to your email.HootSent from my iPhone
On Nov 21, 2018, at 12:37 PM, bmsim <bmsim(at)hotmail.com (bmsim(at)hotmail.com)> wrote:--> Yak-List message posted by: "bmsim" <bmsim(at)hotmail.com (bmsim(at)hotmail.com)>Thanks guys!I have rebuild kits and filter for the T assembly. For the individual sides, do the check valves just screw apart? I disassembled the T the other day and tried to take one of the valves apart but it was so hard to turn that it appears to need a vise. I didn't know if that's normal or if I'd be tearing something up, so I stopped until I could ask. Should the individual sides of the T assembly require a vise to disassemble, or am I missing something on how to disassemble?BrandonRead this topic online here:http://forums.matronics.com/viewtopic.php?p=485478#485478
http://wiki.matronics.com
 Filesize:  159.94 KB
 Viewed:  11102 Time(s)
PostPosted: Wed Nov 21, 2018 12:32 pm    Post subject: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
Brandon-
You could also replace all check valves with Swagelok check valves which are an easy drop in. Problems solved and no more fiddling with rubber discs/crush seals and bodies which loosen. All six for about $280. To me worth the price to improve health of pneumatic system. Old nipples with flare are transferred and work with a 1/8” NPT Swagelok. Part number is “SS-2C4-xx (last number is “cracking pressure” which is not critical, may be 1/3, 1, 10 and 25 , I believe). See pics.
[img]cid:B9CAA587-2B29-4D67-8B05-81B36318EA85[/img]
[img]cid:881E5241-4750-45B9-9506-427AFD0FA716[/img]
Sent from my iPhone[img]cid:98D9F294-EEDB-4B2A-ADE5-84AD48D13AD5[/img]
Good luck- Hoot
On Nov 21, 2018, at 2:18 PM, Warren Hill <hill(at)doctor-hill.com (hill(at)doctor-hill.com)> wrote:
Brandon,
Hope this helps,
Warren Hill
N464TW
Mesa, AZ
<Check_Valve.jpg>
http://www.matronics.com/Navigator?Yak-Listhttp://wiki.matronics.comhttp://www.matronics.com/contribution
 Filesize:  690.07 KB
 Viewed:  11097 Time(s)
 Filesize:  588.72 KB
 Filesize:  636.24 KB
Viperdoc
PostPosted: Wed Nov 21, 2018 6:42 pm    Post subject: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
Sounds like the system check valves on the firewall are leaking. If one is leaking they all will eventually leak. May as well replace all three.
This is the T rebuild using CJ new SS check valves from Doug Sapp. You will have to wrap the valves with anti chaff tape to get the correct diameter when you anchor the adell clamps on the firewall. There is a L beam firewall stiffener that the B nut will chaff on if you do not put a chaff tape spacer on the check valve barrels.
Doug has a kit that has all the needed check valves to replace your existing leakers.
Doc
On Nov 20, 2018, at 7:33 AM, bmsim <bmsim(at)hotmail.com> wrote:
Hello Everyone!
Brandon
 Filesize:  1.34 MB
 Viewed:  11093 Time(s)
Viperdoc
PostPosted: Thu Nov 22, 2018 12:54 pm    Post subject: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
Hank,
Some have not had good luck with the Swagelok check valves. One member of our group had four of these fail on a trip to Oskkosh several years ago. The more robust Chinese replacements are still working. Where Swagelok does a great job is for replacing the original Chinese main and emergency air on-off valves as described by Jason Berman. Mine have been fine for years. The smaller size requires two simple adaptors so the connecting air lines don’t have to be re-done. Attached is a picture of my emergency on-off valve with adaptors that duplicate the original line positions. For those who have not yet done this replacement, the current black handle valve for the main air is part number SS-42GF2-A-WN2 and the red handle part number is SS-42GF2-A-RD-WN2. Replace and forget. Really nice. One less thing to cause problems.
Warren Hill
N464TW
Mesa, AZ
[img]cid:EAE9B400-E834-43EA-9F8E-4560C6ABBEC3(at)Home[/img]
On Nov 21, 2018, at 1:30 PM, Hank Gibson <hkgibby(at)yahoo.com (hkgibby(at)yahoo.com)> wrote:
Brandon-
<image1.jpeg>
<image3.jpeg>Sent from my iPhone<image4.jpeg>
Good luck- Hoot
Brandon,
Hope this helps,
Warren Hill
N464TW
Mesa, AZ
<Check_Valve.jpg>
 Filesize:  244.06 KB
 Viewed:  11082 Time(s)
Viperdoc
PostPosted: Thu Nov 22, 2018 9:53 pm    Post subject: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
CJ or YAK? The YAK check valves that have been in use for a few bears are a bitch to get apart. I personally think they use epoxy on the groves. It takes a vice and a torc to get them apart on occasion. Be prepared to replace all of the guts in that case.
You can just send them to Cliff Coy to rebuild with Parker air system parts. They hone the case to do that.
Or you could replace the with Dzongkha Sapps Kit.
Doc
On Nov 21, 2018, at 11:37 AM, bmsim <bmsim(at)hotmail.com> wrote:
Thanks guys!
Brandon
Viperdoc
bmsim
PostPosted: Fri Nov 23, 2018 6:27 am    Post subject: Re: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
Thank you guys all so much for the help! Lots of options and great ideas here.
Yes, this is a Yak.
Brandon
PostPosted: Mon Nov 26, 2018 8:02 am    Post subject: Snot valve, constantly builds pressure. Normal/Not? Reply with quote
Jill Gernetzke can also repair/rebuild them, but it takes the force of a pneumatic hammer to get them apart.
Warren Hill
Doc
> Thanks guys!
> Brandon
