Classic Spinner - front bulkhead for Airmaster
kdietric
PostPosted: Sat Nov 17, 2018 7:58 am    Post subject: Classic Spinner - front bulkhead for Airmaster Reply with quote
Hi,
I'm rebuilding my spinner of my Europa Classic and would need a new spinner front bulkhead with a diameter of 230 mm for an Airmaster prop (with the 48mm hole in it to fit the electric motor of the VP prop).
Does anybody out there has one left, which he doesn’t need anymore and would sell? Cheers,Klaus (OE-CKD)
JonathanMilbank
PostPosted: Sat Nov 17, 2018 8:55 am    Post subject: Re: Classic Spinner - front bulkhead for Airmaster Reply with quote
Hi Klaus,
Would it perhaps be possible to modify the bulkhead which I sent you and to enlarge the hole? Perhaps not, because after cutting the hole to a larger diameter, the remaining plastic material would be thin and it would be difficult to make the bulkhead sit squarely on the end of the electric motor casing. Maybe an insert or an adapter could be added to the middle of the bulkhead, after enlarging the hole?
Just thinking! All best wishes.
Jonathan
