al.bijkerk(at)kliksafe.nl Guest
Posted: Sat Jul 15, 2006 9:45 am Post subject: pitch angle Warp Drive propeller |
Is there anybody who has a suggestion for the (nearly) correct pitch angle
(measured on the tips) on my new 3-blade 68" Warp Drive propeller with
tapered tips in combination with a Rotax 912 (80HP) engine. I want 5000 RPM
static on the ground. I'm using the original Warp Drive protractor.
Andy
Kitfox Vixen V
kitfoxpilot(at)msn.com Guest
Posted: Sat Jul 15, 2006 2:10 pm Post subject: pitch angle Warp Drive propeller |
I have been flying with 16 degrees pitch, I have a model IV 1200 with a
912uls.
Ray
| Quote: | From: <al.bijkerk(at)kliksafe.nl>
Subject: pitch angle Warp Drive propeller
Date: Sat, 15 Jul 2006 19:44:21 +0200
Andy
Kitfox Vixen V
lcfitt(at)sbcglobal.net Guest
Posted: Sat Jul 15, 2006 4:03 pm Post subject: pitch angle Warp Drive propeller |
Andy, I have been running at 17 degrees with the protractor at the inboard
edge of the metal leading edge. I may be a bit course at that, but got 5000
RPM and 800 fpm on a climb out this afternoon from my home airport - 1300 ft
elev and 98 degrees F.
Lowell
janderson412(at)hotmail.c Guest
Posted: Sat Jul 15, 2006 11:48 pm Post subject: pitch angle Warp Drive propeller |
About 12degs at the tips for a start and test the static RPM, keep increasing until you get 4500 or so. That'll get you safely in the air.
Subject: Re: pitch angle Warp Drive propeller
Date: Sat, 15 Jul 2006 16:59:24 -0700
--> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
Andy, I have been running at 17 degrees with the protractor at the inboard edge of the metal leading edge. I may be a bit course at that, but got 5000 RPM and 800 fpm on a climb out this afternoon from my home airport - 1300 ft elev and 98 degrees F.
Lowell
al.bijkerk(at)rdnet.nl Guest
Posted: Tue Jul 18, 2006 11:06 pm Post subject: pitch angle Warp Drive propeller |
Ray, Lowell, John,
Thank for your advice setting the pitch angle of my Warp Drive propeller.
Andy
