| stephencliverichards(at)g Guest
				|  Posted: Wed Oct 24, 2018 10:16 am    Post subject: Rectifier/Regulator Charging Current (Amps)  Measurement |   |
				| Hi hugh as a ammeter has to be connected in series with the output of the regulator I think the output is probably 30 amp which will be greater than the digital meter usually 10 amp.
 You can get a cheap analog DC 30 amp ammeter with a seperate shunt from ebay and connect that.
 Alternatively you can get a relatively cheap DC 30-0-30 amp clipon ammeter again from ebay and clip over regulator output cable or battery cable will no be very accurate but probably ok for your needs
 Clive
 Get Outlook for Android
 From: owner-rotaxengines-list-server(at)matronics.com <owner-rotaxengines-list-server(at)matronics.com> on behalf of Hugh McKay <hgmckay(at)bellsouth.net>
 Sent: Wednesday, October 24, 2018 4:24:20 PM
 Subject: RotaxEngines-List: Rectifier/Regulator Charging Current (Amps) Measurement
 How can I measure the amount of battery charging current being put out by the Rotax Rectifier/Regulator using a digital multimeter?
 Hugh G. McKay III, P.E. Fellow. L.M. ASCE
 Senior Consultant
 Worldwide Engineering Inc.
 4090 North NC Hwy. 16
 Denver, NC 28037
 Ph. 704-661-8271
 Fax 704-483-5466
 Email hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
 http://www.geo.com (click on Power Division)
 Sent from Mail for Windows 10
 | |  |  | - The Matronics RotaxEngines-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?RotaxEngines-List
